Question about Canon P23-DHV Calculator
Adding paper how do i put paper in the adding machine?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
There is no manual available for this model online.
However, there are two basic methods. Always make sure you are puting in paper that has been cut cleanly with scissors, not torn, as this can ruin your printer. If you have a slot on the back of the machine, just under where the paper roller typically sits on the holder, with the calculator off feed the paper in that slot (rolling out from the bottom). Then turn the printer on, and hit the feed to advance the paper into the printer.
If there is no slot on the back, you will see that the opening where the paper comes out from the top is "subdivided", and when it has printed, it is coming out of the front partition of that slot. Make sure the printer is off, feed the paper into the back portion of the opening, rolling from the top. Then turn the printer on, and hit the feed to advance the paper into the printer.
Either method should solve the issue exactly, and once the paper has fed in, then place the roll onto the holder. You're set!
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Posted on Jun 08, 2008
How do I put roll of paper in adding machine Canon P100-dh
hi. the is a little slot located in the back side of the machine insert the tip of the paper there and press the upper arrow in the keyboard. .
Mar 07, 2015 | Canon Office Equipment & Supplies
Ekg machine keeps beeping out of paper --- it has paper !
Check is the paper is properly installed or not. Here i have added a video wich will help you to proper installation of paper in the try. keep in mind the you have to use Schiller orginal paper.
Ajin
May 29, 2012 | Schiller Welch Allyn Cardiovit At 2...
Loading paper in a sharp el-1750v adding machine
i can tell you how in the back there is a **** on lower back slide paper in and push the button that looks like an arrow with ripped paper an it should feed
Jan 19, 2012 | Office Equipment & Supplies
How do you put the adding paper into the machine? My machine is a EL-1197iv
Never insert paper roll if torn. Doing so will cause paper to jam.
Always cut leading edge with scissors first.
1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
2) Turn the power on and feed the paper by pressing . (Fig. 2)
3) Insert the paper roll to the paper holder. (Fig. 3)
DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
DAMAGE TO PRINTING MECHANISM.
Jan 03, 2011 | Sharp EL-1197PIII Calculator
HOW TO put paper into ShaRP ADDING MACHINE
Having gone over a month with no response, I assume this is no longer a problem.
Jul 19, 2010 | Sharp Office Equipment & Supplies
How do you put the adding machine tape into the Sharp EL-1801V Adding machine?
Put the leading edge of the tape into the the opening on the back of the machine. Turn the machine on and press the button with the up arrow, then lift the little metal paper holder and insert the roll.
Mar 08, 2010 | Sharp EL-2630P Calculator
Adding machine problems
Block yBob - did you ever get an answer to your problem. I'm getting ready to install an ink cartridge into the same machine.
Aug 20, 2008 | Office Equipment & Supplies
Adding adding machine paper to the Ibico 1202
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in..Look in the back of the printer for a thin slot. (Usually goes under the printer1.gif assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Please remember to leave a rating or feedback if I have helped you with your question.
Mar 21, 2008 | Ibico 1202 Calculator
Paper tape in my TI 5045, please.
Feed the paper in the back press the paper advance button while pushing the paper in the rear slot, and it should feed the paper through.
Hope this helps.
Good luck.
Mac
Feb 08, 2008 | Texas Instruments TI-5045 SVC Calculator
Canon P23-DHV Calculator Logo
198 people viewed this question
old marine
old marine
