Question about D-Link AirPlus DI-524 Wireless Router
I have a DL 524UP wireless router connected to Thomson speedtouch modem and has been working beautifully for months. AAPT upgraded my internet package and since then I have had no end of connection trouble. AAPT techs have done some backend resetting and connection is establsihed 1 time only. When I try to reconnect for a second session, no connection. I have had to bypass wireless router and just use modem and pc to access internet. PLEASE HELP!!!!
  • Abhishek Ray
    Abhishek Ray Oct 30, 2010
    Are you using any wireless security ?
    What error are you getting when you are attempting the second session ?
Some internet service providers want to charge a fee for each computer you connect to the internet through them, So they setup DHCP to give out only as many local IP addresses as you pay them for. That's sort of like the water company charging you a fee for each faucet in your house...
Assuming that's the problem...
One way to resolve this, is to connect your wireless router's WAN port the ISP's modem, and configure DHCP in your router to supply as many IP addresses as you need to the wireless and the 4 LAN ports.
In case you can't find your router manual, here's a link:
http://static.fixya.com/Manuals/D/D-Link/_D524DWLG510_E6A38A81BDB9E5559BC01452A833ECE5.pdf
Page 9 has the diagram you need.
I would advise you to buy a newer wireless router, because this one only does WEP encryption, and WEP was cracked some time ago. I you really want to use it, Please be sure to enable the WEP security, and select 128 bits. This router has it disabled by default! (See page 13)
Posted on Oct 24, 2010
6ya staff
SOURCE:
Where is the WPS Button on my Thomson Speedtouch Router
Does the speedtouch 585v6 router have WPS and if so where is the ...
www.askmefast.com > Computers & Internet > Computer Networking > Router
  1. Cached
  2. Similar
Jump to The WPS button is located either at the back or top of your router.If ... - source: Trying to connect my wireless printer with the router at my new ... Router thomson speedtouch tasto wps ... Wps button speedtouch 585.
IS THERE A WPS BUTTON ON A SPEEDTOUCH ROUTER - Fixya
www.fixya.com/support/t20444391-wps_button_speedtouch_router
  1. Cached
Oct 1, 2013 - Question about Thomson Speedtouch St585 V6 Sl Wireless Modem ... do i find my password for my wireless speedtouch 585v6 router? my ...
Page 17 of the manual
https://www.cosmote.gr/fixed/documents/10280/652016/TG585_SetupUserGuide_en_v8.pdf/0878a24f-0922-408c-bd51-fff55a07f53a
Feb 02, 2017 | Thomson Computers & Internet
Barq wireless
CALL THE COMPANY OF THE ROUTER OR THE PROVIDER OF YOUR INTERNET
Jan 31, 2014 | Thomson Be Broadband TG585 v7 SpeedTouch...
I was given a linksys wireless-g model wrk54g router but it didn't come with an installation disk. I have a Thomson speedtouch modem ST530 V6. Right now I am hooked up thru ethernet and getting internet...
was the router used by previous users? or did you buy it? if it was used then it was probably configured for different ISP. You don't need any CD. Just connect to the router via your browser (probably http://192.168.1.1) and adjust settings in WAN section.
Mar 15, 2009 | Linksys Wireless-G Broadband Router
Wireless router problem help fast plz
connected the CST-5 in the following manner.
1). one cable from speedtouch LAN port to sparklan WAN port
2). one cable from sparklan LAN port to the computer network port.
3). disable the DHCP from the parklan (consult your users manual how to do that).
4). restart all of the equipment in the following order. (This is important)
speedtouch, sparklan, computer, laptop.
do not rate the answer till you have the whole thing figure out.
Jan 13, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
I can't get my wireless d-link router working
To access the configuration page for your router, try 192.168.7.1 instead of the 192.168.0.1. If that doesn't work try and go to the manufacturers website and see if you can find the correct address. These must be default numbers as they are similar to others I've seen. In the prompt for username and password, leave user name blank and type admin into the password box.You may need to reconfigure but I would see if there is free Live Chat support available from the manufacturers website for that. Try uninstalling and reinstalling the router program/soft ware that came with the router .Hope this helps
Matt
Nov 17, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Speedtouch Wireless Router
delete the wireless profile and recreate with correct wireless key. try to diable the wireless adapter and enable it again
Nov 05, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Belkin (F5D7633-4) Wireless Router and SpeedTouch 360
I have solved this issues. I simply had to change the VPI/VCI values which i have obtained from my ISP. These value differ from one ISP to another.
Thanks for all the people tried to help me!
Mar 02, 2008 | Belkin (F5D7633UK4A) Wireless Router
SPEEDTOUCH 576 WIRELESS MODEM driver
HERE is the manufacturer main link to download driver.
page also has manual on installing it and config modem properties.
http://www.thomson-broadband.co.uk/codepages/content3.asp?c=7&ProductID=511
Oct 16, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
D-Link AirPlus DI-524 Wireless Router Logo
313 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
