Question about Leviton 5634 Dual 1 Pole Switch Decora Combo Device
I am trying to install Leviton Decora Combo 3-Way switches (#5641-A). The instructions that are printed on the interior of the package are beyond unhelpful. Can anyone explain to me how to install and wire these switches?? I have a building inspection tomorrow and MUST have these in to pass!
  • 2,100 Answers
Did the lights have the 3 way switch before?? If so, you should be able to follow the map on the package, remember it is totally unlike anything else in the house, I have seen grown electricians cry with 3 way switches in their hands. One of the wires is a jumper, you need 3 wires in each box, one hot , one neutral, one jumper, now depending on how the first guy did it, will determine what route you will take, I can't explain it over the fone here, but you should be able to see it when you know what you are looking at. Remember, one wire jumps, to the other switch, it will be on the same screw at the other end, the hot will be on the same screw at the other end, and the neutral will be on the same screw at the other end, hopefully. Sometimes they terminate the jumper at the light. So you might only have 2 wires on one side. Check it out, i hope this helps.
Posted on Oct 24, 2010
SOURCE:
I have a leviton double switch that i can't get to work. I have 3 white and 3 black in the box
Try the link below for a diagram.
I would think that you have one black feed and two black legs going out, and three common wires that should be wired together with a wire nut. Is this for a ceiling fan with a light? or ?
May 14, 2014 | Leviton 5634 Dual 1 Pole Switch Decora...
Light switch
Try to switch the white with the black wire
Apr 16, 2014 | Leviton 5634 Dual 1 Pole Switch Decora...
Programing instructions
you can look here http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=6124H-I&section=44955&minisite=10251 and click the adobe manual for programming instructions.
May 05, 2012 | Leviton 6124H 24 Hour LCD Programmable...
Hello: I have a Levitron White decora 15 amp combination switch: I need to get a copy of the schematics as someone threw the schematics away... Geesh! Note The MFG part number is the same as the...
Hello.
There is no schematic shown online for that specific product.
Leviton shows a spec sheet on their website but no wiring schematic.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?sitex=10026:22372:US&item=8938
However the spec sheet does show the screw terminals on one side of device that indicate this is ordinary combo switch-outlet.
Open following link for illustration of combo switch-outlet:
http://waterheatertimer.org/images/Combination-switch-outlet-6.jpg
The problem that usually confronts people when they replace light switch with combo is that the combo requires additional neutral wire to power the outlet.
Neutral wires are the white wires twisted together and covered with wire nut that are pushed to back of electric box. Connect a short piece of white wire to the neutrals, and connect that wire to screw on combo device. If your electrical box does not have these neutral wires, you can get the outlet to work by using bare ground wire instead of white neutral, but I would never recommend this action as it violates national electric code and would not pass home inspection and would cause risk to electrician working on that same circuit who was unaware of a code violation.
Jul 23, 2011 | Leviton White Decora Rocker Switch &...
Where can a get information how to install a automatically turn light swicht leviton model occupancy sensor m,odel
What's the problem? You can get instructions at leviton website but also suggest you read competing products manuals to build perspective. These are difficult to install in 3 way wiring situations. In 3-way they only seem to work well when wired to load not line side. In 3 way I suggest you wire in 2. There is a certain way of doing this. I just looked at instructions for Leviton's competition.
Jan 09, 2011 | Leviton R01-PR180-1LI Decora 180 Degree...
Have 3- 13 watt mini spiral bulbs on fixture. When switch in auto mode, lights hum, flicker and not maximum brightness. When switched to on position, lights stop flickering and humming. Full brightness as...
-Replace the compact florescent bulbs with regular incandescent bulbs and see if problem continues.
-Lighting controls are made for different kinds of bulbs.
-Your package should say what the watt rating and type of bulb.
According to the PR180 manual:
-I am looking at the Leviton PR180 occupancy sensor manual, and the PR180 sell-sheet, and these documents say for incandescent and fluorescent (rapid-start magnetic ballast only).
-Compact fluorescent are supposed to have a magnetic ballast.
-The manual does not specifically say it works with 'compact fluorescent'
-The manual does not say there is a minimum amount of wattage either. Some controls will not work correctly if the overall wattage is low. Your overall wattage is 39watts.
Read the product package (if this is a new installation and you have the package)
Try the incandescent bulbs.
If the PR180 is not your product, add a comment with product number and I'll look for information
Nov 06, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
How do i program the LEVITON Decora Timer Light Switch 10/24hrs.
From this website you can download a free instruction sheet in PDF format...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=6216&section=17138
May 12, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Leviton Dimmer Switch wiring and ceiling wiring for new kitchen table light fixture
I recently purchased a Leviton Dimmer switch which has a brown lead. This switch is to replace 1 of 2, 3 way switches that control the ceiling light in my kitchen. My problem is the new dimmer switch has 4 leads including a brown one which has me confused. I have installed and replaced numerous dimmer switches without difficulty. Please help.
Oct 10, 2009 | Leviton Decora Light Dimmer Switch
Leviton 5634 Dual 1 Pole Switch Decora Combo Device Logo
322 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
boomanfoo
Level 1 Expert
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
