Question about Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
Recently purchyased electrolux 3 door . Had water supply disconnected for approx 8 hrs and now have water back on but ice maker will not make ice
    New Friend:
  • 51 Answers
You have to open the water hose let the water drain for at list 2 to3 minute so you can have the water line free with air package, and close backthe water hose
Posted on Oct 24, 2010
SOURCE:
Electrolux Ref. 3yrs old. ice maker will not make ice, water dispencer will work. I have replaced filter.Ice maker goes through the motion but, no water. can you help me?
either your fill tube is clogged or the water valve in the back of the refer has failed. Go to the back of the unit, if my memory is correct the yellow hose is for the ice maker, at the water valve disconnect the 1/4 hose from the valve to the ice maker only, place valve in a bowl, cycle ice maker. If you get water, fill tube is obstructed, if not water the valve has failed and needs to be replaced.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 28, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Ice maker wont make ice
Is water getting into the ice tray of maker? If not check for the water solenoid's proper operation. Is freezer temp at least 10 degrees or less? If not, the ice maker will not work. If ice in tray then perhaps the heater element is not working to melt it a tad ans allow the fingers to pudh the ice out and into the tray.
You can get those suckers for about 40 bucks new on ebay eBayeBay
Aug 30, 2017 | Star Manufacturing GE Profile PFSS5PJX...
We have an Electrolux S/S side by side w/Ice&water though the freezer door. The water flow through the door has been inoperative for several months but the ice maker continued to work fine. Water...
check and see if there is a built in filter pack inside the back of the fridge or it could possibly be that one of the lines has froze internally and or the open close valve at the water inlet inside has worn out
Jan 18, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
French Door with bottom freezer Electrolux ice maker not making ice and when ice maker on it clunks 8-10 times every few minutes. Water dispenser works fine. Whats could be the issue?
sounds like the drive in icemker head is bad and not turning the timing wheel . the timing wheel controls the harvest and the water comming in ect . best to replace the icemker with ther kit . come with instructions . mm hope this helps . if more info needed i need the model # and ser of your unit .. feed back pls ..
Dec 11, 2010 | Electrolux Refrigerators
I have a brand new French door electrolux refrigerator. It was just delivered today. The water dispenser doesn't give cold water - just room temperature. It's only been plugged in for 8 hrs but I...
We have had two different Electrolux French door refrigerators, over the past 2 years and the water never becomes cold. We were told this is because the the storage tank in this particular refrigerator is so small. You just have to drink your water with ice. Unfortunately, we have had recurrent problems with the ice maker as well! Sorry - but these refrigerators are very problematic and I would not recommend them to anyone!!!!!!
Sep 12, 2010 | Refrigerators
I have a Kenmore side by side elite. I have installed a new ice maker. I can not get water into the ice maker. The extraction teeth rotate and I get water through the water port on the door but not into...
Usually happends that the solenoid (electric valve who opends when the ice maker calls for water) leaks and this water freezes up inside the filling tube for the ice maker , t he solenoid has to be replaced.
Sep 20, 2009 | Refrigerators
Kenmore Ice Maker Not Making Ice
the water that is frozen in the fill tube could have come from the old water valve that you replaced ,you got to get the ice out, the easiest way ,though not the fastest ,is to unplug fridge for 24 hrs . and leave the doors open to let it defrost, the plug back up and hopefully in 5 or 6 hrs you'll have ice
May 20, 2009 | Freezers
Ice maker leak
sounds like you have a bad water valve,if the ice maker is disconnected and water is still filling the ice maker cup the valve is bad
Aug 19, 2017 | Electrolux Frigidaire Professional Series...
Electrolux Icon ice maker stopped working.
HI. Whenever maintenance is done on the water system there is a chance that rust and other debris will break loose and move into the pipes in the house. The tube that feeds the icemaker is only 1/4 inch and easy to block. There is often an inline filter in this tube which feeds the water into the ice maker.
Begin by raising and lowering the wire arm inside of the ice bucket as this will jar the system a little bit. this alone may get the water flowing again. If not, look in your owner manual to see about the location of a filter in the ice machine supply line. If there is a filter, check it. If not you may need to disconnect the supply line where it hooks up to the refrigerator in the rear of the unit to see if the water is flowing to that point. good luck.
Feb 06, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
441 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Felizardo Erilla
Felizardo Erilla
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
