Question about HTC PPC-6800 Smartphone
Htc mogul keeps freezing
The phone will be on. The screen will be lit. But the phone will freeze up. No phone calls come through, no emails, texts, anything...
I will have no idea that its frozen until I try to use it. I have to reset it and then it will do it again a few minutes later. Swapped the phone out 4 times and it keps doing it???
And help u can offer ??
  • 2 more comments
  • rauqs Jun 17, 2008
    mine is htc 6800, not able to get the calls when its screen is off,after turning on the screen , then its showing only the last two calls.
  • SOLDBYAPRIL Nov 18, 2008
    RRRR I AM HAVING THE SAME PROBLEM!! THEY HAVE SWITCHED MT PHONE SEVERAL TIMES
  • sean980 Dec 24, 2008
    did it does not work can you help with code
  • t_i_gg_errr May 10, 2009
    I have 2 of these phones...and since upgrading the software mentioned below...I have had nothing but problems. Both phones constantly freeze up and I have to pull the battery out 2-5 times a day.
    Tried to move all applications to the Micro SD chip...but nothing I have done has solved this problem.
These days they arent making the moguls anymore, and many of them have been reported as having problems. With that said, i was able to bring my phone in to a service store and they were able to order a new one for me free, but since they arent making moguls, they'll actually give you a TOUCH PRO!! much better phone in my opinion. They asked me if i had insurance, i do, but i hope that doesnt affect any of you. moguls ****...=(
Posted on Jan 25, 2009
    Problem Solver:
  • 11 Answers
Update it take off all unsecure apps and if it keeps freezing i can give you a code but it depends on your sp if the code will work
Posted on Jun 09, 2008
I have found two things to keep the freeze from happening. 1. Do not let your memory run over 80% for extended times. It seems that the activesync will ghost and then lock up memory. 2. No more then five voice tags. More than that and there is no hope from freezing up.
Posted on Aug 29, 2009
  • 20 Answers
A new phone wont correct this, but there is a simple fix.
Go to www.htc.com/us (htc.com will NOT have it) and click the support tab, find your phone, and click software download. There will be a tutorial on there if you're not familiar with updating it. This software update fixes bluetooth connectivity issues and the hibernation issues (missing calls/texts and not powering back up from hibernation). If there was actually something as simple as a code to fix it, it would have already been suggested to you or done by the reps before that switched it out
Posted on Jun 16, 2008
Touch Pro Smartphone: My htc freezes, wont allow me to access the intern...
back up all your data...try soft reset first...if it doesn't help...hard reset via
http://bit.ly/bjIg1v
May 06, 2010 | HTC Touch Pro Smartphone
My HTC Mogul Smartphone Does not turn on.
i think your phone is pretty much in sleep mode and mine does that also, all i do is press the top small button on the right side of the phone and the screen comes back
Feb 21, 2010 | Cell Phones
HTC s620 freezes with incoming texts
I suggest take it to a service center store that deals with your service carrier and request to have it flashed. Keep in mind that you have to backup all of your info in that phone since the "flash" is going to delete it all. Good luck.
Jan 03, 2010 | HTC S620 Smartphone
Sprint HTC Mogul Freezing
A common problem with the Moguls, do you have a lot of programs installed on the main memory, try to install programs on a memory card, also delete unused files and move what you can over to the memory card. It helps to close programs completely instead of letting them run in the background. Mine froze up a lot but moving stuff to the memory card helped.
Dec 28, 2009 | HTC PPC-6800 Smartphone
My htc 6800 contnues to freeze up
i would suggest a master reset, hold both soft keys and then hold reset button on bottom by memory card,
Jun 25, 2009 | HTC PCMICROSTORE Brand Mogul XV6800...
My HTC Mogul keeps freezing, wont even get past the main screen when I start it up, I loaded a larger file onto it and started it up, since then it hasn't worked. Anyway to do a hard reset by hand without...
you can try a hard reset. Hold down the left and right softkeys (the two buttons above the windows button and the ok button) and use the stylus in the reset button (bottom of phone just below the sd slot) This will erase verything off your phone, but should fix the problem.
Jun 16, 2009 | HTC PPC-6800 Smartphone
Screen keeps freezing
The Firmware need to be reflash on the phone to correct this issue
Nov 20, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Phone keeps freezing, cant even get to the main screeen
I had the same problem whenever i tried to type... i fixed it by going into settings then input then word completion and then i cleared the stored entries ... if that doesn't work u can try un-checking the suggest words when entering text box ... Hope this helps
Nov 10, 2008 | HTC PPC-6800 Smartphone
Touch screen is freezed
whilst the phone is on take the back cover off and disconect the battery this should reset the phone , replace the battery and start as normal. Also the phone slows down if you have not deleted your text message inbox,sent box, deleted box so keep on top of that and clear your cookies if you been on the internet.
Oct 08, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Verizon Razr freezes
emptied your text messages lately? this used to be a problem with the old v3c and verizon.
Aug 22, 2007 | Motorola Mobility RAZR V3m Cellular Phone
HTC PPC-6800 Smartphone Logo
1,417 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
