Question about Garden
I was tightening the bar and gave it too much torque. I snapped the threads off. Can it be fixed?
    New Friend:
  • 41 Answers
Yes . first you my have to take the bar and chain off I am assuming the tighting screw is on the front but it dose not matter realy get the bar off so you have acess to the broken screw it there is enough left you can get ahold of it with vice grips then it is just a matter of unscrewing it if not you will have to drill the center of the screw and use what is called an easyout to remove the screw a good saw shop should be able to do this in under a hour and at minimal charge
Good luck
Posted on Oct 24, 2010
SOURCE:
2008 mercury milan how to remove the spark plugs
You will need the correct spark plug socket, a short extension bar and a ratchet.
*Do not remove more than one spark plug or plug wire at a time.*
Use the extension bar to get the socket into place. It should grip the plug when seated properly. Using the ratchet apply even, firm pressure and the plug should unscrew. The plugs shouldn't be in too tight. Don't use too much force as plugs can snap or strip out the threads in the cylinder head.
Refit the spark plug 'by hand' to make sure it is seated in the threads properly and turn, again by hand, until you feel it grip. Try using the extension bar like a screwdriver. Use the ratchet to tighten the plug until it gets tight then STOP! It should be less than one full turn. Refit the plug lead THEN move on to the next one. If your using a torque wrench it should NOT be tighter than 25Nm (18ft\lbs).
Aug 03, 2018 | Mercury Cars & Trucks
Free answer "93 Lexus head bolt torque
it means that after the initial torque setting of 25 ft/lbs you put the torque wrench away and use a socket and bar to move the head of the bolt the required number of degrees as per the angle gauge that you will fit over the head of the bolt
so select the first hard stud and torque to 25 ft/lbs
repeat this to all the other head studs in the pattern required to achieve even tightening of the head
put the torque wrench away and fit the angler meter (gauge) on the 1 st stud and tighten to 60 degrees as indicated on the gauge
repeat the process for all the head studs as per the tightening sequence
then start again and tightened again another 60 degrees and so on
modern engines use degrees to achieve the correct stretch of the bolts to get the prescribed crush on the gaskets
this is because engineers found that dry threads , dirty threads and dirty stud holes do not give repeatable tensions on all studs.
May 19, 2015 | Lexus Cars & Trucks
What is the torque on stut bolt
strut bolt? the two bolts attaching the knuckle to the strut.
If no one knows, I would advise about 100ft-lbs.
Apr 30, 2015 | 2004 Ford Escape
What are the torque values for 1998 BMW 318ti top end?
please explain what you mean here ,do you mean the head bolt torques then my alldata book is giving one of them silly answers of tighten to 20nm and then slacken 90? and tighten 70? ,well sorry but the engines are built like this on the assembly line ,where all the head bolts are tightened at once .So ignore this answer and do seat of the pants my old fashioned way ,pull down in order ,middle working outwards laft then right one at a time and pull down with a rachet first then run over with the torque wrench set at 60lbs then third pass at around 75 although i never use a torque wrench just a long snap on knuckle bar till i get two quivers in the wrist forearm muscles .Yes i know the experts will squirm at this but they never fail ,i never snap a head bolt and even a slightly distorted alloy head will pull up level again.Well what else do you expect from a ageing old truck fleet fitter who has worked on big fleets of trucks where the game was keep the costs down unlike a dealership where its all about using as many bits as possible to keep the profit margins up .
Apr 04, 2013 | Cars & Trucks
Aveo noise when turning and breaking
Sounds like the wheel nuts are not fully tightened on the wheels.I would check that first.Some shops use a "torque" bar when tightening wheels which can result in loose wheel nuts due to rusty/tight/damaged wheel stud threads creating a false torque reading and loose wheel nuts.
Apr 28, 2017 | 2005 Chevrolet Aveo
The thread keeps on snapping when i sew straight stitch?
try changing the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
try adjusting the top thread tension-to see if the tension is too tight
rethread the machine--top & bobbin just in case the thread is caught some where
check to make sure there aren't any burrs on the needle plate
Jun 05, 2012 | PfaFF Sewing Machines
Torque for head for a 2.5 for an 1985 Buick Skylark
Loosen Headbolts in this order:
1 5 4
3 6 2
Tighten Headbolts in this order:
3 1 6
5 2 4
Following the tightening order, torque Head Bolts as following:
1. Torque All to 22 Ft Lbs
2. Torque all to 51 Ft Lbs
3. Loosen all 180 degrees
4. Loosen all 180 degrees
5. Torque Center Two bolts to 25 Ft Lbs
6. Torque Outer 4 bolts to 11 Ft Lbs
7. Tighten all bolts 90 degrees
8. Tighten all bolts 90 degrees again
Make sure you tighten all of them down the first 90* and then go back and tighten them another 90*. Also make sure you put some lube between the bolt and the washer, and put some sealant on the bolt threads. Use GM Thread Sealant.
Jan 14, 2011 | 1985 Buick Skylark
DRIVE AXLE TORQUE SPEC FOR 1963 BUG
please be more specific as to what exactly your trying to tighten ?' do you mean the drive shafts ?? if so put some locktight on the threads first ,failing that some contact adhesive will do ,if you mean the big nuts in the middle of the wheels then make sure you have some copper grease on the splined shafts before you start ,then tighten the big nut to about 90 , no torque wrench then tighten with a rachet and using regulation snap on bar a **** on the bar will suffice they do not have to be tightened with a scaffold pole on the end of the bar
Mar 19, 2010 | 2001 Volkswagen Beetle
Torque specs on headbolts 95 taurus 3.8 litre and sequence
cast iron heads ,about 85lbs alloy heads 70lbs ,sequence start in middle and then one bolt to left and then one bolt to right ,just keep going left to right tightening them and you cannot go wrong ,pull down with a rachet first then a nice snap on bar ,i never use a torque wrench i feel the stretch on the bolts ,but thats me so use a torque wrench
Mar 18, 2010 | 1995 Ford Taurus
What is the correct torque for spark plug installation?
Plug torque is not critical. Best way to tighten them is to run them in finger tight to make sure the they are not cross threaded, then tighten enough that you feel the gasket crush. (plug bottomed and just a bit more).
It is essential that you use anti-seize compound on the threads. That will prevent the plugs from seizing into the heads and snapping or tearing the threads out when removing the next time.
Jan 03, 2010 | 2005 Jeep Liberty
Garden Logo
18 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
