Question about Intermatic Inc. ST01C Digital In-Wall Timer
On the sunrise/sunset setting the sun is always dark as if for night. How do i get to the light cycle ?
You posted under ST01C Intermatic timer.
The Intermatic has a battery
If you have another timer, such as the Utilitec, please answer and I will help you with that problem.
Here is the ST01C manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
If I understand correctly, you are programming the timer for the first time.
And you want to set timer for sunrise/sunset.
I have a ST01C in my hand right now
Section 6 says you can select astronomic function which is dawn-to-dusk
I notice that when you want to get to the Dusk cycle, you press ON-off button until Dawn shows ... and then press + key and Dusk shows on display
Answer back. These timer manuals are hard to figure out sometimes.
Posted on Oct 24, 2010
SOURCE:
DO YOU HAVE a manual for a woods e227659 TM-068-2 timer?
Woods TM-068-2
Indoor 7-Day Astronomic Timer
125V ac / 60Hz 15A / 1875W general purpose
8A / 1000W tungsten 500VA electronic ballast
15A / 1875W resistive 120V ac / 60Hz / 8,3A ballast
FEATURES:
• Up to 7 different programmable ON/OFF cycles, cycles repeat weekly.
• Programming fl8xibilify: u8hts fun on/off automatically at sunset/sunrise,
or at any programmed times you choose.
• ln Sunrise/Sunset programming mode, timer will automatically adjust the
programmed ON/OFF cycles to match current sunrise/sunset times.
• Timer automatically adjusts to daylight savings time
WARNING: TIMER IS INTENDED FOR INDOOR USE ONLY!
BEFORE YOU BEGIN PROGRAMMING THE TIMER:
This timer has in internal battery backup to save all programming.
  1. Plug the timer into wall outlet for 30 minutes to charge internal battery.
  2. After 30 minutes, unplug timer and press the RESET button with the tip of a toothpick or similar object to clear the memory.
TO SET THE CLOCK:
  1. Press SET. PRESS +/AUTO or -/RDM to set the current year.
  2. Press SET. PRESS +/AUTO or -/RDM to set the current month from 01 to 12.
  3. Press SET. PRESS +/AUTO or -/RDM to set the current date.
  4. Press SET. Daylight savings mode (DST) will appear on the bottom of the display. PRESS +/AUTO or -/RDM to set mode to either DST AUTO or DST OFF.
  5. Press SET. PRESS +/AUTO or -/RDM to set the current hour. To change between AM and PM, press +/AUTO or -/RDM 12 timers.
  6. Press SET. PRESS +/AUTO or -/RDM to set the current minute from 00 to 59.
  7. Press SET. PRESS +/AUTO or -/RDM to set the Astronomic function to your zone - North (nor), Central (cen), or South (sou).
  8. Press SET to view the sunrise time. To adjust sunrise time press +/AUTO or -/RDM. To go back to the default sunrise timer press ON/OFF.
  9. Press SET to view the sunset time. To adjust the sunset time press +/AUTO or -/RDM. To go back to the default sunrise timer press ON/OFF.
  10. Press and hold SET for 5 seconds to exit clock setting mode.
Note: The timer allows a maximum of 7 programmable ON/OFF cycles.
To program the first ON/OFF cycle: Press SET repeatedly to scroll through setting the clock mode.
  1. Press SET to display ON 1 setting.
  2. Press +/AUTO or -/RDM to select day or group of days you want for cycle 1. Scroll to select either every day, any individual day, weekdays only, or weekends only.
  3. Press SET. Set ON hour by pressing +/AUTO or -/RDM to scroll through and choose hour AM or PM, or Sunrise/Sunset icon for first ON setting. Note: To select Sunset or Sunrise for the ON time, you must scroll through all the AM and PM hours first. If you select Sunrise/Sunset as the programmed ON time, press SET to continue programming OFF setting.
  4. Press SET. Press +/AUTO or -/RDM to set ON minute from 00 to 59.
  5. Press SET to display OFF 1 setting.
Repeat steps 2-4 to program desired OFF time.
