Question about Singer 8280 Mechanical Sewing Machine
How to insert the bobbin, not the one on top, the one under? THANKS! :D
  • dany_soccer Oct 24, 2010
    Please help me. Greatly appreciate it! :D
    Genius:
  • 1,788 Answers
Go to www.singerco.com and download your manual for free. When you see it, enlarge the diagrams and you will see exactly what you need, It is much easier than trying to explain it.
Posted on Oct 24, 2010
SOURCE:
My brother RL 417 makes a clattering noise when I start sewing and swallows the fabric
try a new needle--one that is for the fabric being sewed
clean under the needle plate and in the bobbin area for lint
rethread the machine top and bobbin
if the bobbin is top loading make sure the bobbin is inserted into the bobbin case correctly
if the bobbin is side or front loading then also make sure the bobbin case is inserted into the machine correctly
make sure the bobbin is not warped
make sure the thread has not come off the thread take up lever
Aug 23, 2013 | Sewing Machines
I have a hyundai 8 stitch sewign machine been working brillant but last night it kept missing the tread and the thread breaking or jabbing . today looking at it i see when it jabs the Bobbin Case Inner...
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
if the sewing machine has a top loading bobbin, you may have to have the sewing machine checked to see if there is something wrong with the bobbin case or the hook and hook race.
I suggest try a new needle--one for the fabric being sewed
also try another bobbin
rethread the sewing machine top and bobbin, using every thread guide.
Aug 21, 2013 | Sewing Machines
My machine will sew one or two stitches then the threads get all tangled under the plate. appears to be the top thread, not the bobbin
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Aug 20, 2013 | Baby Lock Ellure
My 7258 stylish will not make a stitch
try changing the needle--insert the needle all the way up into the
needle holder
make sure it's the right needle for the thread & fabric being sewed
rethread the machine top & bobbin
make sure the bobbin is inserted into the bobbin correctly & turned
the right way
clean under the needle plate & in the bobbin area for lint
Sep 10, 2012 | Singer Sewing Machines
I posted a question last night, but have not received an answer. Thanks
try changing the needle--make sure it's the right one for the
thread & fabric
make sure the top thread has not come off the thread take up
lever
rethread the machine top & bobbin--make sure to use every
thread guide
make sure the bobbin is not over full
make sure the bobbin is inserted correctly into the bobbin case
Sep 08, 2012 | Singer Sewing Machines
How do I stop getting thread jams
try these suggestions
change needle
clean under needle plate & in bobbin area for lint or loose threadsmake make sure the top thread has not come off the thread take up lever
make sure the bobbin is not over wound
make the bobbin is turned correctly
make the bobbin is inserted correctly into the bobbin case
Aug 28, 2012 | Sewing Machines
Pfaff 4.0 quilt expression pulling bobbin thread up to top of fabric help.
try a new needle
try adjusting the top tension just a touch to see if that helps
clean under the needle plate & in the bobbin area for loose threads
or lint
make sure the bobbin is wound correctly & inserted into the bobbin
case correctly
Jun 04, 2012 | Pfaff Creative 4.0 Sewing Machnie
Hello! My reliable 1222 has hit a snag. When try to sew, the top thread is not being picked up by the bobbin thread. How can I fix it? Pavla
clean under the needle plate & in bobbin area for loose threads & lint
try rethreading the machine top & bobbin, make sure to get every thread guide
make sure the bobbin is inserted correctly in the bobbin case
Mar 11, 2012 | PfaFF Sewing Machines
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Bobbin
HI hold bobbin case in left hand bobbin and in right hand with the thread going away from you across the top of the bobbin hold the bobbin, the top of the **** the thread goes in to should be up put the bobbin in the case pull thread into **** and under the tension spring while holding thread insert into machine until it clicks, make sure it clicks if it doesnt click it is not in then just gently rotate it till it does click let me know if this helps thanks amy
Jun 13, 2008 | Brother LS-2125 Mechanical Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
tsalagi152
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
