Headphone monitoring DP02
I can only hear out of one ear on the headphones, no matter where I pan to. I have hooked up monitors, and they both work. I have tested the headphones on other equipment and they are working fine. Could I have a bad phone jack on the DP02, or does monitoring only come out on one side??? Drives me crazy! This is my 4th tascam recording device - the first to not be able to monitor with headphone when recording.
It was a bad phone jack adapter ... found another one, and it works fine. The DP02 ROCKS! I wish it had build in compression though - I am finding my vocals get too loud and too quiet at times. Maybe it does, I have to keep reading. So far, it does everything except the dishes :)
I started recording back in the 80s, and spent over $30K back then to get equipment that honestly doesn't do as much as this little machine. (I wasn't rich, I went bankrupt).
Posted on Jun 09, 2008
How do you hook up sound from surface rt to acer monitor 2014
To connect anything to the speakers on your acer monitor you need to use an audio patch cable that has 1/8 inch or mini headphone jacks on each end. Like this one.
5mm Male to Male Stereo Audio Cable...
You connect one end to the headphone jack on your Surface RT and the other to the audio in jack on the monitor. Make sure the power is on for the monitor and that the volume on both is a third or half way up and you should be able to hear the sound.
This is for the monitors user manual.
Acer AL1715 User Manual Amazon com C2G Cables to Go 27413 3
Jun 13, 2014 | Acer 22" X223w LCD Monitor
Severe squelch in left ear phone
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a significant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the shape of the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs.
If the foam in the ear cushion has weakened/deteriorated to the point that it no longer has it's original shape, (in particular the lower half of the ear cushion), the size and shape of the air chamber inside of the earcup is directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
It is probably time to replace the ear cushions. If so, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Aug 29, 2013 | Bose QuietComfort 3 Acoustic Noise...
I have a 1680S. How do I hook up my in-ear monitor? I plan to run two house speakers but no floor monitors. Thanks,
DO NOT connect your in-ear monitors to the power amp out using the MAIN/Mon speaker option as it would be goodbye hearing and fried ear buds..
Get a very small and in-expensive headphone amp and connect its input to the 1/4 inch Monitor output jack.
Dec 31, 2010 | Behringer PMP1680S Europower 10-Channel...
We just bought a viore 19" class lcd and can't figure out how to hook up our new sony wireless MDR-RF925RK RF headphones so that one person can hear the tv and no one else can hear the sound.
After doing some searching for the TV you mentioned, it appears it doesn't have any outputs to plug the headphones. Website says it only has inputs. You would need a monitor or a fixed audio out for this to function as you wish. Sorry.
Nov 22, 2010 | Sony MDR-RF970RK Headphones
I just purchased an LG W2253V monitor, have it hooked up and working just fine but I am not getting any sound. What might be my problem and how might I test this sound?
dbeffort, Try to prove that you have audio (stereo) signal coming out the "lite-green" audio output jack on the pc!!! Use a set of stereo headphones or "ear-buds" to prove audio is present. Let me know results of test. 12fixlouie
Sep 05, 2010 | LG Computers & Internet
How can i setup the mic monitoring system?
The mic monitor should work (you should hear yourself in the headset) as soon as you plug in the chat-controller cable. If not, then there may be something wrong with the chat-controller cable. Also, please make sure you have a fresh, fully-charged set of batteries in the headset.
Mar 06, 2010 | Voyetra Turtle Beach Ear Force X3 Wireless...
Everything works except chat
You probably need a replacement chat-controller cable. Those are available from the Turtle Beach website (look for Replacement Parts) or from their tech support (
Feb 13, 2010 | Voyetra Turtle Beach Ear Force X3 Wireless...
101 people viewed this question
