Is there anything I can try for my Belkin router. It isn't working and the wireless light will not stay lit. I have unplug it and left it unplug overnight but still doesn't work.
    New Friend:
  • 58 Answers
Have you gone into network connection in the menus and see if your wireless in enabled and not disabled. If I am not mistaking, you need to connect the Ethernet cable to your laptop (leaving you wireless router connected) and go to the Belkin web site to reset your wireless router.
Posted on Oct 24, 2010
6ya staff
SOURCE:
Hi, I'm using a Belkin N1 wireless router. I mostly have a stable internet connection, but once in a while the "wireless" icon start blinking orange. What is this? My internet some times get...
if the wireless light is lit up in red it says "someone is trying to connect to your network using wrong password"
Sometimes if any of your devices are not compatible with the security enabled in the router then the light will lit up in red. click here to know more about security types of belkin router
routers has to be turned off atleast 2 hours per day for it to work properly... so better turn off the router when not in use, this will clear the routing table of your router and will make the router to work as a fresh router everyday, so you wont face any speed problems.
May 03, 2011 | Belkin N1 Wireless-N Wireless Router
For some reason the light above the WPS button keeps flashing red. I have tried multiple reboots, none of which have worked. when connected to the ethernet modem, the light stays as a solid red color.
You need to reset your Router before setup manually.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Aug 16, 2010 | Belkin Wireless Play Router (F7D4302)
Unable to configure my wireless belkin N150
As i understand you have a router provided by your ISP: MTNL, you need to configure the Belkin router in Dynamic mode and not in PPPoE. Then restart the devices by unplugging the power from MTNL router and Belkin. Wait for 20 secs, then power up MTNL router 1st, wait for all lights to get steady and finally power up the Belkin wireless router. Then you will find the modem and internet light lit up properly.
For any further clarifications, revert!
Thanks and regards,
Arvind
Jul 09, 2010 | Belkin N150 (F6D4050) 802.11g/b Wireless...
N Wireless Modem-Router F5D8633au4A: every light on my belkin N wireless router is on e...
WIRELESS LIGHT WILL LIT UP IF YOU CONNECT ANY ANY WIRELESS DEVICE TO THE ROUTER.. FOR EX: YOU CAN SEE WIRED LIGHT LITTED UP BECAUSE YOU CONNECTED A COMPUTER WITH HELP OF ETHERNET CABLE.. IN THE SAME IT WILL WORK...
May 17, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
The wireless light is not lighting up. I am unable to connect to the Internet. I have rebooted the modem and router and still does not work.
ISSUE: No wireless light in the Belkin Router and not anle to go online
SOLUTION:(Wireless light will lit up if u connect any device to the network)
Step 1: First hard wire Modem>Router>Computer
Step 2: Open internet explorer and type in this (192.168.2.1) address in address bar
Step 3: You see Belkin Router Ste Up Page
Step 4: In top right corner you can find internet status it would say Connected or Not Connected
Step 5: In your for left left screeen you can find list of options in that click on "Restore Factory Default"
Step 6: It will ask you password leave it balnk and click "SUBMIT"
Step 7: Click on "Restore Defaults" Button and It will show you two warning messages click "OK" "OK"
Step 8: Then you can see the router will reboot once it is completed you will be back to the Home Page
Step 9: In your for left left screeen click on "MAC Address"
Step 10:It will ask you password leave it balnk and click "SUBMIT"
Step 11:You can see Clone computer's MAC address Button Click on It "CLONE"
Step 12:Then you can see the router will reboot once it is completed you will be back to the Home Page
Step 13:In top right corner you can find internet status it would say Connected if its not
Step 14:Unplug the Power Cord from MODEM and RUTER wait for 2 minutes
Step 15:Plug the Power cord to Modem first and wait for 2 miuntes
Step 16:Plug the Power cord to Router and wait for 2 miuntes
Step 17:You can see Modem light in router will lit up standerd Green
Step 18:In top right corner you can find internet status it would say Connected
Step 19:In your for left left screeen click on 'Channel & ssid'
Step 20:Set the Wireless channel to 6 and in SSID type in your New network name may type in your first name
Step 21:In your for left left screeen click on " Wifi Protected Setup"
Step 22:"Disable" the Wifi Protected Setup
step 23:In your for left left screeen click on "Security"
Step 24:In the Security mode select "64 bit wep"
Step 25:Select Key 1 option and in the Key1 type in any 10 digit nunmber's that gonna be Wireless network security key
Step 26:Now go head scan for your wireless network name from any wireless computer and access it
Step 27:Type in the 10 digit network security key
Step 28:Now you can connect to the netywork and you can go online wirelessly from your wireles computers
Step 29: Now you can see the Wireless light lit up in your wireless router
Now your Good to go.... Check you can go online..Good Luck...Budy
If you need any help ....Please P.M me..... I'M here to help you all....
Thanks&Regards,
Karthi.J
Apr 23, 2010 | Belkin (F5D8231-4) Wireless Router...
Wireless light on my belkin n- 150 router not
No Sync with the wireless, either may need to connect a wireless device or PC first... If now something to do with the wireless...
Mar 21, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Our belkin g wireless router was working fine until a friend brought his laptop over connected to our router and now our own laptop will not connect to our router. Is there anything we can do?
Hi Friend,
We have to change the MAC Address Cloning in the router,please follwo the below mentioned steps,
1.Type 192.168.2.1,you will get a Belkin router setup page
2.On your left hand side, Click on MAC Address or MAC Address Cloning
3.It will ask fopr password,leave it blank and click on submit
4.then click on Clone,(It will assign your computers mac to the Router) ,now click on Apply changes
5.Then unplug the power cable of both modem and router,after 10 secs put only to the modem,after all lights got lit up,put the power cable to Router.
6.Then check the lights in router u will have all the lights in blue or green.
7.Try to scan and connect.You will be able to connect to the internet in wireless
Regards,
Ayyasam
Feb 27, 2010 | Belkin Computers & Internet
I just bought a Belkin Router Model # F5D8236-4. I have everything wired correctly, but the wireless light does not come on. I can't get the internet to come on to the computer I want to connect to? What...
Wireless light will lit up only if any wireless computer is connected to Belkin's wireless network.
First, connect to Belkin's wireless network that you can scan.
After you connect, try to go online
It ll work...
Jan 21, 2010 | Belkin (F5D8231-4) Wireless Router...
Belkin F5D7230-4 not working anymore?
Well i think u r right, u must contact to Belkin support team (http://www.belkin.com/support/) or to from where u buy this. If router is in warranty period then u will get replacement.
Mar 21, 2009 | Belkin (F5D7230-4) Router (587009)
I unplugged the cable connected to my desktop and the wireless function stopped working
You must always have a 'host' adaptor whether you want a LAN or a WAN. Go to your configuration utility or control panel via your Run command to set or view your options. Steve Medley
Nov 07, 2008 | Belkin (F5D8231-4) Wireless Router...
Open Questions:
Computers & Internet Logo
37 people viewed this question
Ekse
Marvin
Marvin
