Question about LG LRFD25850 French Door Refrigerator
Freezer not cooling and shoing error on conrols
  • LG Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 25, 2010
SOURCE:
Samsung refrigerator has 21 E code flashing
Freezer fan error. Most likely the fan in your freezer has stopped working completely
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jul 05, 2016 | Samsung RF260BEAESR 25.5 cu. ft. French...
Control panel on front stops working, only freezer lights are lit, freezer and fridge stop cooling.
when half of the display goes out, it is giving you an error code telling you what is wrong with the fridge.Unplugging it simply resets the computer until the error comes back typically within a few hours.
without knowing what is lit up, it is difficult to help you so I would recommend putting the error code "which bars are lit up" in a comment so we can diagnose further
Feb 03, 2018 | LG LFX25960ST Stainless Steel French Door...
Fridgidaire refrigerator keeps beeping with an error message of "HI" for the fresh foods.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 27, 2011 | Refrigerators
What does error code 24 mean?
This error codemeans defrost under heat. The thing about it is chances are there really is no problem. There is a wire that runs from the drefrost thermostat in the freezer to the conrol heading. This wire is split into three sections, and sometimes signal is lost, or degraded, going back to the control so the machine thinks that the defrost heaters are not working properly. The only real way to fix this is to take th freezer wall out, find the wire which I think is blue, and cut the junctions and use wire nuts to tie them together. There are two junctions in the freezer , and one near the control board, but if you can live with seeing the 24 code and know there is no problem, I wouldn't worry to much. Most of te time calling a tech will only get you smeone trying to sell you a part you don't need. Hope this helped.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 11, 2010 | Sub-Zero 700TCLH Bottom Freezer...
COOLING CAPACITY FOR 1993 TAURUS
1993 FORD TAURUS 3.0L 6-cyl Engine Code [Y] SHO
Engine oil, with filter..........4.7 liters
Cooling System, Initial Fill..........11 liters
Good luck and hope this helps, thank you for using fixya
Nov 04, 2010 | 1993 Ford Taurus
Rear heater stuck on cool will not switch to heat
check for hot water in the pipes to the heater unit
Nov 11, 2009 | 1999 Dodge Durango
Freezer working fine but refrigerator not cooling
Do you have the ER DH error message showing? If so, it is a failed senser, an $11.99 part that many of us are having trouble with.
May 18, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error message and not cooling Kenmore Bottom Freezer
First if you have not already complety defrost freezer, if this does not resolve check the defrost heaters are ok if not replace, if they are then the fault is the defrost sensor. Regars Advisor
Jul 31, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
LG LRFD25850 French Door Refrigerator Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
