Question about Palm Tungsten T5 Handheld
Trying to reset my t5 wont hard reset
    President:
  • 1,118 Answers
Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Oct 24, 2010
SOURCE:
Palm tungsten t5 won't boot past the Palm Powered
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your T5, so only do it if you have to. Hold the Power Button while you push the reset button. Continue with the instructions to finish erasing your device.
Feb 17, 2010 | Palm Tungsten T5 Handheld
Upgraded from tungsten e to tungsten t5 did first hotsync but subsequently get error message line:4038 error launching application
Hello.
From Palm Support:
When you upgraded from the E to the T5, did you precisely follow the upgrade directions? These steps include the following actions:
Did you install the new Palm software that came with the T5? Did you rename the Backup folder on your computer before you synced the T5?
If you did not rename the Backup folder you have installed system and preferences files from the E that are not compatible with the T5 and NVFS.
Advise that you hard reset to return the E to factory condition and precisely follow the upgrade procedures.
Hope this helps.
Jan 05, 2010 | Palm Tungsten T5 Handheld
My T5 wont power up even though the battery has a good charge and puts off a good voltage
IF you haven't done so yet, do a hard reset. Take the end off of your wand (unscrew it) there's a reset pin on the end of the cap. In the center of the back panel is a reset hole. Push gently with the reset pin.
It should pwer back up....
Jul 11, 2009 | Palm Tungsten T5 Handheld
Tungsten t5 : Won't power on, despite change of a rechargeable battery, soft reset, trial of hard reset. Any suggestion ? Shall I throw this device away ?
It might just be that the battery is shot and you need to replace just it, I would try that before you throw it away
May 25, 2009 | Palm Tungsten T5 Handheld
T5 is frozen on the "Palm Powered" screen
Remove the battery and let the palm sit for a day, reconnect the battery and do a hard reset. To remove the battery, you need a Torx T5 screwdriver. Carefully remove the cover making a note of the location of all the buttons in the case. The battery is connected by a mini 2 pin connector, just disconnect the battery by gently wiggling the connector and pulling.
Mar 06, 2009 | Palm Tungsten T5 - Multilingual Handheld
How do you flash the rom on tungsten t5
pls try these steps first
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=1156,E=0000000000310371479,K=2039,Sxi=10,case=obj(33016)
otherwise update rom from here
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(15356)
pls rate me fixya if i have fixed ur problem
Mar 03, 2009 | Palm Tungsten T5 Handheld
Palm Tungsten t5 WiFi
I suspect that you're in fact holding a Palm TX and not a T5 as the T5 does not have WiFi. If you're using the Palm SD WiFi adaptor, do a hard reset without the card.
(hold down the ON/OFF button whilst using the reset pin to press the reset button. You'll be asked if you are sure you wish to reset. You'll then be prompted to choose the language caliberate the screen etc..)
After that. Go and download all the updates and drivers from Palm Web site.
Oct 04, 2007 | Palm Tungsten T5 Handheld
Interrupted update - jammed
An interrupted update will corrupt your ROM. I sincerely hope you'll get a better 2nd opinion, and from your post it seems like if theres a solution out there then you're not likely to miss it ;] Good luck, and let us know if you worked it out
Apr 17, 2006 | Palm Tungsten T5 Handheld
T5 Crashes
IF both resets won't help (p. 604 / 602 - on the user guide) , you will need a professional help with the repair. FYI A hard reset deletes all of the information on your handheld, including yourpassword. Applications, files, and folders on your handheld's internal drive are also deleted. You can restore the information by synchronizing your handheld with your computer. I wish i could help you more.
Nov 29, 2005 | Palm Tungsten T5 - Multilingual Handheld
Open Questions:
Palm Tungsten T5 Handheld Logo
98 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
