What is the difference between the 6131 & 6141 bell receivers
2 Suggested Answers
SOURCE:
SOURCE: Need receiver code for Bell 6131 receiver, trying
try with the code 00775, it works fine with my sony nx810 remote
Posted on Jan 02, 2011
How do i hook up a second tv to bell 6131 receiver
you can use your nearest store to mare help
Dec 10, 2016 | Bell Televison & Video
Need a 6131 code for a Philips srp4004/27 universal remote,can anyone help
0065 0090 0101 0107 0119 0152 0163 0166 0171
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Sep 14, 2015 | Philips Televison & Video
Need remote control code bell 6131
It is in the owner's manual that was packaged with your receiver.
Sep 01, 2014 | Bose Cinemate Digital Home Theater System...
Samsung BD-F5100 remote code for Bell 6131 remote
There is usually a time limit within which these must be completed.
Mar 16, 2014 | Samsung Bd-f5100 Blu-ray Disc Player 1080p
500 9nk2al
don't think so, without right software
Sep 25, 2013 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I need to set my Motorola SB6141 modem to bridge mode
The 6141 is not a "gateway". It is always in "bridge mode". However, some crazy engineer decided that the 6141 should have a default DHCP server -IFF- it was unable to completely sync with the cable modem server (i.e. the other end of the cable). I have not been able to figure out how to turn this "feature off". But once it was by-passed, the 6141 worked flawlessly.
*by-passed: somehow (god only knows) the numerous reboots of the 6141 finally synced with the cable provider so that DHCP to my router was finally a "real" IP address. (not 192.168 or 10.0.0.0)
Sep 24, 2013 | Motorola Computers & Internet
Static crackle on yamaha 6030 in 5.1 ..static dissapears if you switch to two channel. coming from bell hd pvr...and sony ps3. with ps3 i have to select audio from dvd or blu ray menu and then 5.1 and...
It might be a bad connection then. First try and swithch it to a different outlet and settings. If it does not work it mightn have to be fixed then.
Mar 28, 2010 | Yamaha HTR-6030 Receiver
I have a maxtor one touch4 and tryin to conect to my bell 6131 hd reciever if formats fine reboots but will not see the drive just tells me to go the bell.ca/pvrmax page wich is pretty useless
Comparing the list of requirements, the ONLY questionable one is the requirement that the external drive does NOT have a sleep mode...
The Maxtor MIGHT have that and not be compatibleas a result. ALL the other requirements seem to be met assuming you are using the external power adapter on the Maxtor..
Jan 03, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Trying to read external HD, unknown partition
I see that you have a loss partition of your External HD. It is totally damage partition.
Here's what you do Replug your External HD to another PC if it is OK. Maybe its not the same will appear on your PC too.
Unknown Partition are likely big trouble to us if we have needed files inside.
Partition on every HD, External or USB are very needed, if you lose it. Then again reformat that to use again.
Hope its not gone. Good luck!
Aug 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Televison & Video Logo
302 people viewed this question
Top Televison & Video Experts
Ekse
