Question about TechnoMarine Abyss ABS04 Watch for Men
Not really a problem, just a question. I have bought a black technomarine abyss 10900, and lost the box and manual for it. I'm not sure what model it is. whats the difference for example ABS02 and ABS05? In conjunction to this by looking at different webpages, it says one that the technomarine abyss can go different depths, some say 1200, some say 3000, and 12000. Whats its true depth?
2 Suggested Answers
SOURCE:
escapement
  • 2338 Answers
SOURCE: Is it possible to change the battery on the
It is possible. Open the watch case back, memorize all the writings on watch battery as well as how the battery is positioned (+ and -). Buy exactly the same battery, replace it and close the case back. To be sure case back is closed as tight as it was, draw fine line across the case and case back with non-permanent marker. This will help you align when closing the watch and you can clean it off later. Rate me, please.
Posted on Apr 26, 2010
Bezel part of my technomarine tmy magnum collection got lost. where can i find same parts?
you can find it only at techno marine authorized distributor because technomarine has a unique sylt that is design for technomarine only.
Jul 24, 2011 | Watches
How much
The Abyss 10.900 is a waterproof diving watch that features a silicone filled stainless steel case and stainless steel unidirectional bezel on a black rubber strap. Silicone is denser than salt water, making the Abyss water resistant to grater depths. 10.900 is the depth in meters of the deepest location on earth, the Marina trench in the Pacific Ocean. The refractive index of silicone enables you to see the dial and hands from any angle under water. You can typically buy this watch for about $425.00
Jul 17, 2011 | TechnoMarine Abyss ABS01 Watch
I have a Technomarine abyss, bought as used and don't know if working. Once open to change battery I found that there's oil also in the bak where is tored battery. Is it normal or the watch is...
Hi. It has silicone oil in it. To tolerate diving to that depth the watch is capable. It is normal, but if the silicone has to be completed if some leaked. Take it to the repair service. Best regards!!!!!!
May 13, 2011 | TechnoMarine Abyss ABS01 Watch
My watch has stopped working intermintently, does it contain a battery which requires replacement? Also, I do not have a manual for it, is there one available online. Thank you for your kind...
Yes it has a battery that will need to be changed every few years.
Click on the following link for details:
http://www.righttime.com/rt/technomarine/abs01.htm
Just take your watch into any jewellery store and they will change out the battery for you for around $10 parts and labour included.
Good luck.
Mar 29, 2011 | TechnoMarine Abyss ABS01 Watch
Hello i recently bought a technomarine watch and it is not moving. what do I have to do?
If you bought it recently, bring it back to the place you bought it from and ask for replacement.
Aug 05, 2010 | TechnoMarine DTC55C (Size: Unisex Adult)...
Is it possible to change the battery on the Technomarine 10900 at home (with the proper tools) or do I need to get it to a repair centre?
Apr 26, 2010 | TechnoMarine RSQC11 Wrist Watch
I Have a problem with my Technomarine ABS05. There is changed a battery by someone. but the watch doesnt work. I removed the back and some oil came out. where can i find that sort of oil? How can I change...
Oil should not come out of a watch. There just isn't that much oil in a watch to have it dripping out.
Are you sure it wasn't water? I can see where moisture could have gotten inside the watch if it was not sealed properly after the battery change.
The fast mall battery change places, jewelers and mart stores do not hire people that are trained to change batteries properly. We have a love hate relationship with those places. We love them because they keep us in business with all the watches they damage. We hate that they are in the business of replacing batteries in the first place because of how many watches they damage.
If you had one of those cheap battery stores replace the battery most likely they did not reseal your watch and it got water inside. This water will cause the problems you have now with your watch.
You will need to have a qualified watchmaker repair your watch.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 16, 2010 | TechnoMarine Abyss ABS05 Watch for Men
Technomarine
Sounds like the main drive is not "engaged" or you are in "stop watch" mode. Check to make sure you are in the correct mode. Then check to see if you can change the hour/minute hands. Reset the time and re-engage. See if that corrects the problem. (You've probably have done this already)
The watch has a 2 year warentee plus because it's water resistant down to 330 feet, I would take it back or to an authorized dealer to have it repaired. Other wise you stand the chance of damaging as really nice watch. And while you are there have them explain all the features. Really is a nice watch.
Nov 18, 2007 | TechnoMarine RSQC11 Wrist Watch
TechnoMarine Abyss ABS04 Watch for Men Logo
63 people viewed this question
Top TechnoMarine Watches Experts
Janelle Schoonover
Janelle Schoonover
Andrew Taylor
Andrew Taylor
Are you a TechnoMarine Watch Expert? Answer questions, earn points and help others
