Question about ASUS K8V-VM (K8V-VM GREEN) Motherboard
I have an ASUS K8V-VM motherboard. I recently upgraded the memory to 2GB of DDR400 (2 1GB sticks) It ran fine for the first 3 or 4 days then started having problems booting. After changing the memory back to the original, it still had the same problem. I ran diagnostics with the new memory and it checked out fine. When I ran the diagnostics on the hard drive it told me that it over temped and it failed the SMART pretest. I got a new hard drive, and ran the test again. It now shows fine. However, whenever it boots or does a reboot, it freezes like it was doing before. I tried F8 to get into the bios and it doesn't open the bios.
  • ASUS Master
  • 27,725 Answers
One bad lead will cause your computer to shut down or continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to your hard drive
hope this helps
Posted on Oct 24, 2010
SOURCE:
THANK YOU ALL FOR YOUR HELP, BUT THE USER GUIDE WAS THE WRONG ONE. I NEED ASUS K8V-VM PLZ. HAVING TROUBLE FINDING ONE..
That motherboard with support 2 x 184 pin 1GB memory sticks. It supports PC3200, PC 2700 or PC 2100. You can mix and match but note that both memory sticks will operate at the slowest stick's speed.
Jun 22, 2013 | ASUS K8V-VM Ultra 1GB DDR PC-2700 Desktop...
What is better? to put four different rams or one single ram of 4gb in p4p800 vm asus motherboard
I would suggest going with a single piece or 2 identical pieces of RAM for expandability purposes. If you want to upgrade later, you will have the option to add more RAM. From a cost standpoint, you might be better off buying 2x 2GB sticks as a single 4GB stick of RAM might well exceed the cost of 2x 2GB sticks.
Best, Hunter
Mar 03, 2011 | ASUS P4P800-VM Motherboard
Motherboard driver download
Click here to visit ASUS Official site and follow these steps: -
1. Select Product - Mother board
2. Select Series - Socket754
3. Select Model -
K8V-VM and click search, it would ask you for operating system
4. Select operating system and download drivers
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 09, 2010 | ASUS K8V-VM Motherboard
I m having asus k8v-vm bt no space for sound card
The Asus K8V-VM motherboard has an intergrated audio chip on the motherboard, Realtek ALC660. You need to enable it in the bios. If you do not have you're manual down load it from Asus; http://www.asus.com/Search.aspx?SearchKey=K8V-VM You'll also need Adobe reader installed to view the manual. Enter the bios menu. Open Advanced. See the top of page
2-21 in the manual. Set, High definition Audio to [Auto] Save and exit the bios. Also check out page 1-19. You can install the driver software from the Asus CD or download it from the Asus link provided above.
Realtek Audio Driver V5.10.0.5211 for Windows 2000/XP/XP 64bit. (WHQL)
Cheers'
Mike
Jan 10, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
I have asus K8V-vm and i installed vista home premium which is working very well but when i try to install any kind of games or any software it do not support it.What should i do!
switch to xp pro sp2..
i guess ur using ram over 1gb..(though it may support upto 2gb ddr1 400/pc3200 fsb probably)!!
replace it with a standby n check..it may b a faulty ram..
make sure ur system clock speed is matching..
if ur using more than 1 ram, both must b of the same frequency..(eg 400fsb+400fsb / pc3200+pc3200 [correct]; 400fsb+333fsb [wrong])..
check if ur hdd is working fine and without any humming or oscillating noise..
also go for a bios update frm: http://support.asus.com/download/download_item.aspx?product=1&model=K8V-VM%20Ultra ....
..if ur not professional, do contact ur system admin/vendor....
Oct 26, 2009 | ASUS K8V-VM Motherboard
Asus k8v-vm wont resume from standby.
get into the bios and change the setting to start from any key save yes and ok -esc
Jul 04, 2017 | ASUS K8V-VM Motherboard
Asus k8v-vm mother board drivers
boot block compatible version ver 003
bad bios checksum, start recovery
is alone window seen in my computer
Dec 26, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Installing extra memory causes freezing + closing down of pc
Check these specs for your board.it will support 2gb but only if its pc2700.anything greater will not boot or become unstable quickly.here are your specs.also i am enclosing an ASUS link for any and all manuals etc. for this board.asus a7n8x-vm motherboard
Specifications www.microsoft.com/Genuine"] --> CPU Socket A for AMD Athlon XP
Thoroughbred/ Barton Core Support Chipset NVIDIA nForce2 IGP
NVIDIA nForce2 MCP Front Side Bus 400/333/266 MHz Memory -Dual Channel Memory Architecture
-Supports up to 2GB of 2700/PC2100 DDR memory
-2 DIMM sockets Expansion Slots AGP8X (1.5V only)
3 x PCI VGA -Integrated GeForce4 MX GPU
-Integrated TV encoder
-NVIDA nVIEW dual-display architecture
-Support DVI (AGP-NV-DVI) and TV out (AV/S) cards Storage/RAID 2 x UltraDMA 133/100 Audio Realtek ALC650 6-channel CODEC
S/PDIF in / out interface LAN Integrated 10/100 Mbps LAN controller + Realtek PHY USB Integrated 6 USB2.0 ports Special Features Power Loss Restart
Support S/PDIF in / out interface
ASUS MyLogo2
ASUS C.O.P. (CPU Overheating Protection)
ASUS EZ Flash Back Panel I/O Ports 1 x Parallel
1 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x VGA
1 x Audio I/O
1 x RJ45
4 x USB 2.0/1.1 BIOS 4 Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI, ASUS EZ Flash, ASUS MyLogo2 Industrial Standard PCI 2.2, USB 2.0 Manageability WfM 2.0,DMI 2.0,WOL by PME,WOR by PME, Chassis Intrusion Support Disc Drivers
ASUS PC Probe
Trend Micro™ PC-cillin 2002 anti-virus software (OEM version)
ASUS LiveUpdate Utility Accessories User's manual
UltraDMA cable
FDD cable
I/O shield Form Factor microATX Form Factor, 9.6"x 9.6"(24.5cm x 24.5cm)RICHARDM69
Dec 15, 2008 | ASUS A7N8X-VM Motherboard
ASUS K8V-VM (K8V-VM GREEN) Motherboard Logo
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
