Question about LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T...
My fridge keeps stopping and i get an er message on the display the fuses look fine thanks
    New Friend:
  • 51 Answers
The thermostat may be malfunction, may need freon, may be overloaded,also may have a bab start relay
Posted on Oct 24, 2010
SOURCE:
Hi, my side by side LG SXS fridge has no cooling on the fridge side and 60% freezing on the left. The error codes on the LCD display is Er and dS. Is there internal fuses. Thanks Todd
Er/ds=Failure of defrost sensor or there is a cut of short in circuit wire. You would have to use a multimeter to perform continuity tests on the sensor to assure it is working with the sensor and the machine unpluged. If you have any further questions message me back I await your reply.
Thanks again,
Rick
p.s if you have any further questions please also include the full model number of the unit so that I may supply a schematic for you as well showingg the location of the sensor in your unit.
Sep 24, 2011 | LG Refrigerators
Westinghouse Model WSE6070WB*5 Error code: Cn Er
I recently had this message on my Westinghouse fridge. The CN and ER message stands for Connection Error. This is due to a power surge.
I suggest you disconnect the power cord from the powerpoint and switch off for 5 minutes.
When connecting, if you have a double power point use the other head as the initial one may be faulty and this may have caused the power surge.
Hopefully this will fix the CN ER message to disappear.
Jan 22, 2010 | Westinghouse Refrigerators
Kenmore Elite Trio Fridge - Getting ER F5 error on display
Er-FS error code: Failure of freezer sensor.
I have been finding the fuseable link in the defrost system on these models open preventing the defrost cycle.
This would involve removing the freezer back panel and removing the sensor and fuse from the evaporator.
It's just a plug in.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 23, 2009 | Kenmore 73503 Stainless Steel Bottom...
Digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigertor isn't cold at all
Hello sewing6
Welcome,
You said,
digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigerator isn't cold at all
Try turning the fridge and the freezer off at the controls.
Then turning off the breaker for the fridge for 5 minutes .
then turn the breaker back on and restart the fridge and freezer!
This should reset the system and solve your problem.
let me know how it goes.
Thank You,
Huuum
Please remember to leave a rating! Hopefully a "solved "one.
Oct 12, 2008 | LG Refrigerators
Where is this fuse located on the LG refrigerator is displaying a ER DH code error
GO TO SEARS .COM ,CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND YOU WILL FIND WHERE THE PART IS,LET ME KNOW-MIKE
Jul 07, 2008 | LG LRFC25750 Refrigerator French Door
LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 13, 2008 | Refrigerators
LG LRFD25850ST gives ER CO code on door
There is a communications error between the control board and the display board.  Check the connector located on the top hinge cover.  Remove the hinge cover and check to make sure the connector is tightly secured.
Apr 12, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Hi. You have an Error Defrost Heater. Its taking too long for the heater sensor to open the circuit during defrost. You normally replace the heater, heater sensor and circuit board(motherboard) located on the back of the refrigerator in this situation. Check your mollex plugs and make sure they are connected tightly at the evaporator coil area. Sometimes they come loose. I reccommend replacing the heater and heater sensor located top right on the evaporator coil. This should take care of the problem. Need parts see me on ebay as user, themackshack. Good luck, Mack
Jan 02, 2008 | LG LRBC22544 Bottom Freezer Refrigerator
LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Logo
120 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
