Question about Samsung 61" Slim-Depth DLP HDTV
My samsung tv cuts off while watching tv. sometimes its every 10 minutes
  • Samsung Master
  • 5,138 Answers
Ck the Fans ,make sure they are not Full od Dust and Dirt on them and if they are OK then replace the Lamp Mats has them for $99.00 1-800-628-1118
SamsungParts.com 1-800-627-4368
Posted on Oct 27, 2010
SOURCE:
Why won't my Samsung LCD tv boot properly at startup
Hi Tom,
This is becoming a theme with Samsung TV's, Samsung have extended warranty cover for some customers with this problem, have a look at this post for more info and the link to Samsung:
have 60 Samsung led tv Sound keeps cutting out all night for 3 5 seconds...
Feb 13, 2016 | Samsung 9000 Series UN65F9000AF 65" 4K LED...
Why does upper half of screen go dark?
http://www.shopjimmy.com/samsung-bn96-03365a-g-buffer-board.htm Watch the video. Also be advised that plasma sets are getting very hard to find parts for.
Feb 01, 2016 | Samsung HP-S5053 50 In. Plasma HDTV
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Samsung LN 32C 530F1F keeps powering off randomly
probably overheating. hoover out the vents and make sure plenty of air can circulate. a case of suck it and see. lol
May 24, 2017 | Zenith Televison & Video
Rear Projection TV Cuts out Need to wait and then turn back on?
SOUNDS LIKE A FLYBACK PROBLEM AROUND $70.00 FOR PART
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
Television
maybe the power switch of your tv is loosen,if not you may coldsolder the components of board of your tv.
May 26, 2008 | RCA TruFlat 27F520T 27" TV
Audio cut off Samsung 32
Try using different audio connections and see if you have the same trouble... try using RCA cables, optical, and HDMI... see if it happens in either scenario... I would bet dollars that you are using optical audio and the cable is crimped, etc.... you probably just need a new digital optical cable...
Dec 27, 2007 | Samsung LT-P326W 32 in. HD-Ready LCD...
Picture cuts out and sound delays
Wow, I have the same problem. I have even tried using never used DVDS, it just freezes after a while. I will get small glitches every few minutes. I am calling Samsung tommorow and raising hell, this was a Christmas present and I am embarrased. I also use HDMI and have changed the set up to 720P.
Dec 01, 2007 | Samsung HT-X40 System
Samsung 61" Slim-Depth DLP HDTV Logo
99 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
