Question about Samsung CLX-3175FN Printer
How do i remove the fuser unit from samsung 3175fn
4 Suggested Answers
SOURCE:
antiochpc
  • 1314 Answers
SOURCE: Replacement fuser unit for Samsung CLP-510
The part number you need is JC96-03239C-N
You may order it through this website; you'll need to call them for pricing information. They are a reputable company that I use to obtain parts.
Thanks and please give this solution a thumbs up rating, solving your problem.
Posted on Apr 26, 2009
  • 23 Answers
SOURCE: samsung clx-3175fn "deve home positon error"
Service Manual can be found here Free http://hotfile.com/dl/28988134/55113fe/CLX-3170-3175.zip.html
Posted on Feb 17, 2010
SOURCE: need to replace samsung clx-3175fn
I have the same problem. I'd like to replace the fuser unit. It appears that maybe there is a belt that is holding it on. Any help out there? If I can get a solution, I'll shoot a video when I replace mine.
Posted on Dec 12, 2010
Samsung CLX-3175FN printer only prints VERY faint image. Just replaced all toners with genuine Samsung. Never had this problem. All contacts look clean???
Faint prints with Laser Printer usually occurs when the drum is full with the wasted ink (toner power) or when the Fuser Unit is not working correctly. First of all try cleaning the Drum and remove the wasted toner power. There should be an opening on one of the end of the drum. In some cases, it needs to be disassembled to remove the wasted inks.
Also remove the fuser unit and clean the unit. Please handle it with care and never clean it when it's hot/warm. Only do this, after the printer is left turned off for about half an hour.
If nothing is helpful, try with another/new drum or fuser, that will help you get to find out the exact cause of the problem.
Good Luck.
Thanks for using FixYa.
Sep 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
What does low heat error mean?
hi..............
There is a problem in the fuser
unit.
Unplug the power cord and plug it back
in. If the problem persists, please
contact a service representative.
Thank you.........
Jul 30, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Paper Jam 1
there is most probly a pease of paper in side the fuser unit.See if you lift the top cover just under the scanner, the hole top lifts up!!!!!!.in the back you wil be able to see the fuser.Be carefull IT IS HOT!!!!!!!see if you can get eny papers in there.And try to take it out carefully.Otherwise will have to strip it to take the fuser apart to clean it up
Jun 03, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
My samsung 3175fn laser printer keeps getting a black line and ye
The printer has a build up of toner on the drum/fuser, a maintenance cleaning done by certified technician of the printer would fix this problem.
May 31, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Low heat error. I am assuming it is the fuser unit
It could be the fuser or the power source to the printer. If you have printer attached to a power strip or UPS try disconnecting from that device and see if the issue still exists. If that doesn't work it is probably time for a new fuser.
Nov 17, 2009 | Samsung CLX-3175FN Printer
System error cycle power. i already reinstall the bottle and the imaging unit. still same error. the unit is brand new
Change the temperature sensor from the fuser unit. There is no need to chang the fuser unit, it is expensive. I repair the sensor, it is a mechanical device who remains blocked.
Nov 06, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
How to remove covers and fuser unit?
Ive got the same problem :( and because i used compatible cartridges, it apparantly voides the warrantly, so staples will not fix it :( so im now stuck with a £260 uselss printer :( good luck getting it fixed.
Sep 28, 2009 | Samsung CLX-3175FN Printer
Samsung clx-3175fn "deve home positon error"
The developer home error is due to developer home unit itself and has to be replaced. can be done by Authorised service person.
May 29, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung CLX-3175FN Printer Logo
292 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
