Question about Motorola Mobility RAZR V3
Error code receive text message with error code each time phone is turned on. "invalid 10 digit number" tried different sim card..master clear and reset...nothing works unlocked razor phone
    Brigadier General:
  • 7,752 Answers
Check your msg center to see if your number is correct
Posted on Jun 14, 2008
My lg versa isnt sending text msgs. every time i try, it says it failed then it tries again then says message not sent. invalid destination. i have the right number and ive turned it off a bunch of times...
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Jan 26, 2011 | LG VX9600 Cell Phone
My text messages wont send, keeps saying system error
I suspect it's related to your sim card (network), not your samsung cell phone. In most cases, regarding text messages, the problem is from the Service Operator. Have you tried the sim card on another phone? If not, remove the sim card, insert it on another phone and try sending a message from another mobile to you number, or you can do it in vise versa by inserting another sim card on your mobile.
If you can't receive text messages even it's inserted on another handset, then you need to call the customer care of your Network Operator and tell them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think it's very much important in your case, well, if you wanna try, just check the text message settings and verify that the message center number (which is currently in use) is the same number which is on another phone with the same network (the other sim should be of the same network in your area). If it's different, make the changes and save the settings. Also disable the "Receive Via" or similar settings.. (I can't recollect the exact settings as i don't have the same model with me, please excuse me for this.).
If the same sim card doesn't receive text messages using another handset, don't bother to change the settings or to make any changes with it, first call the customer care and verify from them, you may make mistakes instead of fixing it.
Also itmight be caused by VIRUS,
You will need to format to restore back phone.
Take care.
Sep 14, 2010 | Cell Phones
Text Error 1121611611
I have an unlocked T-Mobile Dash which I am using with AT&T sim card. I had a similar problem - whenever I booted the phone up, I was getting this sms (text) message, until I figured out what it was. The phone at bootup was sending a T-Mobile internal message to invoke the Favorite 5 list refresh, and it was a reply from AT&T network which didn't understand this message.
To fix it I simply removed this shortcut: \Windows\StartUp\My5MsgCenter.
Jan 15, 2009 | LG Vu CU920 Cellular Phone
Motorola rokr e8 error message
not even a MASTER RESET will resolve this issue most of the time. the only way to fix it is to perform a MASTER CLEAR. Before doing a master clear, make sure you save all contacts to your sim card and images, videos, etc to your memory card.
Nov 18, 2008 | Motorola Mobility ROKR E8 Cellular Phone
In order to send a text message on the iPhone, you must have the entire 10-digit phone number in your phonebook. For example. If you are trying to send a text message to the phone number 555-1234, you must also enter the area code. If the area code it 412, you must put in 4125551234 for the phone number.
Hope this helps!!
Nov 14, 2008 | Apple iPhone Smartphone
MOTORIZR Z3 - Message Memory Issue
One of my few complaints about my Z3 is the low message capacity. I have a 2gb sd card in there...why can't I store more than 500 texts?
But...500 is a lot more than 10, there's definitely a problem here.
I know there's a way to change the default storage location, although I'm not sure it will change the location of texts or not. Here's how to do it:
Go to the main menu and select "Settings". Scroll down to "Phone Status" and select it. Then select "Download Location" and finally, select the memory card.
Now...What concerns me the most is the 4Tb message flood O_o
Aug 27, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Outbound Text Message
It's a operator message. Your SIM card need to send a message to the operator to inform something about your phone (like you are using a new phone) but the receiver don't recognize for what the message is. Your sim card will keep sending the message until it receives a valid response.
Try to change the SIM card and see what happens. If the problem appears only with one card, you may ask your carrier company to change it.
May 05, 2008 | Motorola Mobility RAZR V3
Unlock code
SIM Cards and Unlocking your Phone What is a SIM?
Subscriber Identity Module (SIM): A smart card containing the telephone number of the customer, encoded network identification details such as: Call Forwarding, Caller ID, etc., the PIN, and other user data such as the phone book. T-Mobile customers can move their SIM card from any T-Mobile branded phone to any other T-Mobile branded phone without the need to contact Customer Service to activate the new phone. Your rate plan and phone number will follow your SIM to the new phone.
