Question about Dell Dimension 4600 PC Desktop
Slave drive into Dell Dimension 5100
Hello I own a Dell dimension 4600 that I believe the power supply went out on. I'd like to take the hard drive out of this machine and install it in my Dell Dimension 5100. Does the 5100 have the power and plug ins available to do this?
    Sniper:
  • 54 Answers
Yes it does. It may not have an IDE cable if using SATA hard drive, but it does have a port on the motherboard to plug in the cable you take from your 4600.
Don't forget to rate your answers please!
Posted on Jun 08, 2008
Which power supply connectors plug into which drives in a dell dimension 3000
P1 is about the same as the rest but for a slave drive p7 should be ok
Jun 21, 2013 | Dell Dimension 3000 PC Desktop
Power supply instalation manual for dimension 5100
power supply installation for dell dimension 5100 is not that much hard, what you need to do is to remove the old power supply and unplug the cable from the mother board
Oct 26, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
1st, my desktop (dell Dimension 5100) had been not used for several months. When turned on, the green error code lights 3, 4 and a flashing battery appeared, along with a beeping noise. I read up on the...
I assume your new computer has IDE controller on the motherboard.
Yes you can install your old hard drive into your new computer as a Slave hard drive.
If the old hard drive is installed on the 2nd IDE controller and it is the only device on the controller then the jumper and be master or slave, but connect the hard drive at the last connector on the IDE cable.
Oct 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
I need printed instructions on how to install Dell Dimension 4600c power supply. I ordered the part but it came with no instructions.
Power Supply Removing the Power Supply caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions in your Owner's Manual or Product Information Guide. caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before removing the cover.
  1. Follow the procedures in "Before You Begin."
  2. Remove the fan assembly.
  3. Disconnect the AC power cable from the AC power connector on the back of the power supply.
  4. Unplug the DC power cables from the drives and system board.
  5. Remove the four screws that secure the power supply to the back of the computer.
OR
As you add more devices to your Dell Dimension 4600 desktop, it is important to ensure there is enough electrical power being fed to the components. While the 250 Watt power supply that comes standard with the Dell Dimension 4600 is acceptable at stock settings, it is almost certainly not capable of providing power for many more devices such as graphics cardsmag-glass_10x10.gif and multiple hard drives. If you add such devices, you also should upgrade your Dell Dimension 4600 power supply.
Aug 28, 2009 | Dell Dimension 4600C PC Desktop
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Power supply ?
I'd recommend purchasing a new power supply.
Your Dell Dimension 5100 comes stock with a 305W power supply. This is a bare-minimum wattage that will only handle what they ship on the system & not much more. You're better off upgrading the power supply with a compatible after-market model.
You can go to a PC parts store in your area and take your chances...but they're usually more expensive then Internet sources (they've got to pay for their brick-n-mortar store overhead).
Here's a link for a very inexpensive replacement 400W power supply for your Dell Dimension 5100:
http://www.affordablesurplus.com/dell-5100-5150-power-supply.asp
This particular site offers $8 Flat-rate shipping & a 1 year warranty. Your power supply is only $49.99 - you might be able to find it cheaper elsewhere, but that's the best I could find with a quick Google search.
If my answer helped you, please provide feedback :-)
May 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell 4600 motherboard
That particular Dell uses a power supply with non-standard wiring. The plug is the same size as an ATX plug, but it's wired differently. If you were to replace motherboard & plug in the standard power supply, it would damage the supply, or the motherboard, or both. Also, the front panel plugs (for power & power LED & hard drive indicator) are proprietary as well. Ideally you should replace it with another Dell Dimension 4600 motherboard. I've found replacements for reasonable prices on some of the auction places on the web. I recently replaced a failed motherboard in my Dimension 8300 with one I got from a popular auction site, I think my cost was about $59 plus shipping.
The other option would be to remove the hard drive, video card (if any), and optical drives, and consider a 'barebones' package from various sites such as geeks or newegg.
Jan 05, 2008 | Dell Dimension 4600 PC Desktop
Hard drive and cd drives still on
Locate Power Wakeup option in modem/LAN in BIOS and disable them, if you have "power wake up" enable for LAN/modem your computer will be switched on for remote network command.power wake up setting are located on BIOS.
Dec 09, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
199 people viewed this question
Alun Cox
