Question about NetGear RangeMax Dual-Band Wireless-N USB Adapter (WNDA3100-100NAS)
My computer that I am connecting to wirelessly with the adapter keeps dropping the IP address and is continually searching for network address. We have uninstalled and installed it now 9 times. It connects for awhile, like weeks and then drops it again. Help!
    New Friend:
  • 56 Answers
Upgrade the firmware of the adapter or your router/modem
Posted on Oct 24, 2010
SOURCE:
Can not connect to Verizon MiFi2200 wireless network
Yes the verizon tech informed you right that the ip address will be acquired by your wireless adapter automatically. However there are lots of reason that your adapter not able to connect wireless.
1. Make sure no firewall or antivirus is blocking your wireless connection to connect wirelessly.
2. Make sure you are entering the right password for the wireless network if your network is secured.
3. Make sure the wireless adapter driver installed properly.
4. You can also try to restart the DHCP services through which your computer will try to get the ip address. I am giving you the steps how to restart the DHCP service once again.
- Click on start
- Under start search or under run type in services.msc
- Search for DHCP client and right click on that and you can click on restart. It will restart your services.
5. Make sure other computer are able to connect wirelessly to identify whether there is a problem with the router or a wireless adapter.
6. Make sure the wireless channel on the router is correct sometime due to wireless channel your computer not connect.
I hope this will help to resolve your concern. Still if you face any problem let me know.
Thanks & Regards
Jazz
Jun 27, 2010 | Linksys Ultra RangePlus Dual-Band...
Cannot connect to the internet wirelessly. says i
If you are getting invalid ip try the following:
  1. Click Start and type "cmd" in search press enter
  2. In the command prompt window type ipconfig /all
  3. Check the ipv4 ip address
  4. If you are getting an ip address as 169.254.xxx.xxx
  5. Go to device manager
  6. Uninstall the Network Adapter
  7. Reboot the computer
  8. Re install the driver for you network adapter if prompted
  9. You should be able to get a Valid ip address and get connected
If you have a pci network card installed
Try to remove the card and install it in another slot.
Hope you find this solution helpful.
Thank you for choosing Fixya.
Jan 22, 2010 | Acer 91.AB370.001 Network Adapter
My wireless network is detected by my computer, but I cannot connect, what should i do?
If your network is WEP or WAP encrypted try to reconnect your computer and provide the key. Else go to your PC and Remove all wireless netork configurations you made so far to connect to the network. Restart your computer and search for the network. Don't configure the PC for the new network just search for a wireless network and when you find it connect it.
N.B. Check your wireless adapter's IP. If your network uses automatic IP addressing check to see if your computer's IP is set to automatic no static
Nov 22, 2009 | Zyxel P660HW-D1 Router
My wireless adapter keeps disconnecting me from the internet, and I can't figure out how to fix it. I have to restart the computer everytime. I also can't pick up my laptop or it freezes. I have a toshiba.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. ypur connection won`t drop after this. and your laptop is freezing because you might not have got it serviced from a very long time.
Jul 14, 2009 | Toshiba (PA3212U) Wireless Adapter
My wireless adapter TEW-444UB disconnects from network if computer stays "on" for a day or so. It's connecting again if I unplugged and plugged it again. This drives me crazy. Is it a way it designed and...
Jul 13, 2009 | Trendware TRENDnet TEW-444UB 108Mbps...
DSL connection keeps dropping off. Going to RED
well!! I have an answer for you.your comp is loosing the IP address.do this when you can go online. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. ypur connection won`t drop after this.
Jul 10, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Intel Proset wireless just drops connection
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 02, 2009 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
My 2Wire Wireless adapter connection keeps getting disconnected every 5-10 minutes(ATT U-Verse Internet Svc)Is there a better adapter to resolve my problem ? Thank you.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Computers & Internet
Abit wireless adapter unable to locate wireless network
well!! I have an answer for you.your comp is loosing the IP address.connect your computer through cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Abit (WLP-01) Wireless Adapter
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
NetGear RangeMax Dual-Band Wireless-N USB Adapter (WNDA3100-100NAS) Logo
246 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
