Question about Coleman Refrigerators
Fan isn't working and its not cooling. It's model 564.
    New Friend:
  • 51 Answers
The fan motor could be bad, the relay, the contacter or the transformer could malfunction
Posted on Oct 24, 2010
SOURCE:
Has someone got a manual for lervia 564
This site lists manuals for Lervia (although not your model), however, sometimes machines are sometimes similar enough that other manuals are helpful:
http://safemanuals.com/page/search/Lervia+564
Kompernass LERVIA KH 4000 Operating Instructions Manual
May 27, 2016 | Sewing Machines
Cooling Fan Not Working
if the fan is electric, the problem is probably the fan thermostat. usually fitted into the water pipes near the radiator.
May 06, 2013 | 1996 Ford Escort 4 Door
GE spacemaker range model number jmp28g0r1wh display goes blank and oven turns off
the model number isn't correct.check and send the model number again.if you changed the sensor this should take care of the f3 error code but the clock shouldn't go blank and oven stops.like i say your model number doesn't show up as a good number,if this machine has a fan in it you could have a bad fan motor,the fan cools off the electronics and if it isn't working the clock assy. can get hot,damage it and it will do this,also i've seen on some models there's a screen where the fan is and dust gets stuck on the screen and the fan can't blow any air,i'm just telling you what i've found before but it sounds like the clock assy. is heating up and shutting down,if there isn't a fan in your model it sounds like you have a bad clock assy.if you send the model number i can look it up for you.
Nov 15, 2011 | Kitchen Ranges
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
I am in saudiarab i have crown victoria 97 model it is working good but i have problum in air condition system when i run my car its running good no problum but when i start my air condition it is heating...
The air conditioning condenser creates a lot of heat when the a/c is on. The cooling fan is supposed to run the whole time the a/c is on to keep it cool. If the fan isn't on, the radiator will absorb this heat and cause your car to over heat. You should also check your coolant level. So, it sounds to me like your cooling fan isn't working.
Sep 13, 2011 | 1997 Ford Crown Victoria
Maytag MDS2351- came home one day and noticed water coming from where u get the ice and water when i opened the freezer it was not cool and everything i had in there was defrosted and then when i went to...
Your fridge operates like that: a compressor liquefies freon vapours; this creates heat so the hot liquid goes thru a cooling radiator with a fan on it (these 2 elements are at the rear bottom of the fridge) the freon fluid goes to an evaporator, turns to vapour and absorbs heat in the process, cooling the evaporator; a fan blows air over the evaporator and spreads the cooled air all over the fridge; the vapours return to the compressor.
In the rear of the fridge you should make sure that the radiator is clean and the fan working; inside the fridge you should make sure that the evaporator is not covered in ice and/or dirt and its fan is working. If necessary clean both.
If they are clean , the fans work but the evaporator isn't cold then either the freon circuit has sprung a leak and all the fluid has been lost or the compressor isn't working - to find out which just put your hands on the compressor : if it's hot and vibrates the fluid has been lost, if it doesn't vibrates then the compressor isn't working.
The compressor isn't working because either the thermostat or itself have failed. To find out which the compressor will have to be powered directly from the mains: if it starts then the thermostat must be replaced, if it doesn't the compressor will.
To fix the freon circuit or to replace the compressor a certified professional is mandatory, you must call one.
Jul 12, 2011 | Refrigerators
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
What is cod 564 and 111
Code 111 is a good thing. It is simply telling you that the PCM is finished outputting codes and that there are no further problems that it needs to tell you about. On a vehicle that has no problems with the computer controls, code 111 will be the only code that you will get. The time to worry about code 111 is when you cannot get the computer to give you this code. (usually caused by a failed computer)
Code 564 is a cooling fan control circuit code. If your engine has been overheating, this code is telling you why...your cooling fan is not working. Code 564 indicates a failure of the Low speed Fan Control (LFC) relay PRIMARY circuit. It can be caused by an open or shorted LFC primary circuit control or power wire, A defective LFC Relay, or a faulty PCM.
The relay is controlled by the YELLOW/WHITE wire at Pin #35 in the PCM. This wire needs to be checked for an open or shorted circuit. The relay is powered by the ENGINE fuse (15 Amp) in the Instrument Panel Fuse Block. If the engine starts, this fuse is good because is also supplies power to the starter relay. If the fuse is good and the wire has no short to ground or open circuit between the relay and the PCM, then I would try replacing the relay to see if it resolves the problem. If not, you will have to replace your PCM.
May 15, 2011 | 1995 Ford Escort
Coleman 12-volt cooler stoped working/fan burned out
Sound like you have the newer version. These fans can be found at Radio Shack or anywhere computer parts are sold. It doesnt have to be an exact replacement. Just big enough to fit over the Cooling fins. Also make sure it's a 12 volt motor
Jun 25, 2009 | Coleman Electric Cooler 40 Beverage Cooler
I purchased a Coleman model 564 cooler about june 1,2008 at Wal-mart. I used it for two trips to Canada,June and August,one week each. The fan operates spasmodically and the unit does not cool. I believe...
I had the same problem with the fan...its junk.. don't try to replace it with the same kind of fan. I went to radio shack and got a 3.15"square brushless fan. You could go to a computer store and get the 3 &5/8" fan with ball bearings and it would fit just like the old one. Fans run about $15 to $20 depending on location. I cut the old one out and sodered the new one in and it works fine now. Hope this helps. Larry Crockett at [email protected] Let me know how it works.
Aug 28, 2008 | Heating & Cooling
Refrigerators Logo
129 people viewed this question
Top Coleman Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Coleman Refrigerator Expert? Answer questions, earn points and help others
