Question about ViewSonic A90f+ 19" CRT Monitor
Viewsonic A90f Clicking off and on after the computer is shut down and monitor goes into sleep mode (green LED turns to yellow). The monitor then turns itself on then the monitor times out and goes back into sleep. This occurs continuously, when it does happen. Occasionally, the monitor shuts down with no issue. Otherwise the monitor functions properly.
SOURCE:
SOURCE: ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Posted on Jul 26, 2007
  • 1684 Answers
SOURCE: ViewSonic VX900 was working fine. I was in the
The power board in your monitor was damaged when the power was interrupted. We can do the repair for you if you are interested. The repair charge runs $35 + return shipping.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Posted on Sep 18, 2009
budmrtn
  • 11361 Answers
SOURCE: Viewsonic VA912b. Monitor will only turn on for a
Bad caps in the power supply, common problems. See examples here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20V912B/
Posted on Jan 07, 2010
SOURCE: ViewSonic Monitor has trouble to wake up after been shut down.?
i have the same problem, my viewsonic lcd is also 2 years old, hmmm...then maybe "the" 2 years do something to them since everyone else exp the same prob after 2 yrs.
but, i find a "not so smart" solution, my lcd will turn back on whenever i unplug the power cable and then plug it back in, (won't turn on if u only press the power button)
so what i did was bought an electric switch (on-off) in the edge of my lcd's power cable, so whenever it goes blank, i can easily and quickly cut the electricity without having to bother unplugging and plug back the power cable.
hope it works for u guys
Posted on Jul 21, 2010
budmrtn
  • 11361 Answers
SOURCE: I have a viewsonic monitor model # VX2245wm. It
It does the same when using it with another PC?
Otherwise it may have bad caps as shown in my pictures here, very common problem.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 31, 2011
Testimonial: "Great helps alot"
Viewsonic v1930wm
Sounds like the unit needs repair.
Jun 23, 2014 | ViewSonic VX924 19" LCD Monitor
My screen is saying burn in and keep switching colours all the time.(white,red,green,blue.
You may need to send in unit for service because your unit is unable to go to sleep mode when the signal cable is disconnected or the PC is turned off. Please call ViewSonic Customer Care for support.
Although this will not hurt the monitor, you just need to apply an active video signal to get a display correctly. However, it will not work as expected to go into sleep mode. You'll need to call ViewSonic Customer Care to get this taken care of.
May 09, 2014 | ViewSonic VA721 17" LCD Monitor
VA503b goes into sleep mode
Go to power options in your control center. Click on set when to shut down display and set what time. You can also select never.
murf427
Aug 29, 2012 | ViewSonic VA503b (Black) 15 inch LCD...
A90f dark dark screen
Use brighten controls on monitor to lighten
Dec 22, 2009 | ViewSonic A90f+ 19" CRT Monitor
My ViewsonicVP930b Monitor Suddenly Turns Off
This is a classic VP930 problem.
It is caused by bad capacitors in the power supply circuit.
Open the monitor, and look at the power board. There are six capacitors. Replace the 220uF @ 25V and the 1000uF @ 16V capacitors. I would recommend replacing them with 35V and 25V capacitors respectively.
If the serial number on your monitor starts with Q8H you could also have a bad IC on the main board. Q8 on the main board is an FET in an IC package. If this problem persists solder a wire from the right side to the left side. There is one pin that turns the IC on and off. All the other pins (per side) are soldered together. Do not solder the pin on the left side that is by itself. Just leave it. Solder ALL the other pins on the left to ALL the other pins on the right.
Remember, do this ONLY if the problem persists after replacing the capacitors AND if your serial number starts with Q8H.
Apr 20, 2009 | ViewSonic VP930b 19" LCD Monitor
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Dec 06, 2007 | ViewSonic G90fb 19" CRT Monitor
Repair manual
Problem solved! The main power thingy (the thing with the big red wire coming out of it) was all black and dusty. There was 'soot' all over the whole insides of the monitor. I concluded that this monitor should be laid to rest, and a new flat-screen monitor erected in its place.
Nov 18, 2007 | ViewSonic G220f (Beige) 21" CRT Monitor
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
ViewSonic A90f+ 19" CRT Monitor Logo
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
