I have an advent T9404. I need to open the case to add RAM. I have removed the two obvious screws that hold the side panel, but the side panel will not move. I don't want to force it. Is there another fixing point that need to be released?
  • Anonymous Aug 22, 2008
    i have the same problem...
  • 3 Answers
Remove 2 screws from right rear of case, then slide the side of the case backwards. The panel is a tight fit and may require firm pressure to remove. There is no other screw or fixing point.
Posted on Sep 12, 2008
Removing LCD from Advent 9112 laptop
  • first remove battery case
  • then open all the screws from back side you ca see.
  • then open the front panel of power on key
  • then open keyboard screws and remove the keyboard carefully.
  • then you'll find the simple socket just remove from mother board of your laptop.
  • then open the screw of your lcd from the bending arm.
  • and replace it if you want
I hope you understood ! Thank you for give me chance to help you!!
please give me your ratings!
Feb 24, 2011 | Computers & Internet
Need to change heater coil need a diagram to do so
  1. Drain the coolant. Refer to Draining and Filling Cooling System .
  2. Remove the instrument panel storage compartment.
  3. Disconnect the electrical connectors, as necessary.
  4. Remove the center floor air distribution duct.
  5. Remove the hinge pillar trim panels.
  6. Remove the blower motor cover.
  7. Remove the blower motor.
  8. Remove the steering column.
  9. Roll back the instrument panel. Refer to IP Carrier Replacement in Instrument Panel, Gauges and Console.
  10. Remove the coolant recovery reservoir.
  11. Remove the heater hoses.
  12. While holding the heater case to the cowl, remove the screw on the interior side of the cowl, near the evaporator pipe, if equipped.
    1. On the engine side of the cowl, remove the 4 screws that hold the heater case to the cowl.
    2. On the engine side of the cowl, remove the 2 nuts that hold the heater case to the cowl.
    3. Remove the heater case. Ask an assistant for help, if necessary.
    4. Remove the 7 screws that hold the heater cover to the heater case.
    5. Remove the heater cover.
    6. Remove the heater core from the retainer.
    7. Installing
      1. Install the heater core into the retainer.
      2. Install the 7 screws that hold the heater cover to the heater case. Replace the seals.
      3. Install the heater cover. Verify that the heater cover is properly sealed.
      4. Install the heater case. If necessary, ask an assistant for help.
      5. On the engine side of the cowl, install the nuts that hold the heater case to the cowl.
      6. On the engine side of the cowl, install the 4 screws that hold the heater case to the cowl.
        1. On the interior side of the cowl, install the screw.
        NOTE : Refer to Fastener Notice in Cautions and Notices.
        1. Tighten the following fasteners:
        Tighten
        • Tighten the screws on the engine side of the cowl to 1.9 N.m (17 lb in) .
        • Tighten the two nuts to 2.8 N.m (25 lb in) .
        • Tighten the screw on the interior side of the cowl to 11 N.m (97 lb in) .
        1. Install the heater hoses.
        2. Install the coolant recovery reservoir.
        3. Roll forward the instrument panel. Refer to IP Carrier Replacement in Instrument Panel, Gauges and Console.
        4. Install the steering column.
        5. Install the blower motor.
        6. Install the blower motor cover.
        7. Install the hinge pillar trim panels.
        8. Install the center floor air distribution duct.
        9. Connect the electrical connectors, as necessary.
        10. Install the instrument panel storage compartment.
        11. Add the engine coolant. Refer to Draining and Filling Cooling System
        12. Inspect the system for leaks.
Dec 15, 2010 | 1999 Chevrolet Silverado 1500
How identify panel to remove hard drive
Turn the computer off.
Disconnect the AC power.
Flip it over.
Remove the battery.
Look at the screws holding various "cover-panels" on the bottom (and side) of the case.
Take a small screwdriver, and remove the screws for one panel.
Gently remove the panel.
If you've opened the wrong panel, you'll see either the RAM slots, or the wireless adapter.
On some ThinkPads, removing a few screws allows the disk-drive to "slide" out, rather than being "behind" a panel.
Sep 22, 2010 | IBM ThinkPad T30 2366 Notebook
How do i get the top off to replace a belt.
You don't need to remove the top.
