Question about Refrigerators
I have a Magic Chef Mini Fridge model number MCBR465S that stopped cooling. I can hear it humming but don't know how to diagnose the problem. The seal on the door is a little bent up (not really bad) on one corner. Could it have cause the fridge to overwork itself? Any help would be great.
  • 1,891 Answers
The humm may be the compressor trying to run . the seal is not your problem / but if you get it running then i would replace the seal . . the relay on the compresser could the problem. also the fan underneath if not going this would cause the problem. hope this helped mm
Posted on Oct 24, 2010
SOURCE:
Magic Chef Refrigerator has stopped cooling adequately.
Check the compressor and the Relay, the relay is located on the compressor itself. you should have full voltage to both of those. If oyu have voltage to the relay and not the compressor then the relay is bad. If you have power to both and the compressor will not kick on then you have a bad compressor and it is best to just replace the fridge
Apr 26, 2009 | Magic Chef MCBR170 Compact Refrigerator
What could be the problem with my Magic Chef mini fridge model number MCBR465S. It comes on when I plug it in but not cool at all, and the compressor hot, could I trouble shoot and how,freon? Thx
If the compressor is actually running and there is no refrigeration, I would suggest it has a gas leak and that's why it isn't cooling. Depending on what type of refrigerant is in it, it may not be worth repairing as its only a small bar fridge? Check the rating plate to see if its R12 (Older fridges) or R134A . If the unit is less than 5 years old, it may be operating on R32 or R600 (Butane refrigerant gases) If its only a couple of years old, it may still be under Manufacturer warranty. Most fridges carry a 2 year warranty on everything and up to 5 years parts warranty on what is known as the "Sealed system"
Apr 19, 2015 | Magic Chef Refrigerators
I have a Magic Chef Mini Fridge model number MCBR465S that stopped cooling. I can hear it humming but don't know how to diagnose the problem. The seal on the door is a little bent up (not really bad) on...
First fixed the seal make sure that any leaking out. And then go to the next step by checking to see if the compessor motor come on and stay running for af list 10 minute. check the temperature controls make sure they are at the set temperature.
If you go behind the fridg and take the motor temperature see is very hight you must unpluged the fridg you may have a bad motor.
Oct 24, 2010 | Magic Chef MCBR445S1 Stainless Steel...
Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
Oct 29, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Fridge won't start, tries to but clicks off after a few seconds
compressor is broken if you are under warranty you can get it replaced. if not you should buy another one cause compressors are expensive to replace. costs about the price of a new refrigerator. you can try getting a used one from classifieds or craigslist.com
Aug 26, 2009 | Magic Chef MCBR440 Compact Refrigerator
Re: Magic Chef
If the compressor is running but the fridge is not cooling, the gas may have leaked out of the system or the compressor is inefficient. The only way to know for sure is to connect a set of gauges to the system. You will need to call in a Refrigeration Mechanic.
Nov 03, 2007 | Magic Chef MCBR440 Compact Refrigerator
Refrigerators Logo
214 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
