I pod got the red x i managed to get it back to the normal menu screen but then my i tunes couldnt read the i pod and said it might need to be restored. So i clicked restore then it said that i pod could not be restored and that error 1439 has occured. But it also erased all my videos and music on my i pod after this. So i got a i pod that works but has nothing on it and cant connect to i tunes.
  • 4,924 Answers
Reset it from the reset button ..and after that remove the battery and all and than try again ....Probably the computer just do not recognize it for some reason ...and in this case change the usb plug ..
http://www.reset-ipod.com/
If it has some driver that allows it to connect ...just run the driver again ..cause it might be damaged in the process..or be from the first place damaged and this caused the malfunction..
Posted on Oct 24, 2010
SOURCE:
I reset my ipod touch but the screen appear with itunes icon and usb connector
The OS (operating system) of your ipod is corrupt for one reason or the other. The ipod won't boot or start because the start-up file or necessary files needed to boot up the ipod are corrupt.
The solution to the problem is to re-installing the OS (operating system) of the ipod by restoring the ipod. To achieve this, you will be needs a USB cord for your ipod model and i-tunes installed on your computer. Once you have i-tunes installed on your computer and a USB cord, then the job will be done and your ipod will be back to normal again.
If you don't have i-tunes installed on your computer, go to www.apple.com
Click on i-tunes and download i-tunes for free, then install it on your computer. After installing and downloading i-tunes, follow the below steps:
Run the i-tune program on your computer
Connect the USB to your I-pod
Connect the other end to your computer
Wait a while for the computer to recognize and install the ipod, then read and follow instructions on the i-tune. It will ask you to restore your ipod.
But if the i-tunes doesn't recognize the ipod via your PC, press and hold the Power button and the home button for 5 to 10 seconds. Leave the power button and keep pressing the home button or vice-ver-sa till the restore option comes up.
Click on restore and follow instructions thereafter.
After the whole restore process, your i-pod will be back to normal again.
Note: Make sure you back up your ipod if the files on it are very important to you. Start by syncing your iPod with your computer. When you do this, the iPod management screen will appear. Midway down that screen there's a button that reads "Restore."
Please let me know if you need further assistance.
Good luck.
Jan 16, 2012 | Apple Audio Players & Recorders
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Ipod nano 2gb cannot be synced required disk
1. Run "c:\WINDOWS\system32\devmgmt.msc" (this is the Device Manager), this will need to be used later, but you'll need it quickly when you do.
2. Start i Tunes
3. Connect i Pod
4. Go to your i Pod Settings and select "Enable disk use"
5. A dialog box will pop up reminding you that you'll need to manually eject. Hit OK
6. Hit Apply to save changes to the i Pod
7. Quickly switch to Device Manager window and right-click on any item there and select "Scan for hardware changes"
8. Switch back to i Tunes, where you should have a nice, working i Pod!
Let me know, if problem still persists.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 27, 2009 | Apple iPod nano
Cannot get my i pod to show the menu. Can't get out of shuffle
The problem was solved by going to i tunes and connecting the i pod. Then I hit the restore button. That seemed to do the trick.
Apr 10, 2009 | Apple iPod mini M9160LL/A MP3 Player
Cannot put movie from i-tunes on 3rd geneation i-pod nano
I just had this issue- I bought a movie off iTunes, and could view it on the computer, but it wouldn't go on to my iPod. I looked around and found instructions to open iTunes and on the home page of your iTunes where it shows you how much space you have, you can restore original settings, etc., if you click on "manage iTunes manually" or "manage music and videos manually" and then click apply you will be able to move your movie on to your iPod. In your iTunes library you just have to drag and drop the movie onto the iPod icon that appears in the left menu when your iPod connects to iTunes. It took about 10 minutes for mine to fully upload onto my iPod- so make sure you wait to disconnect until it tells you to. I hope this helps! What I read is that when managing the music and videos manually instead of it doing it automatically, you can move the videos and music as you'd like.
Jan 03, 2009 | Apple iPod nano
I pod nano
open I tunes, plug the i pod into the computer, when the i pod shows up on the left hand side of the screen, right click it and you should get an option to rename it
Sep 19, 2008 | Apple Mini IPod
Grays songs in ipod when connected to Computer
You need to set your iPod to update manually, instead of syncing automatically when you plug it into the computer.
To do this, plug your iPod into your computer, and on the iPod info screen that pops up in iTunes when your iPod is connected, click "Manually Manage Files."
You'll now have to click and drag your songs from your library to your iPod, but now you can also play songs on your computer directly from your iPod and delete songs from your library without deleting them from your iPod at the same time.
Hope this helped!
Sep 05, 2008 | Apple iPod MA446LL/A MP3 Player
Miissing e drive
Try updating or reinstalling iTunes.
Jan 02, 2008 | Computers & Internet
Ipod nano problem
hello blair,I Have my own I-pod so I hope this will re asure you. First I think you should restore your I tunes as long as your brother has your songs too. Then ask him to create a CD of all your songs, which is not hard at all. then take the CD and open I-Tunes. Place the CD into your hard drive and I-Tunes should pick up the CD. Then download the content of the CD onto I-Tunes. You Will Now have all your songs on I-Tunes like before. Now plug in your I-Pod and continue like It's the first time you have pluged in your i-pod! hope this helps! Rosebetts xxx
Dec 29, 2007 | Audio Players & Recorders
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
