Question about Refrigerators
F30 fault - Refridgerator model RF610 - Refrigerators
  • 1,891 Answers
This code does not come up . but i don't know your moder or brand . try removing the toe grill and see if tech sheet is there it will tell you what the code is and what to do about it . mm
Posted on Oct 24, 2010
SOURCE:
The electric range is a Kenmore model
Bad oven temperature sensor.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 02, 2014 | Kitchen Ranges
Defrost Cycle on Fisher and paykel RF610
Malcolm, if you are indeed getting an F20 fault, this is a problem with the flapper heater. The flapper heater current is low.
First, Check the JST in-line connections for the flapper heater.
Second, Check the resistance of the heater. If open circuit, replace the heater.
Apr 20, 2014 | Refrigerators
When I push the Bake or Broil buttons on my kenmore stove it beeps F30. I do not have a self cleaning oven. The gas burners work fine so I know we have a clear line. What can I do?
Log on to the Kenmore website and click on support. Enter your model number and go to troubleshooting. There you should find what your trouble code means. murf427
Oct 24, 2012 | Kitchen Ranges
My washer is giving me an error message of F30 and it makes humming noise like it wants to come on but it doesn't.
The fault guide says the following about F30:
DISPENSER SYSTEM ERROR
The dispenser motor cannot be driven to its proper position
1. Unplug and disconnect power
2. Check mechanical linkage from dispensor motor to top of dispenser
3. Check wire harness connections to the dispenser motor and central control unit
4. Check dispenser motor for powered rotations
Hope this helps
Jul 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F30 comes up and the drain basket is empty
F30/31 - Motor Error
If this error occurs then you should try to run the programme again, but a persistent problem will need to be looked at by a professional. A F30/31 error code can indicate a fault with the carbon brushes, drive belt, motor relay or PCB. You can buy spares for your Hotpoint washing machine at many places on the 'net, simply Google for it.
Nov 09, 2010 | Washing Machines
MAYTAG MODEL MAH22PDAWW FAULT CODE F30
I have maytag model MAH22PDAWW it doesn't work the display show's ----
Sep 09, 2008 | Maytag Washing Machines
F30 fault code on model ples389ecb
F30 code fault means the temperature probe has an open circuit. It could be the probe or control board but probably not. There is two thermal overload switches in this circuit which may be tripped. One is located in back of range and the other is located in the front near right burner knob. Find these two switches and mash red button on them to see if it clicks and resets. Dana
Jul 30, 2008 | Frigidaire Kitchen Ranges
Refrigerators Logo
134 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
