Question about Samsung DV337 Electric Dryer
My samsung dryer will not turn any suggestions? It is less than a year old was working fine and when I switched loads the unit lights up just will not turn
  • Samsung Master
  • 43,501 Answers
Door switch...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 28, 2010
6ya staff
SOURCE:
Gas smell inside samsung dryer when off
Very seriuse must repair gas valve may need to change
Dec 06, 2013 | Samsung DV456GWHDWR 7.3 cu. ft. King-Size...
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
Kenmore HE2 Gas Dryer Control Panel Does Not Work Properly
I have the same problem..really disappointed in this product. I bought mine in 07 as well..I found that if i hold all the buttons down and then hit start it (Sometimes starts), but after it starts it turns off after 10 seconds.
Mar 27, 2009 | Kenmore Dryers
Dryer wont turn back on.
Hi!! Relax your thermal fuze has shorted out..replace your thermal fuze and all is fine..Good luck..the fuze is located by the motor blower inside the machine its white oval around 2 inches and has 2 wire leads to it good luckk.
Jan 04, 2009 | Kenmore 64992 Electric Dryer
My Bosch nexxt electric dryer won't turn on
Belt broke or came off. Replace or reset belt. Be sure to reset the switch that the tension arm activates when tension is lost.
Nov 04, 2008 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer doesn't work, check filter light is illuminated
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Codes require factory service . Why wait call tonight!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 27, 2008 | LG DLE2532W Electric Dryer
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
Control Button Issues
My two year old unit would not do anything, but lights on. Then they would go off, and nothing but opening the door would get them on again. Replaced electronic panel in Feb. 2008, under warranty, still cost $80. Worked until first of June, 2008. Ordered a new panel. Repairman suggested that the wall outlet may be defective, even though the lights were on. The Unit also would have the lights come on by themselves. Outlet replaced, dryer worked fine. We still replaced the panel board, as repairman was not sure exactly what was the problem. I was told that the panel costs about $300.
Jun 08, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Samsung DV337 Electric Dryer Logo
1,137 people viewed this question
Top Samsung Dryers Experts
Marvin
Marvin
Mike
Sheldon Dedek
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
