Question about Logitech Cordless Mouse
When I put the USB drive into the computer it doesn't recognize it being plugged up and the light doesn't come on. Is there a installation cd to go with it.
  • 707 Answers
Did you put batteries in the mouse?
You can check here for other solutions:
http://www.logitech.com/support-downloads
Good luck
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Posted on Oct 24, 2010
SOURCE:
Usb device not recognized
Usually this means the computer saw that something was plugged into the USB port, but it doesn't know what device it is. It will require device drivers from NEC to recognize the drive. If your drive came with a driver CD, install these drivers. If the drive was working before, but now it's not, reinstall the drivers. If this does not fix the problem, then most likely either your drive is bad, or else your registry has become corrupted. Try another USB drive and see if your USB port is working, that is another possibility.
Oct 01, 2013 | NEC Computers & Internet
A blue and red flashing light and won't connect to computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
How to connect to a pc
Install the software first, then connect the usb and power cables, then turn on the unit.
Here is a section of the installation manual :
Software Installation
1. Do not connect this device to computer yet.
2. Insert the utility CD into computer's optical drive, and then the installation window should
automatically appear on the screen. If the installation window doesn't show up, go to "My
Computer" and browse the CD. By executing the "index.html" file, the installation window
will appear.
3. Click on "Private Folder Manager"/ "Playlist Manager", and then follow the on screen
instructions for installation.
4. After the software had been successfully installed, see [Connecting to USB] for cable
connection.
Connecting to USB
1. Connect the plug of AC adapter to the connector marked "DC IN", plug the other end into
an electric outlet.
2. Connect the USB cable to the USB connector. Then connect the other plug to computer's
USB port.
3. Press the Power switch and then the blue LED will light up.
4. The computer will detect this device and you can start accessing the drive.
Jul 13, 2011 | Argosy HV372T Mobile Video HDD Media...
Is it possible to fix a notebook that has a message with load needed dlls for kernel. It's for a notebook. I've looked it up and it tells me to put the cd in and restore it. I have a notebook and...
Hi.
Yes it is possible to fix the netbook. All you need to do is reinstall the operating system. You will have to get hold of an external DVD/CD drive or install Windows through a USB drive.
With a DVD/CD drive all you need is the XP installation CD. Connect the drive to the power outlet and then plug the USB lead to the computer. turn the netbook on and hit the F12 key or the key it tells you for "Boot Options". Select the "USB CD-ROM" device and follow the on-screen instructions to reinstall the operating system.
If you haven't got an XP installation CD then you'll have to purchase one.
You can also install XP from a USB flash drive. Click on the link I have provided below for an in-depth explanation for how to install Windows XP from a USB flash drive>>>
http://komku.blogspot.com/2008/11/install-windows-xp-using-usb-flash-disk.html
If you decide to install using the USB flash drive then to get the system to boot from the USB flash drive just follow the same instructions for the DVD/CD drive.
Hope this helps and please post back if there is anything else.
Regards.
May 23, 2011 | Computers & Internet
I believe my hard drive is locked. When I try to plug in my hard drive to someone else's computer I cannot drag anything into it. Thanks for the help!
For some hard drives, you need to have the correct driver installed on the computer in order to use it. Especially if it is a USB device. If not try a different usb port. The port your using might not be working properly. If that doesn't work... turn off the computer and plug the hard drive in, then turn the computer on. The computer may need to recognize it on boot up.
May 12, 2011 | ClickFree (225-1001-100) 250 GB USB Hard...
CD driver do not read any file
Does it recognize any cd you put in the drive or is it only one cd it doesn't recognize?
Please check if the cd drive is recognized by your computer:
Click Start go to My Computer (XP) / Computer (Vista/Win 7)
and check if you can see the drive. (if it's not there you may have to reseat the drive to make sure that the cables connecting it to motherboard are tight)
check the status in the Device Manager:
On your Keyboard press and hold the Windows Key then press the letter R
once the Run box comes up type in devmgmt.msc and the device manager should appear.
On the device manager look for the cd / dvd drive see wether it has an exclamation point a red x mark or a down arrow or it looks normal.
if it has a yellow exclamation point press and hold the windows logo then the letter R again and type regedit:
On regedit go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and the delete the upper and lower filters. Close Regedit and restart the computer.
if it has a red x mark right click on the cd drive in the drive in the device manager and the choose uninstall and restart the computer.
If it has a down arrow right click on the drive and click Enable.
If the above steps doesn't work or if it doesn't recognize all types of media you put in it, that might mean that your cd drive is busted and it needs to be replaced.
Hope you find this helpful!
Apr 30, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
I got a Belkin wireless usb adapter (F7D4101) and when I put the CD in my driver, the CD is not recognized what so ever in the D drive. However, the USB adapter is recognized when I plug it in, but when it...
If the cd does not work on your computer, you might want to download your softwares and driver from this LINK as an alternative.
I hope this works for you. Kindly comment for further assistance. Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Feb 14, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
I want to install driver of jf v30/1gb on my system
I formats the pen drive but due to the electricity cut off, format doesn't complete and pen drive doesn't recognize in computer
Dec 27, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Logitech Cordless Mouse Logo
24 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
