Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series top loader leaks from the front. how to fix the problem
I do not know what model it is but it leaks from the front
  • Anonymous Jun 08, 2008
    We have a Kenmore Elite washer that leaked in the front. The technician came out and determined that the bleach holder was getting clogged with debris and the water would overflow. We just had to pop out the bleach holder, clean out the dish below it and the water stopped leaking. Quick fix for an annoying problem.
  • 413 Answers
The water pump is the front and has probably failed.
To access it REMOVE POWER, lift the console by one of three ways. 1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward. 2. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw. 3. insert a putty knife under each corner, push to release a latch. With console lifted:
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
The pump is mounted to the motor with two spring clips. Look at the face of the pump for any signs of melting or blistering. (grey bubbling) or the shaft of the motor for rusting.
If the pump appears OK, inspect the drain hoses for splits or cracks and that the hose clamps are properly secured.
Posted on Jun 07, 2008
How do I replace lid switch in a Sears Kenmore 80 series, model 1
The following link explains step-by-step how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool so these instructions will apply.
Apr 07, 2010 | Kenmore 24032\24036 Top Load Washer
Efficiency of Kenmore 80 and 90 series washers
all front loaders do is save alittle water,motor and pumps aree almost the same,kenmore makes the 300,400,500,600,series know and they will last forever,and if you do need a replacement part they are dirt cheap,because all parts are universal-mike
Feb 05, 2010 | Kenmore 15944 Top Load Washer
I get oil stains on some items of clothing in each wash. I've tried discontinuing use of fabric softener as suggested by Sears, and I've also tried several loads of CLR to clean any grime or rust build up....
If this is a front loader, it is the bearings on the tub shaft. I just replaced a set on my front loader for the 2nd time. It is not a real easy fix but mine cost only cost 25.00 for the 2 bearings and seal. Not from Sears.
Jun 28, 2009 | Kenmore Washing Machines
Where do i put the softener
some model units do not come with a softner dispenser, ask sales rep at sears it might have been an upgrade model in the 90 series that had that dispenser??
May 16, 2009 | Kenmore 23012 Top Load Washer
How do you open the console on a Kenmore 80 Series Washing Machin
To replace a motor coupling on a Kenmore top loader, follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Included are all the step-by step instructions you need (including how to open the console). If you still have questions, or require additional assistance, please let me know. I hope this helps you.
Feb 25, 2009 | Kenmore 24032\24036 Top Load Washer
Need cu size of my broken washing machine.
it is a 3.0 cubic foot.
  • I would do some research before spending a lot of money on a front loader.
Aug 05, 2008 | Kenmore 24032\24036 Top Load Washer
80 Series top loader excessive vibration and noise on spin
check the screw feet, on the front corners, one may be not screwed down far enough to be 'tight' to the floor allowing a small movement that makes a lot of noise, halting under pressure suggests this is the case
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series leaking
the pump is most likely the cause if you have mach skills i can walk you thru it on how to open the unit and check it let me know
Jan 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Ron Lankford
Archaeology
Archaeology
reliableservice