To program additional ON/OFF cycles: Repeat steps to create additional ON/OFF cycles (ON 2-OFF 2, ON 3-OFF 3, etc.) up to a maximum of 7 different ON/OFF cycles.
Press and hold SET for 5 seconds to exit programming mode. Note: During programming, if no button is pushed for 30 seconds, the timer will automatically return to standby mode. Press ON/OFF to cancel any setting.
Sun tracking technology: Timer adjusts automatically to changing sunrise and sunset times in sunrise/sunset mode is chosen for any programmed ON or OFF time. For example, if you program a cycle to turn ON at sunset and OFF at 10:00 pm, the timer will automatically adjust ON (sunset) time as sunset time changes throughout the year (and will always turn off at 10:00 pm as programmed).
IMPORTANT! REVIEW PROGRAMMED ON/OFF CYCLES: Press SET to advance through all programmed ON and OFF settings. Make sure there are no overlapping ON or OFF times. Stop at any programmed setting you want to change.
To operate timer: Press +/AUTO until AUTO appears in display. Timer must be in AUTO mode for programmed settings to operate. Plug appliance (such as lamp) into timer and plug timer into wall receptacle.
IMPORTANT: Appliance must be turned ON or be in the ON position before plugging it into timer.
SECURITY (RANDOM) MODE: To operate a plugged-in appliance (such as a lamp) in a random pattern while you are away, to simulate actual use: press -/RDM until RDM appears in display. In Random mode, plugged-in appliance will turn on and off at random, approx. +/- 30 minutes from the programmed settings.
To cancel Random mode, press ON/OFF until RND disappears from display. Timer will now function using your previously programmed settings.
DAYLIGHT SAVINGS (DST) MODE: If timer is in DST AUTO mode, clock time (and sunrise and sunset time) will automatically increase 1 hour on the second Sunday in March at 02:00 am and decrease 1 hour on the first Sunday in November at 02:00 am.
TO OVERRIDE THE TIMER: Press ON/OFF until desired mode is displayed:
ON: Programmed settings will be overridden; the plugged-in appliance will remain on
OFF: Programmed settings will be overridden; the plugged-in appliance will remain off
AUTO ON: Turns plugged-in appliance on immediately until the next programmed OFF time. Press ON/OFF until ON displays on the screen, then press +/AUTO and AUTO will display on the screen.
AUTO OFF: Turns plugged-in appliance off immediately until the next programmed ON time. Press ON/OFF until OFF displays on the screen, then press +/AUTO and AUTO will display on the screen.
RDM ON (Random ON): Turns plugged-in appliance on immediately until the next random off. Press ON/OFF until ON displays on the screen, then press -/RDM and RDM will display on the screen.
RDM OFF (Random OFF): Turns plugged-in appliance off immediately until the next random on time. On/Off times will vary +/- 30 minutes from the programmed settings. Press ON/OFF until OFF displays on the screen, then press -/RDM and RDM will display on the screen.
Consumer Support (800) 561-4321
www.colemancable.com
Dec 12, 2017 | Woods Hardware & Accessories
What are the sun setting and raising times fro June 22 at zip code 49701
5:50 AM
Friday, June 23, 2017 (EDT)
Sunrise in Mackinaw City, MI 49701 9:33 PM
Thursday, June 22, 2017 (EDT)
Sunset in Mackinaw City, MI 49701
Jun 22, 2017 | Sun Computers & Internet
How do you cancel the sunrise sunset program and just use your own times?
Most dawn-dusk wall timers have programmable option... except aube/honeywell.
Most plug-in timers have various options... but some are just astronomic and not programmable
Following link will help identify timer so you can download possible manual with instructions.
http://waterheatertimer.org/How-to-set-timers.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 17, 2015 | Hardware & Accessories
Finepix troubleshooting
The automatic white balance setting will try to compensate for the red tone in the sunset. You need to set WB to sunlight to get the full effect from the sunset or sunrise.
Aug 04, 2014 | FUJIFILM FinePix S4600 16MP Compact Camera...
How to set on/off time?
