Question about Epson Stylus R265 InkJet Photo Printer
Ink system I have just purchased the continous ink sytem for the epson R265 I THINK I know how to install it but the problem I have is taking the top ink cover off in the printer I have looked at the instructionsthat came with the system but I think its just showing how to do it on the 2800 please advise
    Problem Solver:
  • 5 Answers
There is a removable slider on the top of the R265 unfortunately if forced this will break the locking tab here is a detailed fitting instruction diagram for the R265 and other models but it does show you how to install and what you need to remove. hope it helps you i have had mine now for over 12months and i would not be without it.
http://rapidshare.com/files/128648098/Epson_CISS_Fitting_Instructions.rar.html
Posted on Jul 10, 2008
Does not print, just a faint black print, the cartriges are half full.
your printer is a photo printer which consumes considerable amount of inks when printing... you may need to perform a head cleaning process to clear the clogg on your nozzle. this may consume your ink cartridges... i suggest that you convert your printer into a CISS (continous ink supply system) this is more cost effective instead of buying ink per ink as this shows the same output as the regular ones.
check out ebay for people who convert epson system to CISS
note: doing the head cleaning process always takes ink to force the clogg out of the nozzle tube
hope this helps
Aug 07, 2011 | Epson Stylus R265 InkJet Photo Printer
Need to clean waste ink pad on epson r265 printer
You need to remove the Paper support tray, printer cover front cover usb housing and right and left housing then remove the waste ink tray inside the tray you will find about 12 pads that need taking out you can just replace them with new ones or wash and dry them and re-install them the latter is very messy then refitt everything and then you will need the service utility to restet the printer If you need further help email me at drummerboy36uK@yahoo.com or try me on msn messenger using thedrummerboy53@hotmail.com
Feb 08, 2010 | Epson Stylus R265 InkJet Photo Printer
I have an Epson Stylus R265. It is telling me all
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 05, 2010 | Epson Stylus R265 InkJet Photo Printer
Epson r265 keeps printing purple pictures I have installed new cartridges and done a head clean several timesbut i just won't budge
You probably need to purge the yellow ink channel. Use the cleaner found in refill kits and gently force the cleaner through the channel where the yellow ink cartridge attaches.
After cleaning, you will need to "charge" that ink channel either by many cleanings or by forcing the yellow ink into the channel before installing the cartridge.
Nov 03, 2009 | Epson Stylus R265 InkJet Photo Printer
Hi, I have just changed the yellow cartridge on my R265 with proper epson ink cartridge and it is saying that it is incompatible. Can you help please?
Hi If you are using compatable inks try taking the ink cartridge out and put it back in again try this three or four times to see if it will accept it if not try a different cartridge you can sometimes get a duff one The earlier models have a different cartridge than the later models epson altered them and changed the chip
Oct 25, 2009 | Epson Stylus R265 InkJet Photo Printer
2 red lights are flashing on my printer epson R265(END OF LIFE TIME SERVICE)
U can find resetter (SSC Utility or R265 Adjusment) at indoreset.blogspot.com. Reset the waste ink counter.Good luck.
May 29, 2009 | Epson Stylus R265 InkJet Photo Printer
I need an Epson R265 Reset please
I managed to get a resetter program for the Epson R265 from the USA which did the trick!
Dec 28, 2008 | Yahoo YHT-630 System
Epson R265 Ink pad full
I have problem with r265 Epson. I installed new ink cartridge from epson but the printer could not recognize it. I installed SSC Service utilitry, but the programme could not recognize printer at this status. What can I do?
Nov 03, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson R265
Both redlights are flashing, and I need to change the waste ink any one help please
Apr 24, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson r265
download and install latest driver from Epson. Status monitor is in the driver. Check you have monitor ink setting active within driver.
Feb 18, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus R265 InkJet Photo Printer Logo
73 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
