I have a white / negative picture on my 32" Dynex tv. Do you think I have a bad T-Con board? Board is a 320WF01C any idea what may go bad on this board if its the problem? thanks!
  • 11,361 Answers
It does sounds lkie the symptom of bad T-CON board, you can try cooling it with electronic freeze spray for troubleshotting, more likely to have bad IC, most repair I do is due to shorted out DC filter caps such as the one in INSIGNIA/DYNES NS-LCD37HD (backlight is on but no picture due to bad T-CON board):
http://s807.photobucket.com/albums/yy352/budm/Insignia%20NS-LCD37HD-09/
I spent many hours to locate the shorted out surface mounted caps it was time consuming becuase they are in parallel, but Iwas able to find it since I do not want to spend $80 for a used board and I have nothing to lose.
http://www.shopjimmy.com/catalogsearch/result/?q=320WF01C
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Oct 24, 2010
SOURCE:
My Dynex TV model # DX46L263A12 when I turn the TV on for a few seconds the picture is fine, then the screen turns black but I have audio. Can I fix it?
It think it might be a fault on the T-Con board. Could be a bad soldering joint or bad connection. But could be something faulty on the board itself.
Jul 06, 2018 | Dynex Televison & Video
I have a Dynex 32 LCD that I can only see the top half of the picture, the bottom half/40% looks like rainbow lines. What are the possible problems and how do I fix it.
Unfortunately what you have is a fried screen. Toss it at the city dump and get a new TV. Wallmart has 36 and 45 inch TV's for under 300 dollars
Good luck
Nov 29, 2014 | Dynex DX-LCD32-09 LCD TV
The color of the picture is white
The LCD Panel failed. There is no easy fix but try to get the T-Con board to fix the issue. However, this part is usually only available with the whole LCD Panel. This is usually the most expensive part in the TV and the whole TV needs to be taken apart to replace the panel.
Might be economically viable if you can find a place that carry's the T-con but Dynex parts are usually hard to find. The LCD Panel part alone will exceed the cost of the TV.
Dec 28, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I bouth the dynex 32" but six months into use I
Either a lose LVDS cable going to the t-con board or a bad t-con board.If it's still under warranty I would take it back for service.
Dec 01, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
My tv comes on but only show half a picture why is that
You have bad T-CON board and possibly the main logic board that drives the T-CON board. Try cooling the T-CON board with fan blowing on it to see if the problem will go away.
Jun 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
TV worked fine one night, next day screen is white.
Might be economically viable if you can find a place that carrys the T-con but Dynex parts are usually hard to find. The LCD Panel part alone will exceed the cost of the TV.
Oct 07, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Can not find board
The only place you will find that board is in China. The best I could make out is the price is 280.00. You will have to google the number and select a company, but you will have to translate the page to Chinese.
Apr 24, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
Ekse
