Question about Maytag Neptune FAV6800AW Top Load Washer
It was running for awhile then it stop and DC appear in the panel
  • 526 Answers
I'm sure it is a Clutch Malfunction if the wash tub is banging around in Spin Cycle of the Wash Cycle.
See if this post Clutch Fix you will need the Service Manual, servicematers.com now charges for this but other forums have it available.
Join this forum then download the SM 16022808 Maytag Top Load Neptune Washer Service Manual
Posted on Oct 24, 2010
SOURCE:
1990 ford econoline Van e250 my van has been dying after running it for awhile once I shut it down and try starting again it won't turn over ! But if I can comeback after awhile and try starting it and...
If the headlights are dim when the engine stops, the alternator is not charging the battery.
A lead-acid battery will "recover" slightly when the engine is turned off. The recovery may be enough to allow the engine to be started again but if the battery is not being charged adeqautekly, the engne wills top running when the battery voltage falls too much. It won't last long, though. The battery terminal voltage should be around 14.5 Volts with the engine running. If it is 12V or less then the alternator is defective.
There are diodes in alternators to convert AC into DC for the battery. If you "jump start" cars with yours, its alternator diodes or the alternator's internal regulator circuit can be damaged due to excessive loads and/or what is called "inductive kickback" from the other car's starter.
Hope this helps!
Feb 11, 2015 | Ford Cars & Trucks
2001 kia sportage how to test ecu
substitute it with a known good one is the quickest method
Feb 22, 2018 | 2001 Kia Sportage
Advent 100 roma only works on battery not on dc charger
try another charger ,,, then check the power plug ( could be broken or needs re-soldering ) .... after you try all of that and didn't work that means you need to replace the power ic ...
Mar 06, 2012 | Computers & Internet
It Runs for a while then stop and DC appear in the panel
Probably a clutch issue se if this post will get you started Clutch Fix
If you are going to DIY you will need the Service Manual. You can't get it from servicematters.com anymore. There is another site that you can join and dowload the FAV6800A/FAV9800A Service Manual.
Join the forum then download the SM
Oct 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Pioneer Elite VSX-92txh - panel buttons stop wkg won't pwr off
There is a fix for this problem. Check out this info.
http://www.curtpalme.com/forum/viewtopic.php?t=19315
Jun 12, 2009 | Pioneer VSX-92TXH Receiver
I have a Coleman Powermate Pulse 1850 Generator.
If the generator hasn't been used for awhile the rotor may have lost it's magnetism. All you need is to re-excite it. There are several websites that explain how to do this. It's a good place to start.
Erick
Mar 23, 2009 | Coleman Electrical Supplies
Maytag Neptune FAV6800AW Top Load Washer Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
