Question about Microsoft Xbox 360 Console
My xbox displays a error message E-71 it does not allow my system to boot up. Can this problem be repaired?
  • 767 Answers
Well you may posabiley know the answer to that. The other
questions is it possible to get a durable fix at a reasonable cost?
The answer is a resounding YES. Have a reputable repair
shop Reflow the G.P.U. and then install a hardware up grade
for the seriously lacking " X clamp bracket" . just google
"Conformail Compression Bracket" . And on average you should
get 9+ month of trouble free operation. The cost of the
Reflow is around 50.00-70.00 depending on the condition
of the P.C. board.
If you have any questions , please ask before you rate this tip
Thank you
Posted on Oct 24, 2010
SOURCE:
Error 71 it keeps freezing
from : http://forums.xbox-scene.com/index.php?showtopic=484726
E71:
Dashboard Error - Error within Xam.xex: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
  1. Go to the "system" blade
  2. Select "memory"
  3. Press Y on the HD symbol
  4. Press X,X, Left Bumper, Right Bumper, X,X
  5. A message will appear saying: "Do you want to perform maintenance on your Xbox 360 storage devices?"
  6. Select Yes
Clear Any Failed system updates that cause the console to error.
  1. With the console off, press and hold the sync up button (the small white one)
  2. While holding the sync button press the power button to turn on the console
  3. Continue to hold the sync button until the Console has booted up completely.
  4. During the boot process the console should clear any failed updates, allowing you to use it normally
Jan 05, 2012 | Video Game Consoles & Games
My xbox keeps freezing when I play my games then sometimes I get an E 71 error??? what do i need to do?
E71: Dashboard Error - Error within Xam.xex
Try resetting the console - Clear All Installed Game Updates and Console Cache
  2. Select "memory"
  6. Select Yes
  4. During the boot process the console should clear any failed updates, allowing you to use it normally.
If that doesn't fix it, you'll need to set up a repair with MS.
In the US Customer Support can be reached at 1-800-4-MY-XBOX (1-800-469-9269)
Jun 27, 2011 | Video Game Consoles & Games
Xbox will not load up, has a red light glowing. screen displaying; contact xbox support Error E 79
Do a quick check to see if your Xbox will start up without the hard drive connected. If it does, you'll probably need to replace your hard drive. If you still get the error message, try the following: Clear Any Failed system updates that cause the console to error. 1. With the console off, press and hold the sync up button (the small white one) 2. While holding the sync button press the power button to turn on the console 3. Continue to hold the sync button until the Console has booted up completely. 4. During the boot process the console should clear any failed updates, allowing you to use it normally.
Jun 11, 2011 | Video Game Consoles & Games
Sreen system error e 74
This problem occurs when the Xbox 360 console experiences a hardware failure. To verify that your console is displaying the E74 error message, follow these steps:
  1. Turn off the console.
  2. Turn on the console.
  3. Verify that your console displays the E74 error message.
If you are experiencing this problem, your Xbox 360 console must be repaired..... Microsoft covers repairs for the E74 error for a period of three (3) years from the original purchase date of the console. If you are outside the initial three-year warranty period, you can still receive console repair service from Microsoft for a fee for the E74 error.
https://myservice.xbox.com/en-us/Pages/Welcome.aspx
Jan 01, 2011 | Microsoft Xbox 360 Console
E 74
E74 error appears when you use your Xbox 360 console Article ID : 941377 Last Review : March 10, 2010 Revision : 14.0 On This Page SYMPTOMS Your console displays the following error message in multiple languages on your television screen or monitor: E74. System Error. Contact Xbox Customer Support.If you see a different error message or a code other than E74, your console may be experiencing a different problem. If this is the case, please search the Microsoft Knowledge Base for the error message or for the symptom.
uparrow.gifBack to the top
CAUSE This problem occurs when the Xbox 360 console experiences a hardware failure.
MORE INFORMATION Step 1: Confirm the E74 errorTo verify that your console is displaying the E74 error message, follow these steps: 1. Turn off the console. 2. Turn on the console. 3. Verify that your console displays the E74 error message.
Step 2: Submit a console repair requestIf you are experiencing this problem, you can submit a console-repair request online by using the links in the "Additional support" section.
Additional supportIf your console continues to display the E74 error message, it requires a repair. There are no additional troubleshooting steps. To start the online repair process, click one of the following links: In the United States
http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair)
Outside the United States http://www.xbox.com/support/ (http://www.xbox.com/support/) Note Online console repair service is currently not available in all countries and regions.For more information about how to contact Xbox support directly, please visit the following Web site: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) Microsoft covers repairs for the E74 error for a period of three (3) years from the original purchase date of the console. If you are outside the initial three-year warranty period, you can still receive console repair service from Microsoft for a fee for the E74 error. For more information about this repair process, click the following article number to view the article in the Microsoft Knowledge Base: 969905 (http://support.microsoft.com/kb/969905/ ) About the E74 warranty extension for Xbox 360 consoles
References/Links If one light around the power button on your Xbox 360 console flashes red, there are additional steps that you can try. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/ ) One light flashes red on your Xbox 360 console
Oct 15, 2010 | Microsoft Xbox 360 Console
My xbox is saying error e74
CAUSE This problem occurs when the Xbox 360 console experiences a general hardware failure.uparrow.gifBack to the top
MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request online by using the links in the "Additional support" section. To confirm your console is displaying the E74 error message, follow these steps: 1. Turn off the console. 2. Turn on the console. 3. Verify that your console displays the E74 error message.uparrow.gifBack to the top
Additional supportIf your console continues to display the E74 error message, it requires a repair. For more information about how to start the online repair process, please visit the appropriate Web site: United States Customers
Outside the United States http://www.xbox.com/support/ Note Online console repair service is currently not available in all countries and regions.For more information about how to contact Xbox Customer Support directly, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 10, 2010 | Microsoft Xbox Console
Error 71,what is that?when I load a game it loads,then screen goes black and says error 71
71 is usually cuased by a failed update that was installed or possibly a memory issue. Try these two soloutions and if they do not fix the issue, you have a hardware problem and you will need to send it in to Microsoft.
  2. Select "memory"
  6. Select Yes
Jan 23, 2010 | Microsoft Xbox 360 Console
E 74 error message, right lower quadrant red ring
Additional support loadTOCNode(2, 'moreinformation'); If your console continues to display the E74 error message, it requires a repair. For more information about how to start the online repair process, please visit the appropriate Web site: United States Customers
http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx? redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx? step=repair)
For more information about how to contact Xbox Customer Support directly, please visit the following Microsoft Web site: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Hope it helped.
Nov 22, 2009 | Microsoft Xbox 360 Console
Everytime i switch on it shows errror E74
The E74 error code occurs when the Xbox 360 console experiences a general hardware failure.
Login at the following website to start an online repair support case
(Free repair if console is still under warranty, $99.00 if not)
or contact Xbox support at 1 800 4my xbox
(Free repair if console is still under warranty, $120.00 if not)
Jul 23, 2009 | Microsoft Xbox 360 Console
Error 71 on screen
this error is caused by a bad update. go to the system blade, select memory, press y on the HD symbol, press x,x,Left bumper, right bumper, x, x, a message will appear, select yes
Feb 21, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
47 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
