Question about Motorola Cell Phones
How do I change my Motorola bluetooth to my new blackberry
  • 282 Answers
You will have to put your motorola headset to pairing mode usually you have to hold the power button until you see that the light on the constantly on either red or blue. once its in pairing mode then you have to make sure youe bluetooth on the phone is on and then search for bluetooth. the default password on motorola bluetooth are 0000. hope this helps
Posted on Oct 24, 2010
SOURCE:
Passkey for bluetooth?
most bluetooth earpiece pass keys are 0000 or 000000. Hold the device power button down until the lights flash two colors, then locate device with the blackberry. Enter either of the two codes and see which works. Normally you can not change the code on the earpiece, but you can on the phones.
Jul 24, 2009 | Motorola Mobility H700 Wireless Headset
Bluetooth
Some phones only have a certain amount of time that they are visible to other bluetooth devices. in the bluetooth settings menu, you can maybe change the time allowed or you can keep it as always visible.
Apr 05, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Can't find my Motorola H681 numeric passkey for connecting it
The default is usually 0000 on most bluetooth headsets, try to find the manual for your bluetooth device, it should say.
Jan 08, 2009 | AT&T Blackberry Curve 8300 Smartphone
Bluetooth
Your bluetooth needs to be in pairing mode. Depending on what model bluetooth there are several methods to put it in pairing mode. the most common is pushing and holding the main button until a light changes color.
Dec 02, 2008 | RIM BlackBerry 8800 Smartphone
Pairing Motorola HS820 with Blackberry 8310
there is really no fail safe method to pairing a bluetooth device.
The main thing is recognition. i,d suggest trying to press the different buttons on the transmitting bluetooth device, whilst attempting to pair. i.e volume up/down or on/off et,c. to enable the device-blackberry to find and sync. i,d think the device that needs to be configured or setup correctly is the blackberry rather than the bluetooth device.
try changing the phone settings. to accept all incoming signals on bluetooth, or disable encryption.
hope this helps.
Mike @ Compurepair.
Oct 06, 2008 | Motorola Mobility HS820 Consumer Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Cell Phones Logo
87 people viewed this question
Top Motorola Cell Phones Experts
Ekse
Damen Wong
Damen Wong
RONALD CARTER JR
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
