Anonymous Posted on Jun 07, 2008
Pioneer model VSX-3300, I had
Pioneer receiver: Model VSX-3300, I had this unit fixed about 5 years ago. It has not been in used since. When I turn it on, I get power, Tv, everything but the radio. Can you help?
  • 1 more comment
  • Anonymous Jun 07, 2008
    I have not opened it up yet. I am not techno savy at all, but I am willing to get my hands dirty. Can you tell where I might find these capacitors? What they might look like? And how to check them.
    The signal is not the problem.Like I said the power comes on. I can hook it up to my TV and get sound from the speakers, just no radio. I don't know if the Tuner button does not work.
    Thank all of you for your help. I will try your suggestions.
    Rocky
Ekse
Level 3:
  • Pioneer Master 13,435 Answers
  • Posted on Jun 07, 2008
Ekse
Pioneer Master
Level 3:
Answers
13435
Questions
82
Helped
3985165
Points
38023
Here you can see faulty capasitors
Hard to say what may be the problem.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 304 Answers
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
304
Questions
0
Helped
115821
Points
831
Clean the contact point inside the unit, it is possible have a dirt and have to clean..
Anonymous
Level 3:
Brigadier General:
  • Master 3,614 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
3614
Questions
24
Helped
1009775
Points
10054
Do you have no signal on your radio..? KIndly find a better spot which could get better reception..
    have you try to use the remote to select into a radio mode..
    if you had a remote on that unit, try selecting the radio mode there..
    Let us know..
Anonymous
Level 3:
Guru:
  • Master 1,894 Answers
Anonymous
Master
Level 3:
Guru:
Answers
1894
Questions
13
Helped
563539
Points
4850
I think the radio module is fried up
    did u open it and check the capacitors?
    also may be due to some kind of shorting since it has not been used from a long time.
    just make a cleaning work inside it and the start the unit.
    you can get it fixed i think
    thank you
2answers
Pioneer VSX-D412 directv remote code
I also have the VSX D412 and DirectTV. My DirectTV remote controls the D412 fine, but I did have the same problem you're experiecing with a Sylvania flat screen that the remote wouldn't operate. I corrected my problem by turning the TV off, then back on using the TV's remote, then telling the DirectTV system that I didn't know the model number and let the system search for the code. Hope this helps.
My pioneer vsx 1015 . I had it turned up rather loud for a few hours a few nights ago and it suddenly cut out. powered off. When i turn it on either directly or through the remote control the power light...
With nothing showing up on the front panel display, I would first look at the power transformer. there is a thermal fuse built into the transformer core, and with your description on what happened, it could have gotten too hot and blown this fuse.
2helpful
2answers
My Pioneer VSX-D1S A/V receiver will not power on; this began yesterday. Pressing the power button results in only a clicking sound along with the standby LED turning on. The owner's manual states to press...
Unit is pretty old I had one of these back in 98-99.
Time to upgrade a service tech is going to cost you $150 just to open it up and figure out whats bad.
Pioneer ok but check out Denon's line of receivers Onkyo is good too but they have a high rate of repairs
Pioneer doesn't make them like they used to that D1S was a tank, had tons of audio / video inputs was one of the first with video upconverting had lots of power and a great front display panel. BUT technology has come along way and pioneer hasn't kept up. They even stopped making high end TV's a few years ago even though they were regarded as the best sets out there.
check this out
Denon AVR-4310CIgoogle it they sell for ALOT less than sticker I bought one for $1299 with a 5 year warranty
Hope that helps
3helpful
No audio output
THE FIX - to audio problems that persist with the VSX-29TX and others using the AWX7272 DSP board is to replace the ROM on the DSP. My unit started failing on and off after 10 years of use! The intermittent DSP board is an Extremely Common and irritating Problem for this model! The replacement IC,(2) resistors + shipping and handling totaled $49.65 and my unit is finally fixed correctly! Don't believe other posts that you can get away with re-soldering; it will continue to fail again and again! Details of fix are:
Replacement for the old Pioneer ROM located at location IC 9374, should be done with the part PD6381A from Pioneer Electronics. You will also need to move (relocate) the 2 resistors (0 Ohm resistors) located at R9372 and R9371 to locations R9374 and R9373.
This component update applies to DSP boards marked as AWX7433, AWX7272.
This fix is validated (from Pioneer) on the VSX-26TX,VSX-27TX,& VSX-29TX it might also work in the VSX-908, VSX-908RDS and others as long as the same DSP board was used.
Let me caution and stress that surface mount soldering skills ARE REQUIRED to do this update! It also doesn't hurt to have excellent vision and/or an eye loop or microscope to check your work. Original ROM's were subject to timing changes internal to the part as a result of HEAT. This model does get HOT! The program was also modified as a further safeguard to re-occurrence.
1helpful
Owners book / manual for Pioneer receiver VSX-605s
www.pioneerusa.com then support. I could not find your "Exact" model, and it could depend on where it was purchased. Look at units closely labeled to yours and chances are it will be the same with a different #. Hope this helps
1helpful
Does pioneer model vsx 403 come with a remote control? If so how can you relace it?
I have the same unit. It does come with a remote. The original remote is pretty much impossible to find. But also there are some companies that sell remotes for it. Google Pioneer VSX403 remote replacement. I have yet to get a remote :D
Good Luck.
Lost remote controller of Pioneer VSX-D506S
You can buy Original Pioneer Remote from HERE for VSX-D506S
Cannot fix the sound
Take it back this receiver is out dated by at least 5 years (mine is over 5 years old) Purchase a newer one......
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
