Question about iRobot Roomba 550 Vacuum
My 550 roomba will not go forward or dock. It just turns in circles and occassionally moves backward a few inches.
SOURCE:
SOURCE: my roomba starts going backwards
I turned my shop vac onto "blow" and blasted my roomba with this problem. It worked!!! I had already cleaned it thoroughly, but it needed to be blown out. My only regret is that I did it in my shop, rather than outside. It was pretty dusty.
Thanks again for the tip. Saved me $100+
Posted on Dec 10, 2008
  • 61 Answers
SOURCE: Dont move forward.
Blow out the unit with compressed air, particularly around the wheels and under the bumper. Tap the bumper with your hand.
If your Roomba stops and beeps at you, count the beeps AFTER the initial "uh-oh" tone. Then call customer support (1-877-855-8593) for assistance.
Good luck.
Posted on May 29, 2009
emissionwiz
  • 85178 Answers
SOURCE: Roomba only circles back and forth in a very small
either the infrard sensor is defective or the steering is defective
Posted on Jun 29, 2009
  • 4088 Answers
SOURCE: backs up spins in circles, then red light flashes and beeps
Sounds like either the battery is bad or not being charged properly with subsequent loss of programming.
Posted on Jul 23, 2009
pappapumpdaf
  • 635 Answers
SOURCE: my roomba won't go forward it just spins in a
You will need to take the top off to clear those wheels.
This happens a lot when cleaning new carpet. The fuzz jams the wheel switch, and dosey do you go.
Posted on Mar 11, 2010
Roomba just turns in circles what could be wrong
What to do when the Roomba just goes in circles ' All about Roomba ...
https://roombafan.wordpress.com/2015/05/17/roomba-just-goes-in-circles/
May 17, 2015 - Single beep - Roomba is stuck or wheel is hanging down; you need to move your Rhoomba to a new location or check the wheels. Two beeps - this happens when the main brushes become immovable, so you need to check the brushes. Six beeps - the likely cause is a dirty cliff sensor or the robot is stuck on a cliff.
Roomba is backing up and circling. - Find Answers ' iRobot Customer ...
https://homesupport.irobot.com/app/answers/.../roomba-is-backing-up-and-circling. If Roomba backs up or spins in circles, run Roomba in an open area with no obstacles present for 2 minutes to determine if the robot will stop with an error ...
SOLVED: The Roomba just goes in circles, how do I fix this ...
https://www.ifixit.com/.../The+Roomba+just+goes+in+circles%2C+how+do+I+fix+this Oct 23, 2016 - Dirt and debris can cover the sensors and make the roomba believe it is ... When my Roomba turns on, it will only spin around in circles and ... Won't go straight; not circle of *****
May 30, 2016
Vacuum will not go straight
May 7, 2013
SOLVED: roomba 560 got wet and now it doesnt go forward ...
May 15, 2012
SOLVED: When I turn my Roomba on, it doesn't go forward ...
Apr. 25, 2011
More results from www.ifixit.com
iRobot Roomba circle dance - "fix" - YouTube
? 5:37
https://www.youtube.com/watch?v=sN03AWr1VAk Jan 21, 2008 - Uploaded by Scubaholic
Didn't feel like open my roomba at 10pm, so I just sprayed it with some canned air around the wheels and ...
Help! My Roomba goes in circles! - Robotic Vacs
https://robotic-vacs.com/2016/03/03/help-my-roomba-goes-in-circles/ Mar 3, 2016 - What to do if your Roomba just goes in circles. Roomba goes in circles. No, your Roomba doesn't have a mind of it's own, nor is it tipsy from ...
May 20, 2018 | Roomba Vacuums
My iRobot Roomba 780 just won't start moving to do the cleaning. When I press the CLEAN button it moves back from the dock, turns 180?, and then moves forward about an inch and makes the uh-oh sound...
make sure all virtual wall lighthouses are turned off. Your Roomba may be getting a signal to not proceed if the lighthouses are turned ON and facing the Roomba
Feb 22, 2014 | Roomba 780 Robotic Vacuum
560 moves away from dock appears lost
hey gsaban
does it sing 9 beep when it stops ?
if it does, you are facing a known issue of bumper sensor fail.
See this page and other 9 beep threads on FixYa
have fun
Avi
Mar 12, 2010 | iRobot Roomba 560 Robotic Vacuum
Moves in circles and backwards, though will not move forward
Sounds like your bumper switch is stuck. try pulling on the bumper to free it, then clear any obstructions you find.
Mar 07, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Backs up spins in circles, then red light flashes and beeps
Jul 23, 2009 | iRobot Roomba 500 Series Virtual Wall...
Running backwards in circles.
If your Roomba's speaker isn't working, you need a new Roomba regardless. Give a call to customer support (877-855-8593) and they'll help you out.
Jun 10, 2009 | iRobot 4150 Roomba Vacuum
Roomba going backwards
I had the same kind of problem with my model 400 today...after starting it and having it go in a circle for 30 seconds or so it would finally run into something and then back up a few inches, turn, then go forward a few inches, then back up a few inches, turn, then go forward a few inches, etc., etc.. I tried cleaning off the four pairs of sensors under the bumper and blowing out various things underneath (by mouth since I didn't have any canned compressed air). It didn't really help. It then occurred to me that I had a leaf blower! I put the Roomba upside down on the grass, put the leaf blower on high, and blew at it from all directions and up close. More dust came out than I thought would. It has been running normally now for the last 45 minutes.
Aug 11, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
My roomba starts going backwards
Apr 18, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
IRobot Roomba Discovery not moving across room.
Sep 26, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
iRobot Roomba 550 Vacuum Logo
66 people viewed this question
Top iRobot Vacuums Experts
Oliver Street
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
