Vestax CDX12, skipping
Hi, i have recently bought one of these players/mixers. its great apart from one small problem. unfortunately the small problem makes the unit unusable in performance. the problem is a glitch in the sound, it is the smallest crackle in the sound which puts the decks out of sync. i have checked all the wiring external to the unit. the problem persists.
what do you advise?
I have one, I bought as a open-box item. Once I suddenly noticed the entire conducting surface for a CD output was missing. I never repaired it but perhaps the solder is weak on these. They are also exposed to rough handling often. When you solder go light if you aren't experienced
Posted on Sep 04, 2008
Why won't my vestax vmc 002 turn on
Try replacing the fuse by one with same voltage and rating. Usually if you take a look at paperwork that came with the mixer it will show you which fuse you should use.
Jan 05, 2013 | Vestax Vmc - 002 Xl
Headphone channel is broken, outputs fuzzy, needs service
I'd try this company: I had good service from them and I live in Canada. They are in Rochford Essex.
May 14, 2010 | Vestax Pmc 280 DJ Mixer
Vestax pmc07 pro powers up, but no output through amp or phones????
most likely one or some of the op-amps are blown. you are using the right ac adaptor too? sometimes when underpowered it will give a low output. also are you getting a read out on the vu meters? if so then most likely the op amps. if there is no read out on the vu meters, it could be the input stage. have you also tried your mic and aux in too?
my suggestion is, that if its under warranty get it fixed.
Aug 30, 2009 | Vestax Pmc07pro DJ Mixer System
White noise in left channel on my Vestax PMC 06 pro-a DJ mixer
try it with nothing plugged in to the inputs, if there is no noise. most likely its the turntable, cd player, or whatever the input is is the problem. or try plugging the mixer into a different area of the house/room. its like if you were to put your cell phone by a mixer, or speakers.
Jun 25, 2009 | Vestax Pmc07pro DJ Mixer System
The headphone jacks on my mixer(Vestax PMC-06 Pro A)not working
did you try the headphone jack in the back? also is the cue fader crackling when you move it left and right? also check if the cue fader is plugged in. if none of the above, check with your warranty
Apr 14, 2009 | Vestax Pmc06proa Thin DJ Scratch Mixer...
Vestax pmc-o5 pro 2
probably just a cold solder joint on the power plug inside the mixer. Check with a meter, then repair(resolder) if needed.
Nov 24, 2008 | Vestax Pmc07pro DJ Mixer System
Vestax pmc 06 mixer / Virtual DJ Mix station
you need a sound card with headphone out seperate from master out
Oct 19, 2008 | Vestax Pmc06proa Thin DJ Scratch Mixer...
Samsung HLN5065W freezes in black / White screen
Picture freezing that is the symtoms of depected DMD modules...
Just click below for electronics store you can order online;
Vance Baldwin Electronics
Hope this may help;
Aug 21, 2008 | Samsung HLN5065W 50" Rear Projection...
JVC KD-SH99 Skipping
try cleaning the lazer lens, also remember it is old and is most likly toast., the longest I ever owned a deck that didnt go out was 4 years.
Nov 12, 2007 | JVC KD-SH99 CD Player
406 people viewed this question
