Question about Refrigerators
3 phase motor - Refrigerators
    New Friend:
  • 51 Answers
With 3 phase motor you could have many difference probems but you did not mantion any problem with your question
Posted on Oct 24, 2010
SOURCE:
I have a Ingersoll Rand Compressor model# 2545E10V 10 HP,3 phase and I would like to convert it to a signle phase. would this motor here be good to go with and what other items will be needed to complete...
It might. Mounting holes match? Shaft diameter and adapter match? Power supply sufficient for 5HP motor? It's a big motor! You might get a better answer from the ebay supplier.
Mar 05, 2015 | Ingersoll Rand Air Tools & Compressors
What is hobart h600, single phase or 3 phase?
Not sure if you are asking if an H600 is automatically a single phase or a 3 phase and the answer is NO. Depending on the motor it will be 1 phase or 3 phase application. It will have 4 wires versus 3 wires -- hope that makes sense 3 of the wires are "HOT" on a 3 phase and only 2 are "HOT" on a single phase Motor.
Jul 09, 2014 | Hobart H600 Stand Mixer
How do I reverse a three phase electric motor?
Reversing rotation of 3 phase motors:
CAUTION: Before attempting any repair of electrical equipment verify the power is disconnected to the device.
CAUTION: Three phase motors could potentially be controlled by frequency control systems. It is recommended a trained electrician perform repairs to any electrical system. In particular, consult a trained electrician if the system includes a frequency control system.
Most 3 phase motors can reverse rotation simply by swapping any 2 of the 3 phase wires. A typical 3 phase wiring circuit will include a safety ground wire (usually green) and 3 phase wires, often designated A/B/C, or 1/2/3, or color coded to distinguish each. By swapping the terminal connection of any 2 of the three phase wires, for example, 1 & 2 or 2 & 3 or 1 & 3, but leaving the third phase wire unchanged will reverse the rotation of most motors.
Jun 12, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
How to change a 3 phase to single phase motor
You cannot change a 3 phase motor into a single phase motor because the windings are different in these motors. You need to buy a single phase motor to replace the 3 phase motor.
Sep 16, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
Where can i find ac motor connection diagrams, specifically, single phase forward and reverse, and 415v motor to 240v power diagrams? thanks andy
there is no motor that is single phase with 415 volts only 240 volt or 120volt and you cannot use a 3 phase motor on single phase it will just fail to start buzz and burn it up .single phase motors have capacitors 3 phase motors do not
Jun 15, 2011 | Air Tools & Compressors
Have a 3 phase compressor model vr5-8 want to know if it can be converted to single phase 230 volt and how
A 3phase motor cannot be rewired to run on single phase power. You need a phase converter. A 3-phase motor will only run on 3-phase power, and a phase converter will convert single phase power to 3 phase. Just google phase converter. There are two basic types, electronic and rotary. The rotary type are more powerful and efficient, but lot's more expensive than the electronic ones. Your only other option is to replace the motor with a single phase motor. Good luck.
May 17, 2011 | Garden
I have a 3 phase electrical motor for my air compressor, How would i connect this from the air compressor pressure switch and towards the electrical source 120V? (for low volt)
If the electrical 120 volt source is single phase, the only way to run this motor is with a single phase to three phase converter. Best to sell the three phase motor and obtain a similar horsepower 120 volt single-phase capacitor-start motor (1750 RPM) for the compressor. You would also require a 3-phase pressure switch for use with the 3-phase motor. Hope this helps!
Nov 05, 2010 | Garden
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
Aug 05, 2010 | Hobart H600 Stand Mixer
Can I change model 754 machine from three phase to single phase by just replaceing the three phase motors with single phase motors?
no you cannot. The cost to replace the dasher motor and compressor would be extreme. In addition, you would need to convert the controls from 3 phase controls over to single phase controls.
Those machines are designed for 3 phase power. If you could get the same components in a single phase version, you would spend more money economically than its worth.
Take the money you would spend converting and purchase a single phase countertop unit. They are made.
Feb 11, 2010 | Taylor 632-27 Ice Cream Maker
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
