Question about Sigma EF-500 Super for Canon TTL Flash
Hello there. It seems that the Sigma EF-500
Hello there. It seems that the Sigma EF-500 Super Flashgun has the E-TTL functionality for Canon SLRs. I bought it for use on a EOS100 film camera and it seemed to work well, but won't fire while fitted to my EOS7D. Can a EF-500 be used on a Canon EOS7D? Regards John
  • b_mused Dec 02, 2010
    Hello Tri3mast
    Thanks for the reply.
    Yes, the EOS7D has built in features to wirelessly control remote external flashguns. This Sigma unit works quite well as a wireless slave.
    I have used it in tandem with the 420EX, both off the camera, and the 7D will trigger them quite well. The next trick is to fine tune the settings for consistent exposures, as I sometimes get a "white wash" from the flash.
    Regards
    B-mused
  • 747 Answers
John, there is a difference in sync times between film and digital flash. It's taken the third party manufactures a little time to catch up so there is a lot of "film" flash units out there. I'm understanding that the Sigma flash doesn't fire at all which is pretty amazing I would have thought it would fire just not at the correct time. This flash isn't a total loss because it can be used wireless with a slave unit for fill or even a main light triggered from a mini transmitter on the camera hot shoe. Here is a link to an e-Bay auction to see what I'm saying.
http://cgi.ebay.ca/Wireless-Flash-Trigger-Transmitter-Receiver-4-Canon-/230537528202?pt=Camera_Flash_Accessories&hash=item35ad1b838a
I use this type of system for a location shoot, there are no wires and I can set up and balance my lighting to each set with no more dark backgrounds hope this was a help
Posted on Dec 01, 2010
SOURCE:
Need manual for sigma ef-500 dg super minolta version
You may download a copy of the manual from here. It's for the Pentax version of the flash, but I don't see anything in it that's Pentax-specific except for the mention that's it's Pentax-specific.
Apr 02, 2013 | Sigma EF 500 DG ST for Minolta TTL Flash
Sony alpha 350
I have a sigma EF 500 ST flash guns which I bought with nikon F75 some years ago. Would this flash work with canon 500d
raji
May 13, 2010 | Sigma EF-500 ST TTL Flash
Can I use a sigma flash EF 500 with Sony Alpha 350
Yes, if it has a Minolta/Sony mount. The Sigma EF 500 has been producedin different mount, so that the model can fit different cameras from different producers. A Sigma flash for Sony should have SO-ADI written on it.
Apr 25, 2010 | Sigma EF-500 DG for TTL Flash
Sigma EF-500-DG, does not charge and does not become ready
Hello
Thank you for using FixYa for your problem
Always check the batteries first - make sure they have full charge (in the wrong way can discharge them) but if is it still giving the same fault, your flash is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Sigma EF-500 DG Super for Canon EOS TTL...
1. Sigma EF-500 DG ST 2. Quantaray 7500A
A: For Sigma issue:
The Sigma EF-500 flashes have very small chromed contacts for the batteries. Even though they may not look corroded, they may not power up or conduct enough power to fully cycle up. Use a polishing tip in a dremel or an ink eraser tip to clean the internal wire contacts and the flat contacts on the door. I use dielectric grease on a q-tip to apply a coat to all contacts and cleaned battery terminals to minimise future issues.
Nov 20, 2008 | Sigma EF-500 DG for TTL Flash
Bulb replacement for Sigma EF-500 DG Super
So I had fixed the problem this morning, since the warranty has expired, I opened up the flash to take a peak on the inner workings, and found that a wire had come loose, got out the soldering gun and repaired the connection and all is good.
Sep 28, 2008 | Sigma EF-500 DG Super for Canon EOS TTL...
Sigma Flash EF-500 DG SUPER
I use one of my cams with a sigma 500 DG-ST in a nightclub
ive done 3 of the hot shoe connectors in the last year
look up sigma's website and find the contact info
give them a call and they should after some arguing ship you out the parts
every time i have ordered parts they try and get me to send it in for repair even though by the time i am ordering the parts the flashgun is already in bits & i tell them this they keep telling me how dificult it is to do...
for the canon fittment do the following
at the base of the flash remove the 4 screws
this removes the bottom section
unclip the wireing harness
there are 2 screws securing a small metal plate remove them
now there are 4 screws securing the small PCB, remove them, you can now take out the boot from the bottom be careful as the pins and the springs will want to come out
pay atention to the locking pin and how its orientated
swap over the broken boot with the replacement then retrace your steps to get it back together
Sep 24, 2008 | Sigma EF-500 DG for TTL Flash
Replacement shoe for Sigma EF-500
send it to a sigma agent thay can replace the broken part
Nov 02, 2007 | Sigma EF-500 DG for TTL Flash
Problem with underexposed pictures
I've got the same problem with my new ef 500 dg super and my ef 530 dg super. It occurs on all nikon camera's I could get.
D70, D80 and Fuji S5 Pro. I don't have this problem with an old (4 years) sigma ef 500 dg super.
I will try to contact Sigma for this problem.
Nov 01, 2007 | Sigma EF-500 DG for TTL Flash
Sigma EF-500 Super for Canon TTL Flash Logo
337 people viewed this question
Top Sigma Cameras Experts
Doberman
Poul Brinchs Larsen
Inky Fingers
Inky Fingers
Are you a Sigma Camera Expert? Answer questions, earn points and help others