Aube T1032 is 500W 7-day timer with full range programming
Aube T1034 is 500W 7-day Sunrise/sunset timer
Aube T1070 is 500W 7-day timer that turns lights ON at sunset and OFF at programmed time later in evening, say 11:00 pm
1) T1032 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI032.pdf
b1129f1.jpgAube T1032 buttons
Switch must be wire for display to show
Move slide switch to ON
Open door to see buttons
Set clock with present hour minute and day
Choose 12 hour or 24 hour format
Review operating mode : Auto for programs to run
Make a chart of your on-off schedule so there are no overlaps and conflicts when programming
Press PGN button
Display shows ON P #1 >>> this means you are setting ON time for program 1
Set hour minute day for ON time for program 1
Display shows OFF P #1 >>> this means you are setting OFF time for program 1
Each program 1-7 has ON time and OFF time plus day of operation
2) T1034 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI034.pdf
Timer must be wired for display to show
Open small door
Review buttons
Review operating mode: Auto if you want timer to turn on-and-off with sunrise sunset
Set the clock with present time / Choose 12 hour or 24 hour format
Use Hour button to set hour MIN button to set minute
Use CODE button to set daylight savings time
Set Sunrise-sunset parameters using tables that show in manual
Make a chart of programs
Set programs 1 thru 7
The above steps are 4 EZ steps for painting the Mona Lisa >>> please re-post question with detailed question
T1070 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI070.pdf
You select mode
Pick your city's coordinates from chart so timer knows when sun goes down
Make a chart of the times you want timer to follow
Select program number
Set days you want that program to work
Set time for that program to turn off lights
Oct 11, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
Programming Utilitech Item # 0192773
Go through the normal setup. Year, month, day, time, DST and the location (north, center, south).
Hit program and make sure all events are clear. Program the first (ON) event, press the TIME button and press /- (with the hour segment blinking) until you see the Sun/Moon symbol indicating the sunset time. Press PROG and program the (OFF) event. Press the /- buttons until you see the Sun/Moon symbol indicating the sunrise time.
Hitting resume clears events if you accidentally entered them.
Make sure you display shows AUTO and you're good to go.
Jul 29, 2010 | Hardware & Accessories
I have a utilitech 0192773 self adjusting timer that will not program. Only works with manual on / off switch. How do you adjust to dusk to dawn
Do not go to Utilitech.com; it's a different company. It's actually at place called TheNCC and is in tiny, tiny print at the bottom of the instructions.
Instead, go to:
http://thencc.com/ncc/support_results.asp?criteria=192773&Submit=Go&SearchRun=RunGo
You should find a PDF for the product and then zoom in to be able to read the instructions. I was not able to read instructions that came in packaging.
Jan 27, 2010 | Intermatic Inc. ST01C Digital In-Wall...
TAKING NIGHT SUNSET PICTURES
this is becouse your not setting the "white balance"
up in the camera first,,,some digital cameras have a manual set up for "white balance" what the camera is doing is trying to put the color cast thats in a sun set right so it looks like day light,,,and you wont that color cast in the pitcher to give it that feeling,,,unless you over ride this white balance you will never get the color you are after,,, i use 35 mm film for sun sets
it will wip a digital camera every time here,,
but its horses for corses,good luck with your sun sets,,, but over ride that white balance first if you can
Nov 16, 2009 | Kodak EasyShare Z712 Digital Camera
Sunrise/Sunset Time and Moon Phase wrong on watch!
Just in case you're still interested in a solution. Your watch uses a geographical location and the current date to estimate the sunrise and sunset times. While the date (and time) information is, most likely, set on your watch correctly, you, probably didn't specify the geographical location (latitude and longitude, as well as the GMT correction for your time zone). Having setup correctly these parameters you'll enjoy the precise sunrise and sunset time. Good luck!
May 29, 2009 | Casio Watches
Taking Pictures of a Sunrise or Sunset
In the mode option u select sunrise or sunset noe be carefull while taking the photo the direct sunrays should never hit on your lense get a shade above your lense now try to take the photo without flash
Jan 05, 2009 | Canon EOS Rebel XSi Digital Camera
Intermatic Inc. ST01C Digital In-Wall Timer Logo
162 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Mike
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
