When my computer starts up it goes to a black screen after windows set-up is finished. How do i fix this?
    New Friend:
  • 56 Answers
It is a software error within windows, either your hdd is corrupt or your installation dvd. Tryin at the black screen hittin ctrl+alt+del and then file run new task and type explorer.exe and run if windows loads then you have corrupt data.,
Posted on Oct 24, 2010
SOURCE:
After changing out fan IBM think pad t40 screen goes black after windows xp screen finishes losding up
Wait Black Screen? AFTER you changed the fan... hmmm... I think I know what the problem is. Okay solution one; You might of hit a wire or cord in the computer when you changed out the fan. Two: You might have the virus 223, get it fixed and it should be going again! Hoped this helped! :D
Mar 25, 2013 | IBM ThinkPad T40 2373 Notebook
My hp g61 will only display a blank/black screen with the cursor after it has finish booting
That cursor is the way in which the BIOS of the laptop is telling you that Windows is completely corrupted and unbootable. You will need to reinstall it so use the recovery cd that came with the laptop.
Dec 28, 2010 | HP G60-120US Laptop
My laptop came on but my screen is black. I can hear my coputer on but my screen is staying black.
Here are some discrete steps you shall also take besides fixing your Windows 7 registry which is inevitable for safer and stable computing:
* Conduct an antivirus and antimalware scan. Fixing for malwares after a registry scan gives an extra protection to the PC and saves PCs from lots of dangerous infections.
* Start Windows 7 in safe mode and restore your PC/system to the previous date after which you received the Windows 7 updates. It is believed that some updates may be behind these screen issues in Windows 7.
* Adjust your display settings since the wrong settings may also cause the Windows 7 black screen also called the blank screen. You can do this by starting Windows in safe mode.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen.use registry cleaner reg in out to solve the issue
Sep 13, 2010 | HP Pavilion dv6000z Notebook
Laptop is working fine until the screen goes black
The problem of black screen can also happen in other versions of the Windows. However, the symptoms and effects of the problems in all operating systems are almost same. For instance, when a user starts his Windows, everything goes fine. But when he logs into it there awaits a black screen instead of the normal desktop layout. An average computer user finds it very disturbing and has no clue how to fix Windows 7.
However, the best way to find a solution to this problem is to fix the registry errors in your computer which become the cause of all major Windows errors and crashes. The registry in Windows 7 is a very important component of the entire operating system and it stores information about the Windows settings. If these settings are not adjusted properly then there start to appear strange computer problems such as Windows 7 black screen.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen. The best available tool to repair registry and fix PC errors such as this is Reg In Out.
Sep 12, 2010 | Acer Aspire One PC Notebook
I had the blue screen of death come up on my wifes lapton inspiron b120. The computer shut down and now it goes to the black screen that says windows didnt shutdown correctly..... any tips on...
click on start windows normally and if the problem come back again. try these steps
in this case, we need to reset the computer back to factory settings.
here we go...this process will cause data loss.
1. Remove non-essential peripherals
like
a) Scanner
b) Printer
c) Modem or Network cables
d) Personal Digital Assistant (PDA)
e) USB flash drive or other external Hard Drive
f) Any other external devices (e.g., USB-attached devices)
g) Remove the computer from the docking station, if you are using one.
2. Turn on the computer.
3. When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
4. In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
5. When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
6. Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received.
Oct 16, 2009 | Dell Computers & Internet
When It goes to loading screen it restarts
It is becasue of your computer is not properly shut down and so your harddisk has some bed indexing of memory location.
For that you need winxp disk or recovery disk.
Then boot your computer with that disk .
You have to set first boot device as your cd or dvd rom.;
For that when you power up press F1 or F2 or "del" key to enter in bios .
Then go to boot option then sewt first boot device as your cd or dvd rom.
then save settings then put winxp or recovery disk in rom.
Then follow the procedure .
Then enter in recovery console then type in prompt "chkdsk /r"
then it fix error on harddisk.
Sometimes this command fix eror and then after restart windows load normally but sometimes need to repair windows.
So after check this if still face issue just chose "r" when it finds your previous version of windows then it recovers your windows.
Let me know if you need more assistanse.
Thanks.
Sep 04, 2009 | Computers & Internet
Monitor comes on for seconds and then goes black
This may be because the resolution that is set in your user profile when you log on has been changed to a resolution not supported by the monitor. The best way to fix this is by going into Safe Mode (press F8 as the computer starts to load Windows) and change it to a lower resolution once you get logged in. 1024X768 is a pretty safe resolution to start with. Then restart and see if that fixes the issue.
Sep 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My computer screen goes black after the windows loading page has finished is their anyway to fix it whithout reformating the comp
try to boot the pc in safemode,and restore your windows in recent time the pc is good
GOOD DAY!!!
Sep 16, 2008 | Computers & Internet
Finishing Migration
display resoulation does not support please set the display resoulation
Sep 23, 2007 | Laplink Software PCmover for PC
Open Questions:
Computers & Internet Logo
64 people viewed this question
Ekse
Alun Cox
