Question about Black & Decker Black Decker 16" Hedge Trimmer
Trimmer stops with very small twigs, sound is a rattleing.
Why does my B&D strimmer ST5530 use so much line. Once round the small garden and the spool is empty
Sometimes it is due to equipment malfunction, but most often it is due to operator error and underestimating what is needed. Light grass can use a cheaper trimmer with thinner line. Thicker weeds, small twigs, and especially areas around fences, namely chain link, can eat up string quickly if the operator gets too close to the edges and chews up the string. These areas need a heavier duty trimmer unit with thicker string to do the job effectively.
Sep 15, 2016 | Black & Decker Garden
Black decker problem
Be sure something is not obstructing the rotation of the trimmer head. If something like a small vine or twig is jammed inside the head it would make a noise and have very little rotation. If the motor brushes were worn you might get the same symptoms.
Aug 23, 2014 | Garden
What's the role of the "power screw" ????
To adjust clipper/trimmers to run to their voltage needs. If clipper/trimmer rattles or over vibrates it may need adjustment to the line voltage in your area. Before adjusting, make sure the clipper/trimmer is clean and blade is oiled. Then turn the SMALL power screw clockwise on the side of the clipper until the noise disappears.
Mar 14, 2011 | Andis 01690 Hair Trimmer
Motor will make a sound , but will not pump any water
it sounds as if you may have something jammed in the impeller blades, if you have small kids, look for small toys (leggos, plastic wrenches, etc) stuck inside the input tube or the blades themselves.
PLEASE turn off power first and drain (if needed). the pump housing should come apart with a screw driver, but you MAY need tamper resistant bits and a bit driver. if no kids, then look for small debris like twigs or such ( I have even found bottle caps in some units that I've taken apart!!).
Nov 18, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
My sst25 starts hard and stalls...seems to be sensitive to engine position before stalling...stalls when throttle is opened and when just runnung
Had the same problem with my SST25 and after looking further, noticed something rattling around in the fuel tank. The fuel filter had fallen off of the small fuel line (actually the small fuel line had broken). Removed filter from tank and small piece of broken line from filter connector, and re-connected to small fuel line.
Jul 11, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Bought it today, it just stopped working. Worked beautifully for about 30 minutes. I would think something is caught in the blades, but that doesn't appear to be the case.
Check the blades very carefully! There can be a small twig, wire or most anything in there. Also, plug it into another extension cord to make sure the one you were using is okay. Good luck...Lee
May 29, 2010 | Black & Decker 3.8 AMP 22-Inch Electric...
2005 ford focus makes load noise when heater fan is on???
Maybe a stray leaf, twig or other small object has been sucked into the ventilation duct, touching the centrifugal fan.
You need to pull off ducts around fan and inspect.
Nov 17, 2017 | 2000 Ford Focus
I have a Black & Decker electric trimmer. Do I change the guard around or leave it where it is to do trimming? It is on the bottom--should it be on the top and how do I switch it?
You are talking about a string tirmmer, right? Leave the guard where it is; it's there to protect your feet and legs from getting hit with twigs, rocks...anything the trimmer might kick up.
If you are using it as an edger you can keep the guard where it is, just flip the trimmer to do the edging.
Sep 13, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
Washing machine makes a loud rattling sound
Hi.k.
Even though you have cleaned filter, there could still be something in the pump, you need to remove the pump and check there is nothing in it.
Hope this helps.
Good luck.
Please leave feedback
Nov 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Black & Decker Black Decker 16" Hedge Trimmer Logo
78 people viewed this question
Top Black & Decker Garden Experts
gggg
Nick Olsen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
