Question about Compaq Presario R3000 Notebook
Compaq presario R3000 Laptop power and fan problems
When I turn my computer on, the cooling fan goes into warp drive and then the computer shuts down, also it sometimes takes forever to boot up. the pc is plugged into the mains all the time but the pc starts using the battery and then shuts off. can you help?
Actually if you can hear the fans running then what you need to replace is the thermal compound on the processor chip it is like 5-10 dollars cad at your local computer store and you can re paste it on your chip and it cools the laptop substantially i had the same problem... it oveheated within minutes and now i can let it sit right on my lap or on the couch and every 1-2 years it should be replaced... and it will help make your laptop have a longer life span
Posted on Oct 25, 2008
Your machine is overheating. Try cleaning the vents with a can of compressed air and making sure the heat sync is free of dust. If that doesn't work, you may need to replace the fans.
Posted on Jun 17, 2008
My laptop Presario R3000 won't turn on
let it sit for awhile. then try to power it on. if it powers up and then suts off again, the processor fan is probably bad and needs to be replaced.
Also, take the battery out and tryy to power it up.
Aug 13, 2009 | Compaq Presario R3000 Notebook
My HP COMPAQ Presario R3000 is turning-of like accidentaly, sometimes is showing , "low battery"
is this happening with the AC adaptor connected?
Connect the AC if it still is exibiting the same chariteristics Charging system needs to be addressed. If not then your batteries are weakening!
Aug 02, 2009 | Compaq Presario R3000 Notebook
I have the same problem
could be a bad driver you have installed
Jul 17, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Compaq Presario 3000 incredibly slow firing up, opening up anything. Loud fan all the time too
This advice relates to the Compaq Presario 3000 Notebook series but may also apply to other notebook computers as well.
The heat sink and fan assembly is probably clogged with dust and airborne particles. The clogged cooling parts can lead to heat problems with the CPU. When the system (CPU) gets to hot, the fan has to kick into high gear to try to cool things down. Once you remove dust and debre from the heat sink fins and fan, you will immediately experience better cooling and less fan usage. Your system may also be set for dynamic switching of CPU speed. If you CPU gets too hot, the system will reduce clock speed and ramp up fan and everything will slow way down. Use a good system monitoring software such as Notebook Hardware Control to monitor your CPU temperature, HDD temp and so forth. When the system starts getting too hot, first look at clogged heat sink fins as possible culprit. If you're good at electronics you may be able to service the unit yourself. Get a copy of the system's Maintenance and Service Manual or have a professional do the job for you as you will have to partially disassemble the computer to clean out the heat sink. Depending on the system, the job can take as little as 15-20 minutes once you become proficient at it.
May 09, 2009 | HP Laptop Keyboard for HP Compaq Presario...
Compaq R3000 laptop screen went black
Give this a try -
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Let me know if it doesnt work.
Jan 20, 2009 | Compaq Presario 2190US Notebook
Compaq presario r3000 amd athlon laptop cuts off after 10 minutes
from my experience this might be one of two things...
if it's shutting down while you're installing windows, i'm thinking you might have a problem with the motherboard channel for your CD drive. i saw this happen to a computer at work - we couldn't install windows because it cut off halfway through and blue screened on us.
it might also be a case of a bad hard drive, if you have any testing utility like drive fitness test i'd give that a shot. it sounds like a new one, but they're bad out of the box sometimes.
hope this helps
Jan 15, 2009 | Compaq Presario R3000 Notebook
Laptop Screen dark yet computer works with external monitor
does the fan work ok? and do you have a laptop holder for it or you just have it on a desk ....get a laptop holder for it if you do not have one and as for the rest goto the power mangment area on the computer and see if the monitor might be on stand by after a few min ...
Jul 14, 2008 | Compaq Presario R3000 Notebook
Presario r3000 shuts down
I have experienced similar problems. I found that if the fans were REALLY dirty, the system would overheat and shut down with no warning.
May 04, 2008 | Compaq Presario R3000 Notebook
Laptop wont power up.
LS-120 SuperDisk drive help Next, connect the power and boot the computer and install the software ... as the computer beeps or pressing and holding CTRL as the computer is booting up.
Good Luck, Read and folow instructions/Please dont for get to Vote/Thank You.
Dec 25, 2007 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Notebook Logo
223 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
