Question about Dryers
I have a Kenmore Elite Gas Dryer in which the drum does not turn. After selecting the mode switch and depressing the start button, the dryer only hums with no turning of the drum.
  • 525 Answers
Disconnect the dryer from its power source before servicing!
Inspect for a brokren drum belt. The humming noise is probably the motor running with no belt. You can easliy identify this by opening the dryer door, rotate the drum by hand by using a baffle as a gripping point. If the drum rotates freely, the belt is gone. If you feel a slight degree of resistance or drag, then you will have to go internal to inspect for the belt and associated rollers and idler pulley to make sure they are free rolling.
Posted on Jun 08, 2008
Kenmore Elite Electric Dryer -- Diagnostic for electronic control "Start" touchpad is 09. What does it mean?
i donot know what 9is but i think its the moter switch or moter try switch first
Jul 19, 2013 | Kenmore Dryers
Drum is having trouble turning
unplug the dryer before you start ,check roller & pulley or install dryer kit
Oct 18, 2017 | Kenmore 72972 Gas Dryer
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
I have a kenmore elite gas dryer... i can push the button to start the dryer and it will start turning but will not continue once depressing the button...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
Dec 23, 2010 | Kenmore Dryers
Our Kenmore Elite HE4 gas dryer will not start although all controls on front are lite and appear to be functioning properly (settings can be changed, etc). I has been working fine for several hours until...
check the door switch and door latch. Open door, set the dryer to air fluff cycle, and manually depress the door switch. Press start button. If it started - door needs alignment to fix it.
If it did not start:
If your dryer has light inside - check if light turns off when you press the switch. If not - switch needs replacement.
If all that checks out ok - the problem is more serious, and you might need a tech to come out and diagnose it.
Mar 04, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 73942 Gas Dryer only runs with start button held
Unplug the dryer. Open the control console.Mark and remove the wires from the start switch.
Using a volt meter set for continuity,touch meter leads to R1 and R2 while pushing the switch. No reading is a bad switch.
Touch meter leads to R2 and CT1. No reading is a bad switch.
If the switch checks out good the start windings in the motor are bad.
Dec 27, 2009 | Kenmore 73952 Gas Dryer
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer turns on, but does not run
Try to turn the drum inside with no clothes in it, does it turn freely both ways?
Then as someone is holding the start button, hold the door switch button, then try to turn the drum counter-clock wise, and see if it will start turning on its own.
If it does start turning, then the motor is more than likely the problem.
If it dosen't then the timer is more than likely the problem.
Feb 05, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore elite gas dryer
Does the ignition glow when you start the dryer? if so you have power to gas valve and ignition system. if not you may have an open thermostat or thermalfuse.
If the ignitor just sits there and glows all day, you have other problems, It could be a gas valve, or ignitor sensor.
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer isn't turning
This could be one or two things, it could be the safety switch located in door that activates the turning of the dryer. Or it could be a belt that turns the drum the motor could be turning inside and belt is broken.
Aug 16, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
94 people viewed this question
Top Dryers Experts
