Question about Canon Office Equipment & Supplies
Close the feeder cover, cover is closed. mx340 printer
    Brigadier General:
  • 3,513 Answers
For this error message the main cause is documents remain in the ADF.
Press the OK button to eject documents and press the Stop button to stop ejecting. To continue scanning, operate on the application. The scanning from the ADF may not be supported depending on your application software. For details, refer to the instruction manual of your application.
Please check the bellow link to have a general idea related to your issue:-
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=pt&cc=br&lang=pt&docname=c01913520&product=3645097
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Posted on Oct 24, 2010
2 Suggested Answers
6ya staff
SOURCE:
nope663
SOURCE: My printer is a Canon
I had the exact same problem. The Alarm light was always on and the screen said "Document in ADF. When I pressed "OK" it would read "Eject the document". Even after I placed paper in the ADF and the paper would feed the document through it, the error and the Alarm light was still there. I found the solution, Lift the cover to expose the flat bed scanner glass. Under the cover, there is a long white bar with two white tabs perpendicular to the white bar. One of the tabs was retracted. Pull on the tab until it is fully extended. The alarm turns off and there is no longer the error. Simple solution to a damn annoying issue.
Posted on Oct 29, 2010
Paper jam I've cleaned sprayed,etc must be something I can't see w/o going deeper. How do I remove cover to get to paper rollers in MX340
Removing the covers is not the answer. Most jams on rear feed printers/faxes are due to some object falling in the sheet feeder. When you pull the paper back out (Very slowly) of the sheet feeder after it has jammed , you will see a nick in the paper. This is because the paper is hitting something and cant get past it. put the paper back in the sheet feeder and the nick will indicate where the object is. Find a large paper clip and unwind it and bend the top of it to 90 degrees. use this to hook the object out and then tip the printer upside down and watch it fall out. Good luck
Dec 11, 2016 | Canon PIXMA MX340 Wireless Office...
Installed new ink. it says out of alenment
Dennis: According to an old FixYa.com, urbanhookupz said: "You need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
now try and print it should solve the problem.
if it does not prompt you to do a test page
Aligning the Print Head
This operation must be carried out when using the printer for the first time.
Aligning the
Print Head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic Print Head alignment only.
?? Ensure that the Inner Cover is closed.
?? The Print Head can also be aligned from the printer itself.
1.With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2. Hold down the RESUME/CANCEL button until the POWER lamp flashes four
times.
1 With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 28.
3 Print the pattern.
(1) Click the Maintenance tab.
(2) Click Print Head Alignment."
May 26, 2015 | Canon MX340 AllInOne InkJet Printer
Cannon mx340 says document in adf, but there is none, also says close feeder cover, it is closed
I just want to say THANK YOU to nope663 for posting the solution to this problem....I like all the others was frustrated and ready to chuck the printer out of the window. Thank GOD for people like you who are kind enough to SHARE their solution to a problem that could have costed a few bucks to "fix"....
Oct 24, 2011 | Canon PIXMA MX340 Wireless Office...
How do you clear "close document feeder cover"
Open ADF feeder cover find out the sensor location observe is there any breakage, if not insert a peace of paper in sensor, see the messiage..if its remain same it might be a problem with sensor, formatter or cable faulty.. if its gone.. used your brain...close it..best of luck..
Sep 05, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My fax machine on my mx340 keeps telling me to close the cover. it is closed. what does this mean? also, do i put the fax papers in face up or down?
maybe the paper you installed is not in correct position try to invert it then locate the guide on how to replace the paper, sometimes it located on the cover of the printer when you open the cover,
Aug 04, 2011 | Office Equipment & Supplies
My conon printer mx340 says ducuments in adf error
Hi guys,
This error occurs when paper sensor in ADF = Automatic Document Feeder detects some paper inside paper path. Firs, open ADF access cover and check if some broken paper present inside paper path. If no broken paper found in paper path means paper sensor is faulty and you need got new ADF replacement. Thanks
Source:
MX340 Series Service Manual
Jun 27, 2011 | Canon MX340 AllInOne InkJet Printer
I keep getting a close feeder error on my Km Kyocera 1530,how do i go round it
Assuming the feeder is closed and you are still getting the message to close feeder the one of your interlock switches are bad or not making contact.
Each cover that open and closes has a switch to indicate it is closed. Make sure when you close the cover the switch is being actuated.
To find the switch open a cover then start to close it and look for a piece of the cover that is going to line up with a hole in the feeder when it closes, this is normally where the switch is.
If you have a multimeter and know how to use it you can ohm out the switch to make sure the switch is working.
Sorry I can't be more helpful but this machine was not manufactured by Kyocera (it was just sold with their name on it) and I am not overly familiar with it and the documentation is not very good on the machine.
Mar 04, 2011 | Kyocera Mita RADF-11 REVERSING...
My printer is a Canon Pixma MX340 it is showing a error Document in ADF Press [ok] but after pressing ok another error reads Close the feeder cover [ok] eject the document
Sep 04, 2010 | Canon PIXMA MX340 Wireless Office...
Hp officejet 7310
better u disconect ur document feeder wire connection. and than try that.
Aug 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Open Questions:
1,525 people viewed this question
Clive
Clive
old marine
old marine
Ekse
