Question about Saeco D-XXDX 8-Cup Coffee Maker
How do I set the timer on my Saeco Venus8 cup coffee maker?
    New Friend:
SOURCE:
Saeco Intuita adjust water volume
Press and hold the coffee button the entire time until the cup gets to the length that you prefer, then let go. That will program the cup to that length.
Saeco Parts
Saeco Espresso Parts Brew Groups Pumps Boilers Water Tanks Drip trays
Sep 14, 2013 | Saeco Magic De Luxe Espresso Machine
I cannot reset the time on my Saeco coffee maker!! It keeps going back to the old time~~ the time buttons are on the bottom of the coffee base
Simply hold down the 'H' button until the machine beeps. Then proceed to set the time using hour and minute buttons. Top left button is for auto brew feature only.
Nov 08, 2010 | Saeco D-XXDX 8-Cup Coffee Maker
Saeco Vienna Superautomatica will not make a full cup of coffee
I'm wondering if you had any luck solving this? After 3 years of great coffee, my machine is only making a 1/4 cup or so. All parts are clean. I'm guessing something on the circuit board that the dial is attached to....thanks!
Feb 27, 2010 | Saeco Vienna SuperAutomatica Coffee...
Tip is broken - Saeco Magic Deluxe Expresso, Coffee Maker
In the UK Saeco parts are supplied by Gaggia UK in Halifax
Dec 13, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco royal
Try to set the grinder to grind coarser, make 2-3 cup of coffee to get coffee with the new settings.
/Mirran
Aug 25, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Easy dispenses first, then grinds
I think you have pre-brewing on your machine, if you have a Sirius then you have these settings in the menu under coffee settings.
I don´t think this is on Saeco Easy, only if you will make two cup of coffee, then the machine will pre-grind the beans for the second cup.
/Mirran
Aug 23, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Vienna Delux Expresso Maker
Try to descale the machine, also try to set the grinding to little more coarse.
Aug 22, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco D-XXDX 8-Cup Coffee Maker Logo
88 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