Open the door, find 2 screws holding the door hinges, remove screws; remove the screws on the opposite side of the door opening from the hinges. With the door open or removed, pull the front panel forward. the top of the front panel will separate from the case and you'll be able to remove it lifting it off the bottom. You'll see several screws with hex heads on each side of the case, which were behind the front panel. Those hold the top and support for the drum. Remove serws. Enjoy! ;)))
Jul 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I need to replace dvd writer in my advent SE 2102 desktop pc but can't get it in. Think I need to remove faceplate to put it in from the front but I don't know what to do without damaging casing?
check to see if there are any external screws ie for side panels removal if so remove side panels then (remove cables that are connected to drive then remove screws holding in drive then simply slide drive out put in new drive and reverse the process). if no external screws put hand underneath front of computer there should be a gap carefully pull panel away, will be quite stiff then do as above in brackets.
hope this helps
Jun 19, 2010 | Computers & Internet
Hi i have a laptop advent 8109 i need to open it
Remove panel at the back, remove keyboard from prongs at the top, remove HDD, remove screws holding down the laptop, remove heatsink, remove fan, remove ODD connector, lift out motherboard at an angle. Its really something that needs to be shown, but thats the order in which you need to do it. If you can figure out the "in-betweens", you will be on your way to a cheap repair!
Jun 18, 2010 | Advent Netbook
How can I open my PC so I can add RAM?
Hello
Welcome to FixYa
I hope Following will Help you
  • Shut off the computer and unplug all of the cables connected to the computer tower. Press the power button to discharge any residual electricity. Touch the case to ground yourself. Unscrew the side panel (attached by two screws on the back-right of the tower), then slide it back and lift it off.
  • Locate the four consecutive large, narrow ports (matching the length of the 256MB RAM modules) and push back the clips on the ends of each empty port. One port will already have a stick of RAM installed. Leave that port alone. Align the RAM modules with the ports so that the notch in the RAM fits into the groove in the ports. Push the modules into each port until the clips snap into the top notch on each side of the modules.
  • Slide the side panel of the case back onto the computer tower and screw it back into place. Reconnect all of the cables.
  • Press the power button to turn the computer back on. Watch the screen for a prompt to confirm that the amount of system memory has changed. If prompted, press "F1." Allow the computer to boot up and confirm that the computer is functioning properly.
If this Helped you-Vote for ME...I like to Know feedback too...Thanks for Contacting FixYa...
Jun 16, 2010 | Acer Aspireā„¢ T180 PC Desktop
I need to replace the ram how do i open the case
The left side panel will need to be removed. Lay the computer down on it's right side side at take off the two screws on the back holding the left side panel. Some cases I've seen may just have a switch or something similar. Once you've done this slide the panel towards the back pull it off. The panel will not slide off, it'll move about an inch backwards at which point you will vertically remove the panel. Don't forget to ground yourself before touching any of the components.
Feb 27, 2010 | Compaq iPAQ Legacy-Light PC Desktop
Cant open the case to my HP pavilion 700
First, turn off the PC, remove the power cord from the back of the PC to remove the 115 volts then push the power button for a second or two so the capacitors will discharge. This is important because the residual charge can cause Motherboard damage especially when changing the RAM. You should follow this process ANYTIME you enter the PC case to make changes, etc.
To remove the side panel on a Pavilion 700x series:
Only one side panel allows access to the inside of the Pavilion case, the left side if looking from the front of the PC. The left side panel has knurled thumbscrews, not machine screws. Loosen the thumbscrews, they are designed to stay attached to the side panel, place your hand on the middle of the side panel and with inward force push the panel towards the back. The panel will slide and inch or two and you can pull it free. This proccess is easier if the PC is unplugged (push the power button on the front of the PC after pulling the power cord to dischard the capacitors) and the right side of the PC laying on the floor. This allows easy access to the left panel and allows light to enter the case from above to change/add the RAM you want to install.
Apex44
Mar 03, 2009 | HP Pavilion (PN153AAR) PC Desktop
Need to remove case of hotpoint wma 63
The drum comes out through the front on this one.Take off kick plate and remove screws holding front panel to frame. Take out soap drawer & remove screws behind it. Take off band holding door seal & peel seal back.Remove 2 screws holding door lock &push lock through. Pull control panel forward at left side &slide to right to remove being carefull with board & wiring.Remove screws holding top end of front then lift slightly &remove front.Remove back panel &take wiring off heating element & pump. Disconnect the pump hose at the drum end, disconnect the hose from the soap dispenser, note that wiring is fastened to the drum at several points and will need to be disconnected. Remove panel from behind control board then carefully move everything away from the front of the machine, the drum can now be lifted clear.
Forgot to mention unplugging motor but common sense will prevail.
If you need any further assistance please post back
Good luck & thanks for using Fixya
Nov 27, 2008 | Hotpoint WMA64 Front Load Washer
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
