Question about ASUS Computers & Internet
How to repair windows 7 in asus x70a from healthy hard drive
    New Friend:
  • 56 Answers
Make the drive bootable xcopy the entire contents of your windows dvd drive to the hdd and select repair my pc when prompted.
Posted on Oct 24, 2010
SOURCE:
Error code OX45d and the ASUS boot disk can not finish fresh install.
Your hard drive has some bad sectors and Windows 7/8 does not want to be installed in the problematic hard drive. They are require a healthy hard drive.
Feb 14, 2014 | ASUS Computers & Internet
Windows 7 installation disc doesn't see SATA hard drive
If your motherboard's BIOS is properly configured for SATA controllers and you burned the Windows 7 RC1 ISO image correctly, Windows 7 should recognise and install on a SATA drive without any third-party drivers. Consult your motherboard's User's Guide for assistance in setting up the BIOS properly.
In case Still Having Problem Then Follow Us For Computer Support For On : Computer Support
Feb 06, 2014 | HP Pavilion dv6130us Notebook
"asus" laptop boot from bios
Hi.
If you are trying to install Windows 7 from the USB flash drive then you need to configure the drive so the system will see it as a boot drive, see link below for instructions on how to do this. If you have Windows 7 installed on the flash drive then the boot files may have become corrupt thus preventing you from booting into the operating system. Link for installing Win 7 from USB below >>>>>
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
Regards.
Feb 04, 2013 | ASUS Computers & Internet
Graphic card for x70a asus
I am really sorry to tell you that approximately all the laptop come with only onboard graphics chip and there is no PCIE slot available on their motherboard to insert an external graphics card.
So you wont be able to upgrade you graphics card for this laptop.
Nov 27, 2012 | Computers & Internet
Unable to instaal windows 7 on Asus A3Ac
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
http://windows.microsoft.com/en-AU/windows7/products/system-requirements
hope this helps
Sep 21, 2012 | ASUS Computers & Internet
My asus eee pc 4g has windows xp program but i want to change it to windows 7,is it possible?how?
You can connect an external dvd drive or use a thumb drive to install windows 7. The thumb drive however will require you to format the drive itself to a different format and install windows files to it in order to make it both bootable and a windows 7 install. Here is a link on how to do that if that is the path you choose:
http://blogs.technet.com/b/aviraj/archive/2009/02/01/installing-windows-7-using-usb-thumb-drive.aspx
WARNING!! - It will take some know-how to be able to use the thumb drive, if you are unsure, get an external Hard Drive.
Sep 19, 2011 | ASUS Eee 4G Notebook
Eee 1000XP 160 GB HDD is partitioned (C) healthy system, (D) healthy but empty. How do I expand (C) to use empty space, Tried XP right click, no joy, tried command prompt still no joy. Any ideas???
The most-simple method is for you to remember to write to the 'D:' drive, to use that existing space.
There exists commercial software, namely "PowerQuest Partition Magic", that can delete the 'D:' partition, turning the space into "free" disk-space, and then "expand" the 'C:' drive, to extend its upper-boundary to incorporate some/all of that free-space.
Or, leave it partitioned, but always write your files to 'D:'.
Then, if you ever need to reinstall Windows to 'C:',
then all your data files on 'D:' will _NOT_ be "touched" at all.
Oct 23, 2010 | ASUS (90N804SH021) Hard Drive
Can windows 7 be installed on asus k8v-mx mb with amd sempron 2.4 1gb ddr1ram
this is the minimum spec for Windows 7:
  • Processor: 1 GHz 32-bit or 64-bit processor
  • Memory: 1 GB of system memory
  • Hard drive: 16 GB of available disk space
  • Video card: Support for DirectX 9 graphics with 128MB memory (in order to enable Aero theme)
  • Drive: DVD-R/W drive
  • Internet connection (to download the Beta and get updates)
Its not the motherboard, its the processor speed, RAM size, and hard drive space, and video card capability that counts.Your processor speed well meets this criteria and also your RAM size is within spec for Windows 7, and im sure you will have in excess of 16GiG hard drive space. So its all down to your video card. You may need to install DirectX 9.Hope this helps :)
Feb 14, 2010 | ASUS K8V-MX Motherboard
Will not load
Open up your PC. And from the windows menu, left Click to open, Settings, Control panel, and the Add
Hardware wizard. From the Add hardware wizard, install your ASUS hard drive. Just follow the instructions. If you get it installed, then it a job well done. Most of the time, Asus is a supported item of Windows XP, Vista, & 7
However, if you are prompted to have your own CD to
get it installed. Just have your download from the
Internet. Just type at the Search engine blank (Free
download Asus (90N804SH021) Hard drive software
installer). Once you have your download, go back to
your PC menu. Click open, the download and follow
the instruction to have it installed. Then, have your
test on the Asus harddrive.
Nov 28, 2009 | ASUS (90N804SH021) Hard Drive
Open Questions:
Computers & Internet Logo
389 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
