Question about Black & Decker String Trimmer Cordless 12" 18V
Head falls off
My grass hog head falls off, or is unattached to the main center rod and thus has no power for cutting. It spends loosely, then falls off. How do I get this to re-attach?
  • M19SOORKB Jun 16, 2008
    The head containing the string will not stay on the trimmer. It will whack weeds for maybe 5 seconds and then the head becomes detached from the trimmer. HELP!
  • 313 Answers
SOURCE: Black & Decker CST1000 Grass Hog Grass Trimmer
common problem battery.
Posted on Jun 08, 2008
  • 9 Answers
SOURCE: Black and Decker Grass Hog Model #GH1000
the drive cable probley kinked or bent and does not drive the head the cable goes from the motor to the head take the clamp bolt out and lift the head off the cutter check the cable
Posted on Jul 30, 2008
  • 36 Answers
SOURCE: grass hog 18v nst2018 trimmer
After reading all of the reviews on Sears.com, it seems these batteries require charging and discharging 3-5 times before they hold a full charge.
All of the reviews mentioned this; they said it lasted 5-10 mins the first few times, but then they suddenly got 30-50 mins per charge after the 3rd to 5th charging.
Posted on Sep 19, 2009
  • 133 Answers
SOURCE: how to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Posted on Apr 21, 2010
Put in replacement spool cutting great as usual went edge the head with spool of line wont turn went back to normal position spool will not spin to cut motor runs spool head not engaging how can I fix
pull the head completely off and make sure that the shaft is not broken, if not then line it back into the head slot and put back together and test it out, Tim
May 29, 2011 | Black & Decker 14" Grass Hog Xp...
I need a new spring to replace the lost one that makes the spool advance. Its a Grass hog that is a few years old. Not battery powdered, but electric. Can yoy tell me where to buy one or what size...
They have upgraded the old string heads (type 1) to a new string head (type 2). They say type 1 is no longer available. Please see part numbers 20 & 21 in this 14" Grass Hog parts breakdown diagram. The new string head is relatively inexpensive. If you don't want to get one, could I suggest you take the old spring (if you have it) and match it up with possibly a new spring at the hardware store. Sometimes you get lucky! Here is the parts diagram for it. Hope this helps!
http://www.ereplacementparts.com/black-and-decker-gh1000-type-grass-hog-trimmeredger-parts-c-4167_9518_9532.html
Oct 30, 2010 | Black & Decker 14" Grass Hog Xp...
What replacement line is used for the BLACK & DECKER Grasshog. 5,063,673 5,620,336 6,443,753 6,443,762
For the cordless Grass Hog, the replacement spool is AF-100. You can purchase these spool heads online or maybe find them at your local hardware store, but they may be hard to find because the Grass Hog is not made any more.
Jul 13, 2010 | Black & Decker 14" Grass Hog Xp...
My grasshog weed trimmer only spins when it is upside down.
It sounds like the rod that runs from the motor to the head, is either loose or it has broken, so when you turn it upside down that causes it to engage itself and turn. You will have to take this apart and make sure that the holding clamps are in place
May 04, 2010 | Black & Decker 14" Grass Hog Xp...
;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
I was trimming and the head stopped turning, motor still going. Is there a repair center around Charlotte,NC???
May have grass or line bound up between moving and non moving parts. If motor is free wheeling, then the plastic driven gear is likely damaged. The part is not consumer available. No one that I have read about has been able to find it.
Apr 03, 2010 | Black & Decker 14" Grass Hog Xp...
B&D grasshog XP motor squeeled and spin rate slowed. repairable?
I just saw your post. Check the area between the housing and the head, along the shaft. Fibrous debris (in my area, this loosely translates into "lilly leaves") gets wound around the shaft, and will slow the universe down to a crawl. The only way to get it loose is to cut it loose, or unwind it.
Best regards, --W/D--
Aug 18, 2009 | Black & Decker 14" Grass Hog Xp...
Black & Decker String Trimmer Cordless 12" 18V Logo
151 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
