Question about Lexmark X8350 All-In-One InkJet Printer
X8350 will not power on. It is getting power. (green light on transformer is on)
    New Friend:
Power is on and power light off. Could I have waited too long to replace the color cartridge and that is the reason it is not working
Posted on Oct 31, 2010
6ya staff
SOURCE:
I am having problems with Lionel Fastrack layout. When I put electrics to the layout the green light comes on and I think all is ok. However as and when I start to increase the power the red light A.
remove all the cars and engine from tracks and try it, if green stays on add one car back to track at a time and try it , when light turns red , the last car added is the problem
Mar 20, 2016 | Crafts & Hobbies
Blinking powerlight on lc- c5255u
I just repaired this LCD tv exact same model.
symptoms- when the tv turns on, all I get is a black screen with blinking green light. No other error codes. It was crazy frustrating trouble shooting this. I measured the transformers on the master and slave inverter board with a multi meter. The resistance should be 1.31 k ohms. All but one measured within the specs except one. I get an OL reading. I took a chance to order this part on eBay for 13 dollars. After soldering it, the resistance for all of the transformers were back to specs. The tv powered on and stayed on. Works good as new. If anyone has the this similar issue I would advice testing the mini transformers on your master and slave inverter board. My email is [email protected] for help.
Jan 29, 2014 | Sharp LC-C5255U 52 in. LCD TV
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
No power
you have a low amp fuse protecting transformer. could be thermostat issues.
Dec 12, 2013 | Ruud Rheem Corsaire Control Circuit Board...
I have two dimmer switches in the same box side by side. one goes to three pot lights, the other goes to a halogen track light. these have been working for 5 years. the lights have burnt out and been...
Sounds like the transformer in your track light. In the box where the green light is, the voltage is converted by a small transformer from 120v to 12v for the halogen lights. With the breaker off, try jumping out the dimmer going to the track light (disconnect the dimmer and connect the two loose wires from box together). With the breaker back on, if you have 120v power on the wires (black/white) going into the track light transformer (measured at the track light), and the green light won't come on, I'd say it's the track light transformer. You may have to replace the whole track if you can't get the transformer as a part.
Apr 22, 2017 | Lutron ELECTRONICS MAW-600H-LA SMART...
Laptop is not turning on
thing to check is the power
1. is the battery charged? 2. Do you have power into the transformer? green light on the transformer should be on. 3. is the Transformer providing power to the device (is the power light on (usually on the front) green?
If any lights are not on the no power is getting into the device. Check connections are in correctly, If still no power to the device then you need a new transformer and prices vary depending on the make and model but they are not cheap.
Dec 14, 2010 | Computers & Internet
Tv comes on, green light flashes several times, get the "digital television" shown at botton left corner, then flashing green light stops, tv turns off and red constant "stand by" light comes back on. TV...
common problem with that model is the backlight inverter, 1 or more of the six transformers may be bad.also check for bad capacitors.the tedious way to check is unplug each and plug in each one at a time but unplug the power from the tv each time you check one or you will get a nice jolt. the one that doesnt light the lamp is bad.or take each transformer off and check the primary and secondary coils if you find one open coil. the transformers cost between $8 and $20 each.it has a substitute part.
Jul 05, 2010 | Sylvania LD-320SS8 32 in. LCD TV/DVD Combo
NEON SIGN WON'T WORK
If It is actual Neon Tubing. It Takes a High Voltage Transformer to light the tube.
I work in a sign shop and we commonly use 8000, 12000, & 15000 volt transformers.
These types of transformers are like "Lightning In A Box". Unless you know what you are doing It could kill you! Any reputable sign shop should be able to give you a idea what you have for FREE, and the safest and cheapest way to get it working...
Nov 19, 2008 | Neon GREEN PC POWER SUPPLY KIT Power...
Lexmark X8350 gets power not much else
it could be jammed , but unplug it for a while then see if that helps, otherwise a faulty ink cartrige could cause it , a bad wire strip or connection , if none of that seems to be the problem then it is definately an electronic problem
Oct 09, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark X8350 All-In-One InkJet Printer Logo
111 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
