Question about Maytag Neptune FAV6800AW Top Load Washer
Dc error message - Maytag Neptune FAV6800AW Top Load Washer
  • 526 Answers
Most of the time this is a Clutch malfunction could be a TDS issue
I don't offer support anymore at this forum. If no one has a fix for you here Google Maytag Neptune load unbalance and open up a post at that forum and I will help you to DIY or point your service repairman in the right direction to resolve this issue.
This is an easy fix for most DIY folks and very difficult for most repair folks due to lack of hands on knowledge of the machine which had a short production run.
Posted on Oct 28, 2010
SOURCE:
60.20 error
The tray 2 lifter-motor is not functioning
Unfortunatly this usually requiers parts
1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness is full seated in its connector on the dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver assembly
-If the unit is still clicking/banging with a new lifter replace the tray -If the unit is still clicking/banging with a new lifter and tray see step 5 5 Replace the dc controller PCA.
Apr 22, 2014 | HP LaserJet 4350dtn Printer
51.20 error message
It's a black toner laser problem.
1. Press the "check mark" to continue.2. If the message persists, turn the printeroff and then on.3. Reseat DC controller connectors J1010,J1012, and J1021.4. Replace the flat cable.5. Replace the DC controller PCB asnecessary.
If you never worked on printers before, ignore steps 3 + 4 and get someone toreplace the DC Controller.
Sep 27, 2011 | HP LaserJet 3800 Printer
I want to know what the problem 59.CO message on my printer Laserjet colour 5550 and how to get it solved
59.XY PRINTER ERROR
A printer motor error has occurred.
(C)= developing disengaging motor rotation error / (0)= no color/black
Developing disengaging motor error
1. Reconnect the connectors J16 for the developing disengaging motor and J1100 for the DC controller PCB.
2. Replace the developing disengaging drive assembly.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
Jul 13, 2011 | HP LaserJet 5550 Printer
Sir, i have hp laserjet colour printer CP5225, having error 55.0601. Kindly give me online solution
this all i manage to find for hope it helps
55.x Error
Error Message
55.X Error
Turn off then on
Description
The printer has experienced an internal error. The printer may experience one of the following errors:
55.0 DC controller communication error
55.0601 DC controller NVRAM data error
55.0602 DC controller NVRAM access error
55.1 DC controller memory error
Action
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the printer to initialize.
If a surge protector is used, remove it. Plug the printer directly into the wall socket. Use the power switch to turn on the printer.
If the message persists, contact HP support.
You need to first check the connection between the dc controller and the formatter and if the connection is fine you need to replace the dc controller.
Dec 22, 2010 | Office Equipment & Supplies
I received an error message for lmy HPlasejet Printer 58.3
Fan Motor Error. Fan Motor 3 (FM3) is defective.
Switch the printer off and then back on. If the error continues:
  1. Check cabling between fan motor(s) and DC Controller PCA.
  2. Replace the faulty fan motor.
  3. Replace the DC Controller.
Nov 08, 2010 | HP LaserJet 4mv Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
DC error message
tonite while driving on a bumpy road i had the dc error right after a big bump.
according to user manual,
one of your speakers connector got lose and is touching the metal body of the car giving a shortcut
-> check your speakers wiring
May 16, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Help:D
At the start of a device BenQ DC E610, after the release of the target, the message "System Error 0010" will appear and the digital zoom will retract
Apr 28, 2008 | Cameras
Error message 06 appearing, I can't clear this eero, please help.
remove the battery for some 1 day and then try .. if you have connected the dc plug into the jack remove that also ....
Feb 11, 2008 | JVC Cybercam GR-D30 Mini DV Digital...
Maytag Neptune FAV6800AW Top Load Washer Logo
47 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