SIM Error Messages:
  • Invalid SIM: This error means that the SIM you have inserted into your phone is either inactive or is not compatible with our service. You may purchase a new SIM card from a T-Mobile retail location. Locate a T-Mobile retail store near you.
  • Insert SIM: Your SIM is either not inserted in your phone or is inserted improperly. Please remove and re-insert your SIM card. If you continue to receive this error message, your SIM card or phone may be defective. You may take your phone and SIM to a T-Mobile retail store for further assistance and a free SIM card replacement if necessary. Locate a T-Mobile retail store near you.
  • Unregistered SIM: This error may occur if your SIM card is not fully activated or if the SIM card registered to your account is different than the SIM you have in your phone. For assistance with this issue, please contact Customer Service.
  • SIM Not Ready: This error occurs when you have just powered your phone and is due to the phone not being fully initialized. Please wait a few moments before accessing your phonebook or placing a call.
  • OTA OK: This message is displayed when your phone receives a network update, phonebook download, or an Over-The-Air t-zones or Picture Messaging configuration. NOTE: These messages are free of charge and will not be billed to your account or pulled from any text message bucket.
  • Enter PUK: These errors can occur if you have entered your SIM PIN three times incorrectly. If you receive this error message, please contact Customer Service for a PIN Unblocking Key (PUK) to restore access to your phone.
  • Check card, Card Blocked See Supplier, Blocked, SIM Blocked, or Contact Card/Service Provider: These errors may occur if you have entered your PUK ten times incorrectly. If these errors display your SIM is unusable and you will need to purchase a new SIM card. You may purchase a new SIM card from a T-Mobile retail location. Locate a T-Mobile retail store near you.
SIM PIN:
A SIM PIN can be used to prevent access to your phone. When enabled, your phone will prompt you for the SIM PIN when the phone is powered on. Entering the wrong PIN will prevent you from making or receiving calls. SIM PINs are different from a Security Code that your phone may use to secure other phone functions. Please check your phone’s manual for further security details.
T-Mobile SIM PIN numbers are set to default values before purchase. If you change your SIM PIN, it is recommended that you keep record of the new PIN in a safe location. T-Mobile cannot retrieve a lost or forgotten SIM PINs.
  • SIM PIN1: 1234
  • SIM PIN2: 5678 (Only available on select phones)
SIM Unlock:
T-Mobile branded phones operating on the T-Mobile network may only use T-Mobile SIM cards. To use a T-Mobile branded phone on another wireless carrier's network with a non-T-Mobile SIM card, you must first request a "SIM Unlock" code from T-Mobile. Conversely, if you have a phone from another North American wireless carrier, you may need to request a "SIM Unlock" code from that carrier before being able to use a T-Mobile SIM card on the T-Mobile network.
SIM Unlock Requests:
T-Mobile customers must meet the following eligibility requirements before contacting Customer Service to request your SIM Unlock code.
The following restrictions apply to all account types:
  • T-Mobile can provide SIM Unlock Codes only for handsets sold by T-Mobile USA, with the exception of Danger Sidekick devices. T-Mobile can obtain SIM Unlock Codes for companies acquired by t-Mobile USA (VoiceStream, Aerial, Omnipoint, SOL, Digiph, PCS One, and Powertel).
  • SIM Unlock Codes will only be provided after your account has been active for 90 days. Only one unlock code may be provided per customer every 90 days.
  • No SIM Unlock Codes will be provided within the 14-Day Buyer's Remorse period. Customers who purchase phones in CA California or via Amazon.com are granted a 30-Day Buyer's Remorse Period.
  • SIM Unlock Codes are not always available from the Manufacturer. However, T-Mobile will make a dedicated effort to obtain the SIM Unlock code. Note: Other restrictions may apply depending on account type.
Goodluck
Jan 10, 2008 | T-Mobile Wing™ Smartphone
Phone keeps sending message
see if the message is in the drafts folder or the sent items if so delete phone will stop sending
Jan 09, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Unlock
i want use it in egypt
Dec 12, 2007 | T-Mobile Wing™ Smartphone
Motorola Mobility RAZR V3 Logo
83 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
